Mud Tire Question
Discussion in 'Wheels & Tires' started by andycass, Aug 30, 2010.
  1. Aug 30, 2010 at 10:55 AM
    andycass
    andycass [OP] Well-Known Member
    Andrew
    New Orleans
    2012 DCLB TRD Sport
    17 inch FN FX Pro Wheels, 3inch Toytec Adjustable coil-overs w/ rear AAL, OEM Roof Rack, Pioneer double-din in dash, Two Pioneer 10 Inch subs with custom box behind rear seat, HID Hi/Lo and fogs, FLowmaster 40 single in dual out. Weather Tech floor mats, LED Dome/Map lights, Cover Kings Camo seat covers,
    I have stock 265/70r/16 on my 04 2wd prerunner and i want to know if 305/70/16 would look bad without a lift kit
  2. Aug 30, 2010 at 10:56 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Yes and you wouldn't be able to fit em anyway :eek:
  3. Aug 30, 2010 at 10:56 AM
    98tacoma27
    Ben
    Not Beech Creek
    It would look really bad because they won't fit............with out a lift and aftermarket tires or spacers.
  4. Aug 30, 2010 at 10:56 AM
    ColtsTRD
    Scott
    AZ
    x10000000000
  5. Aug 30, 2010 at 10:57 AM
    98tacoma27
    Ben
    Not Beech Creek
    What he said
  6. Aug 30, 2010 at 10:58 AM
    andycass
    Andrew
    New Orleans
    2012 DCLB TRD Sport
    alright cool...if i want to get a bigger size tire what would you suggest ?kind?
  7. Aug 30, 2010 at 10:58 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    265/75/16 would be the max you could go without lifting.
  8. Aug 30, 2010 at 10:59 AM
    ColtsTRD
    Scott
    AZ
    I know your thinking that the tire would only be wider and not taller but with Metric sized tires thats not the case...a 305/70 is wider and taller than what you have...a big difference for sure!
  9. Aug 30, 2010 at 10:59 AM
    ColtsTRD
    Scott
    AZ
    this :)
  10. Aug 30, 2010 at 11:01 AM
    andycass
    Andrew
    New Orleans
    2012 DCLB TRD Sport
    alright i am waiting to put my rough country 2.5" suspension in also....just trying to figure out what would look good
  11. Aug 30, 2010 at 11:01 AM
    ColtsTRD
    Scott
    AZ
    I have a 3" lift and I run 265/75/162 still...
  12. Aug 30, 2010 at 11:02 AM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    I have a 3" lift and run 315/75/16 :anonymous:
  13. Aug 30, 2010 at 11:02 AM
    ColtsTRD
    Scott
    AZ
    Can't go wrong with the BFG All Terrains and their KM2 Muds :D
  14. Aug 30, 2010 at 11:04 AM
    andycass
    Andrew
    New Orleans
    2012 DCLB TRD Sport
    alright thanks ill post a pic once i get my lift on
  15. Aug 30, 2010 at 11:04 AM
    ColtsTRD
    Scott
    AZ
    lol! That looks mean though! The only reason I got the 265s was because the stock wheels i was running weren't back spaced enough for a wider tire...I was rubbing like hell on the UCAs and I refused to run wheel spacers...I'm stepping up to either 285s or 295s when these tires wear out :)
  16. Aug 30, 2010 at 11:08 AM
    98tacoma27
    Ben
    Not Beech Creek
    255/85-16 FTW
