Mud stained frame
Discussion in 'Detailing' started by Ellocotaco, Aug 30, 2013.
  1. Aug 30, 2013 at 11:35 AM
    Ellocotaco
    Ellocotaco [OP] Active Member
    Virginia
    14 MGM DCSB 4x4 TRD Sport V6 Auto 94 XCab SAS
    I'm buying a 2006 tacoma this sunday & the guy used ut as his hunting truck. The body & interior are really clean, but the frame is dirty looking. Like you can tell it's been in some mud. Any ideas or experiences to get it back to black. Almost factory. Besides the ol wire brush & black spray paint.
    Thanks
  2. Aug 30, 2013 at 4:21 PM
    lasllc
    lasllc Wait. . what’s wrong here
    Southwest RedRocks
    13 SuperWhite DCSB Sport TRD
    SnugTop Super Sport, BedRug mat, Redline Tuning hood lifts, LED interior lights, 3D carpet protectors.
    Pressure wash entire underbody, on a rack if possible, to see what you have to work with.
    There are several products (chemical guys, griots garage ) that market underbody back to black sprays. But there needs to be something to work with. Otherwise you are in for a restoration project.
  3. Aug 30, 2013 at 5:16 PM
    Ellocotaco
    Virginia
    I'm sure the frame is in really good shape & . I just like a clean black frame. I'll attach a picture where you can kind of see the dirty frame
  4. Aug 31, 2013 at 4:43 PM
    lasllc
    Southwest RedRocks
    Well, surface rust is surface rust; it will never go away without proper prep. If you just want it clean looking, pressure wash, wire brush as much as possible, rustoleum flat black. It will always have that sort of brownish black color after a couple of days but it will be clean and it will retard the rust to a certain extent, but you will need to keep after it.
    Don't forget that the frame is a c- section with the open portion to the inside. Mud will pack up,in there and it is hard to see or get to from the outside of the vehicle, ie. pressure washing form the wheel wells, you need to be spraying from the center line toward the outside, that's why having it on a rack is best, but rarely possible.
  5. Aug 31, 2013 at 5:01 PM
    Ellocotaco
    Virginia
    Okay I appreciate it
  6. Sep 4, 2013 at 7:20 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    I like to use the satin black grill paint its not real shiny and doesn't start turning chalky looking after a couple months like flat paints. Also mud doesn't really stain it to much either.
  7. Sep 5, 2013 at 9:24 AM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    If your going to go thru the trouble of wire brushing POR 15 it much better than rustoleum
