mudding issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by DaytonLax14, Mar 26, 2010.
  1. Mar 26, 2010 at 1:58 PM
    DaytonLax14
    DaytonLax14 [OP] Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    I took my tacoma mudding today after school with some friends. After about 20 mins or so, I had to go. As I was leaving, I lost a very significant amount of power in my truck all the way until it wouldn't go anywhere anymore. I got out and popped the hood to see if anything obvious was wrong, but everything looked fine. I tried starting it a couple of times, but the motor would run really rough and then shut off. After about 10 minutes, I started the motor again, and it all seemed to run just fine. I just drove it home and it seemed to run perfectly. Any thoughts?
  2. Mar 26, 2010 at 1:59 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    You may have sucked some water or mud into your intake or something :notsure:
  3. Mar 26, 2010 at 2:00 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    thats my guess as well. Anytime super moist air get's in it can cause issues.
  4. Mar 26, 2010 at 2:01 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I think i read somehting similar to this just a few days ago. something about his distributer cap coming un done or water in it..somthing along those line...sorry I cant really help much :notsure:
  5. Mar 26, 2010 at 2:03 PM
    DaytonLax14
    Corey
    Ohio
    Hmm okay. There was some water/mud on the airbox where the air filter is, so maybe that was what caused it. I did the elbow mod, so that hole on the side of the air box is open. Maybe the water got in through there? Is it anything to worry about right now since the truck seems to be running fine?
  6. Mar 26, 2010 at 2:04 PM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    just be happy you didnt hydro lock it up
  7. Mar 26, 2010 at 2:04 PM
    snowgod06
    Rob
    06 Access Cab
    You should be ok, but i would just change the oil and check/change your air filters.
  8. Mar 26, 2010 at 2:13 PM
    danbow
    danbow Well, known member
    Daniel
    Wichita Falls, TX
    09 DCSB TRD OR 4x4
    Scratches and Dents
    x2
  9. Mar 26, 2010 at 2:17 PM
    DaytonLax14
    Corey
    Ohio
    what does it mean to hydro lock it up
  10. Mar 26, 2010 at 2:25 PM
    mpleitez
    mpleitez Well-Known Member
    valencia
    08 tacoma 4x4
    ARB locked front and rear URD MAF Calibrator 3 in. lift Icon coil overs front Icon rear add a leafs airbags AFE stage2 si cold air intake DT Headers 02 sensor URD y-Pipe URD turbo Muffler
    Hydro lock means you might neeed a new block. I hydro locked mine end result new engine:confused: i would remove plugs start it up and let all the stuff in there shoot out then change your oil a few times to make sure everything is ok.
  11. Mar 26, 2010 at 2:31 PM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road SR5 Impulse Red
    5100's @ 1.25", Scangaugae II, deck plate mod w/AFE Pro Dry S filter, grey wire mod, alarm mod, defrost w/o compressor mod, de-badged, 17" sport wheels powder coated black, 1" B.O.R.A. wheel spacers, 265/70/17 Cooper Zeon LTZ's, sockmonkey beside decals.
    off topic but are you coming to the NKY meet next month? hope you can come on one of the dates we have. links in my sig
  12. Mar 26, 2010 at 4:55 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Hydrolock is when water enters the cylinders and because water can't compress as the piston goes up something gives such as a connecting rod. It can be very very expensive to fix and is a major repair. This is one reason why you see vehicles with snorkels.
  13. Mar 26, 2010 at 9:24 PM
    DaytonLax14
    Corey
    Ohio
    so how do guys go mudding and such without getting water in the pistons/hydro locking it up?
  14. Mar 26, 2010 at 9:26 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    that pretty much sums it up :cool:
  15. Mar 27, 2010 at 1:24 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Yes. Just no the trucks limits with water. Dont go threw anything to deep to suck up water. And if you do hydro lock it do not try starting it if it dies, wait untill you can pull the plugs and get the water out and change the oil.
