Mud Guards with 265/75/16?
Discussion in 'Wheels & Tires' started by danbow, Jun 22, 2011.
  1. Jun 22, 2011 at 12:19 PM
    danbow
    danbow [OP] Member
    Daniel
    Texas
    18 F150 Crew 4x4
    Im probably in a minority, but I like having mud guards. I want to get some goodyear duratechs or BFG A/T's, but may go to the next size up.
    I'd rather get the duratechs, but I believe the closest size is 265/75/16
    I have a 2 in lift in the front and rear TSB
    Will I have to lose the front mudguards?
    Thanks
  2. Jun 22, 2011 at 12:21 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    I have no rubbing on my mudflaps with 265/70/17 MT's ( same size tire )
    Even with the stock suspension before I installed my lift it was no problem
  3. Jun 22, 2011 at 12:24 PM
    danbow
    danbow [OP] Member
    Daniel
    Texas
    18 F150 Crew 4x4
    thanks!
    I may actually go to a 1.75 in front with bilstiens to get a slight rake to front, good to know they will fit regardless
  4. Jun 22, 2011 at 12:35 PM
    OZ-T
    Peter North
    British Columbia
    Some people has said they had a bit of rubbing , but even with the wheels turned at their closest , I still had 3/4" of clearance .
  5. Jun 22, 2011 at 1:09 PM
    danbow
    danbow [OP] Member
    Daniel
    Texas
    18 F150 Crew 4x4
    hmm... i have heard that the duratracs run a little large, I wonder if that's what they are talking about... but if you still have 3/4 clearance with m/t's... food for thought
  6. Jun 22, 2011 at 1:10 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    I have no lift, stock PreRunner, and I have no rubbing. Don't know if that helps at all in your decision.
  7. Jun 22, 2011 at 1:30 PM
    danbow
    danbow [OP] Member
    Daniel
    Texas
    18 F150 Crew 4x4
    are you running duratracs or BFG's?
  8. Jun 22, 2011 at 1:35 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Sorry... BFG's
