Mud Flaps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sadie, May 13, 2016.
  1. May 13, 2016 at 4:32 AM
    Sadie
    Sadie [OP] Member
    2016 Toyota Tacoma SR5 Access Cab
    Just bought a 2016 Toyota Tacoma SR5 Access Cab. Had the dealer ship put on mud flaps on. They look like car mud flaps. Can some one recommend some other type of mud flaps. Would like to change them when my all terrain tires are put on.
  2. May 13, 2016 at 4:44 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    I just got some RokBloktz for my 15, needed wider for tire/wheel setup. Have not put them on yet, but the quality looks real good, they are much wider,12" wide in front, 13" wide in rear.
    Sadie[OP] likes this.
  3. May 13, 2016 at 4:49 AM
    YDCtaco
    YDCtaco Well-Known Member
    Alexandria, VA
    2016 DCSB TRD OR 4x4-Auto
    I like the oem flaps
    stokka and CusterFan like this.
  4. May 13, 2016 at 5:55 AM
    tacosmine
    tacosmine Well-Known Member
    NW Oregon
    2016 SR5 White DCLB 4x4 Auto V6
    OEM style running boards
    Rokbloktz are the best going right now if you want to protect your rig.
  5. May 13, 2016 at 7:04 AM
    crepr12
    crepr12 Well-Known Member
    25 Limited Hybrid
    just glue a naked form of a women on the rear flaps and your in business
  6. May 13, 2016 at 7:08 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    weathertech has decent ones not sure if 2016 is ready but they have 'em
  7. May 13, 2016 at 7:14 AM
    COskimtb
    COskimtb Well-Known Member
    2016 Tacoma OR 4X4 DCSB 6MT MGM
    What's the difference between OEM and Weathertechs?
  8. May 13, 2016 at 7:17 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    on my 2013 I got weather techs for the front since they are shorter than OEM,
    and now front and back (back are oem) look even.
    otherwise not much different than oem. I don't know much about OEM 2016 flaps though if they are overly long
    like previous years
  9. May 13, 2016 at 10:37 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    The OEM "flaps" are not really Flaps, they are more/less "Guards" like Weather Tech and Husky, they are stiff molded plastic and if you do any wheeling or driving through snow/ice they will likely rip off of your truck and strip the mounting hardware in the process. Floppy rubberized style "Flaps" are more useful for my application because I drive back roads, unmaintained fire and forest service roads, and I am often in areas that a 2wheel drive truck is not going to get back into... so with that being said there are some Floppy options out there that are better suited and some options are far more affordable than others. If you search this forum for Plasticolor you will find a good amount of info and photos on 3rd gen owners using them with install info. Beyond that you have the RockBlokz which I didn't care for because they flare out too far and have a logo that resembles something you'd see on an energy drink can, but to each their own. Also you have Rally Armor which I felt fit into the same category as Rock Blokz. They make Plasticolor with the oldschool 4WD white logo which I thought looked pretty nice, and they fit flush with the fender flares and for me that just looks a whole lot better. Now if you are going to run oversized tires that stick out, the Rock Blokz and Rally Armor might be better, but they do cost more too. All things to consider.
  10. May 13, 2016 at 10:55 AM
    2016BBP
    2016BBP Well-Known Member
    Southeast
    SR5 V6 Auto
    Method Wheels, WxTechGuards, TowPkg, KNDropn, 3M-Tint
    I like the Weather Tec, they fit great and only takes 15 minutes to put them on
    George1441 likes this.
  11. May 13, 2016 at 11:02 AM
    smitty99
    Scottsdale
    Great for pavement. Not good for OP's intended use of "All Terrain"... those puppies won't last off road.
    ZachMX likes this.
  12. May 14, 2016 at 4:04 AM
    Sadie
    Sadie [OP] Member
    I was thinking Yosemite Sam!
  13. May 14, 2016 at 4:48 AM
    psvines
    psvines Well-Known Member
    2016 SR5
    OEM ARE $140+ and Weathertech are $80. I really like my Weathertech, easy to install.
    They probably won't tolerate intense off roading, but for now I'm driving a "pavement princess" as someone else has said. My previous truck was lifted and I had removed the mud flaps.
  14. May 14, 2016 at 5:44 AM
    JQ3
    JQ3 Well-Known Member
    I have the OEM mud guards as well, but my truck is 2WD. We rarely get snow here, besides I had the same on my '00 Tundra and they lasted 15 years. I did drive it on the beach on a few occasions and they remained intact. Yet, I must admit, if you'really going to do some "real" four wheeling in the woods or over rocks the OEM guards will last just that day! I can definitely see these ripping off because they aren't flexible.
  15. May 14, 2016 at 5:52 AM
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    Flappy or not ... if you're wheeling and it gets caught between the tire and rock/dirt/etc. it's just going to rip right off. Moving forward won't be the problem, it's when you partially clear an obstacle and roll back and then your tire can pinch the flap against something. Try to get out of that spot, and off comes the mud flap, flappy or not.
    JoeyDel likes this.
  16. May 14, 2016 at 6:08 AM
    JoeyDel
    JoeyDel Well-Known Member
    Joe
    South Jersey
    2003 Off Road AC and '16 AC Sport Silver Sky Metallic
    I agree, also when backing out of a spot once you realize, maybe I should not keep going forward......:eek:
    JoeRacer302[QUOTED] likes this.
  17. May 14, 2016 at 6:09 AM
    JoeRacer302
    Joe
    Pasadena, CA
    Lol, yup, those moments when you realize you may have bitten off a bit more than you can chew ...
  18. May 14, 2016 at 10:02 AM
    MamaBear
    MamaBear Active Member
    Sharon
    Greater Toronto Area, (Thornhill), Canada
    2016 Toyota Tacoma Inferno V6 DCSB TRD Sport 6 Speed Manual Transmission w/ Upgrade Package
    OEM Roof Rack, Trifold Tonneau Cover, Bed Mat, Spare Tire Lock, Film Protection - Hood, Front Bumper, Side Mirrors.
    I'm waiting to get delivery on my weathertech mud flaps, was told by weathertech.ca that they are out of stock will take 3 weeks for delivery. It would of been nice if they had told me this prior to ordering them, nothing to indicate this on their web site or order confirmation email.
  19. May 15, 2016 at 1:27 PM
    Hayseed
    Hayseed Well-Known Member
    Dave
    WV
    2016 Tacoma sport TRD
    Clazzio vinyl seat covers, decal, auto drop running boards, chrome rear letters chrome rear tail light bezels and bed release cover. Painted grill, polished aluminum cover over black grill in sport hood. Polished alum. wheels. Form fitting flor mats
    I have a white truck, I hate putting black things on a white paint job. They tend to really stick out. I have searched for white flaps but have only so far found the only white application to be a Cadillac Escalade and maybe the Buick SUV. Has anyone painted their flaps to match their truck color? If so can you share your technique and steps of doing so, and how they have held up? Thanks
  20. May 15, 2016 at 2:19 PM
    JoeRacer302
    Joe
    Pasadena, CA
    I just don't see white flaps holding up too well ... they're going to be constantly having stuff from the road thrown up into them.
