Mud grapplers and the road
Discussion in '2nd Gen. Tacomas (2005-2015)' started by troublemaker, Aug 11, 2014.
  1. Aug 11, 2014 at 4:35 PM
    troublemaker
    troublemaker [OP] Well-Known Member
    Mikr
    Ontario
    V6 Manual
    Just put 33" mud grapplers on with a leveling kit. The steering kind of shimmys back and forth, on flat smooth pavement. Also the truck pulls when it hits any bumps. Chamber is .9* and caster is 1.5*. Should I try and get the caster up around 2 + to help this? Truck has factory UCA
  2. Aug 11, 2014 at 4:47 PM
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    Factory UCAs is probably your problem. May not be able to get it into good enough alignment to fix the pulling/shimmy without a uniball.
  3. Aug 11, 2014 at 5:52 PM
    MagneticTaco79
    MagneticTaco79 COLD ASS HONKY
    AARON
    WV
    Mag Grey 2012 Tacoma AC TRD Sport 4x4
    ALL KINDS OF SHIT
    How much of a "leveling kit" are we talkin bout? If it's floating and road walking you have a caster issue and you need to get the numbers up, again the only way to do that is UCAs. Shimmy may be from poorly balanced wheels.
  4. Aug 11, 2014 at 6:10 PM
    troublemaker
    Mikr
    Ontario
    V6 Manual
    2.5" I'm going to bring it back and see if they cant crank those numbers up a bit.
  5. Aug 11, 2014 at 6:33 PM
    MagneticTaco79
    AARON
    WV
    ALL KINDS OF SHIT
    They should be able to get it driving pretty good if your sure you are 2.5 or less. If you got the coin have the balance on the wheels checked. You didn't have any issue before lift?
