Mud flaps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VanGo3, Mar 22, 2020.
  1. Mar 23, 2020 at 7:17 AM
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    Not all Chinese stuff is junk. 30 years ago I bought a 99 cent bamboo back scratcher made in China. I've used it every day since then and it's always performed flawlessly. Would buy again.
  2. Mar 23, 2020 at 8:00 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    Not trying to crap on your post but ...
    The Weather Techs and OEM have approximately the same clearance. I measured them in 2017. I don't think they have changed since.
    I actually bought a set of Weather Techs, they had a defect so I returned them and bought OEMs.
  3. Mar 23, 2020 at 8:14 AM
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    I was actually curious about this as well. The OEM's tend to hold stuff, which for me necessitates kicking to "empty" them. Was wondering if Weathertech had this same issue
  4. Mar 23, 2020 at 12:27 PM
    LongDistanceTaco
    LongDistanceTaco Well-Known Member
    Geoff
    California
    I used the rallyarmour universals and drilled my own holes. Its a little bit of a pain, but they are quality. They are extremely flexible so setting them down on a rock does nothing. If you don't want to drill your own holes the RokBlokz are probably the next best thing
    No coating the sides with mud. Pretty much all the mud is from the tires hitting the mud
  5. Apr 29, 2020 at 6:20 AM
    pultaco12
    pultaco12 Active Member
    2020 TRD OR 4x4 DCSB
    I just installed the oem flaps, and have a loose bolt.
    Its one of the front flaps, the bolt that goes in the bottom hole. After the install, when I wiggled the flap, that bolt would pop out a bit. I squeezed some silicon in the hole, and also on the bolt/washer so it couldnt fall out if it loosens again. Wiggled, and that bolt will still come out about 1/4 inch.
    I could epoxy the threads and put it in, or go with a larger stainless screw? Any suggestions? Thanks!
  6. Apr 29, 2020 at 6:25 AM
    Sandman TRD
    Sandman TRD Well-Known Member
    Indy
    2018 Black DCSB TRD Off Road 4x4
    Has anyone successfully ran OEM flaps with larger wheel/tire set ups? Is there any modification you can do to the flap to prevent rubbing when running a more aggressive wheel offset?
  7. Apr 29, 2020 at 6:31 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Identical to what I'm running, these are great flaps and have some adjustability.
    Rekgen make flaps for Subies :thumbsup:
    Might have lost/cracked the plastic insert that the "bolt" threads into. It happens.
    Best mod is to remove them. They're stiff, so if you rub the tires will win over the mudflaps. No use in risking stripping out the bolts or breaking the plastic inserts they thread into.
  8. Apr 29, 2020 at 7:27 AM
    pultaco12
    those bottom inserts must be cracked. Of course that is the one that you can't get to the back of the insert.
    Any problems if I just don't use the bottom bolt?
  9. Apr 29, 2020 at 7:46 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    It should stay on just fine without half the bolts I would think.
  10. Apr 29, 2020 at 7:51 AM
    rkaterle59
    rkaterle59 Well-Known Member
    Bob
    Junction Texas
    2019 Tacoma SR 2.7 auto Super White
    Any thing out there for a 2 wheel drive sr?
  11. Apr 29, 2020 at 8:28 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Pretty much everything listed ...
    If you get the OEM flaps, make sure you order the ones withOUT the fender flares (unless you have the SX package)
  12. Apr 29, 2020 at 8:28 AM
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    Just get a new plastic insert for the bolt.
    CygnusX191 likes this.
  13. Apr 29, 2020 at 8:55 AM
    pultaco12
    Can anyone confirm that part number 90189-06236 is correct for the plastic thread insert for this bolt? Thanks! (Will get some ebay generics)
