Muddy Boots / Small Brake Pedal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wolftree, Sep 6, 2012.
  1. Sep 6, 2012 at 5:03 AM
    wolftree
    wolftree [OP] Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    I was confronted with often having muddy boots while trying to apply my brakes. The brake pedal on my 2011 Tacoma is small. I sought aftermarket solutions. While many replacement pedal pads are nice looking, none were any larger or offered a clear advantage over the stock pad. None were cheap either.
    I was about to have a oversize custom brake pedal machined from 3/8 aluminum by having slots milled across it when I came onto "Slip Resistant Metal Flooring". The metal I chose is similar to a 80 grit surface. I cut the metal into 3"X6" and merely drilled two holes through the aluminum and the steel brake pedal. Two 10X32 screws and nylock nuts hold it firmly in place.
  2. Sep 6, 2012 at 5:22 AM
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    keep a clean shoe in the truck?
  3. Sep 6, 2012 at 5:22 AM
    Squisha
    Squisha Well-Known Member
    Westminster, CO
    99 Taco Reg Cab 4x4
    Maybe your feet are too big. :D
    Pics?
    I'd be concerned about the oversize pedal catching on something.
  4. Sep 6, 2012 at 5:52 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    pics of the pedal and muddy boots as per mob-spoken forum rulez
  5. Sep 6, 2012 at 7:26 AM
    wolftree
    Rick
    Ohio
    I have driven several hundred miles since installing the new pedal, there is no interference and you can cut or make it any size you wish. I started with 3X6 with the idea I might need to trim. I have not found the need or reason to.
    I use my truck as a truck, I am not planning on carrying another boot so as to keep it tidy. I am merely encouraging everyone to think beyond what the aftermarket suppliers offer and build what you need.
  6. Sep 6, 2012 at 8:08 AM
    PaintDrinkingPete
    PaintDrinkingPete Well-Known Member
    NoVA
    2012 4x4 TRD Sport DCSB
    Isn't the brake pedal in the automatic transmission Tacomas already oversized??? I think it's about twice the size of a normal brake pedal.
  7. Sep 6, 2012 at 11:04 AM
    wolftree
    Rick
    Ohio
    On mine it was about 2"x3-1/2"
  8. Sep 6, 2012 at 3:18 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I wonder if the issue is more the boots than the pedal being small? I use hip waders to get the boat back on the trailer and i've had a couple times when i'm on the brake and gas pedal at the same time...quite the ass pucker! Rather than take the chance i never get in the truck with them on now. Those pedals are close enough as it is!! :eek:
  9. Sep 6, 2012 at 4:34 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    This is going to turn into the thread a few days ago about the guy that kept getting tickets because he couldnt remember to turn on his headlights....
  10. Sep 6, 2012 at 5:44 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
  11. Sep 6, 2012 at 6:31 PM
    wolftree
    Rick
    Ohio
    Well, the whole story is that I am a right leg amputee and use a left foot accelerator pedal and also brake with my left foot. Nor do I have toes on my left foot, so often the "toe" of my boot would strike the vertical bar of the brake pedal before the ball of my foot hit the pedal. This did not allow good pressure to be applied to the pedal. So I wanted and made an oversize brake pedal. I work construction, job site mud is VERY common.
    I am able to adjust the height of the accelerator pedal so that it is lower in height than the brake pedal, avoiding having my foot on both at the same time. Actually, I have less "Snags" now that I have the new brake pedal than before.
  12. Sep 6, 2012 at 6:49 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Makes much more sense now. Good for you in finding a working solution to the issue, I must say I admire how some people like yourself overcome difficulties like this. Seriously, and sincerly. :thumbsup:
  13. Sep 6, 2012 at 6:51 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This
    I would have thought you would have a bigger issue with the throttle
    Edit : just saw your post about your throttle , nevermind
  14. Sep 6, 2012 at 7:41 PM
    wolftree
    Rick
    Ohio
    Oz, The Accelerator pedal is pretty simple in design. I did have block of steel 3X10x1/2 cut into a "L" shape for mounting the accelerator pedal in this truck. I used two holes in the re-enforcing rib under the drivers feet to mount the block. I did not have to drill through the floor. The holes are already there.
    I chose to make a thread about the brake pedal for anyone desiring an oversize brake pedal, for whatever reason. The Tacoma's flat instead of convex pedal easily lends itself to this.
  15. Sep 6, 2012 at 7:48 PM
    OZ-T
    Peter North
    British Columbia
    :thumbsup:
  16. Sep 6, 2012 at 9:34 PM
    PaintDrinkingPete
    NoVA
    Exactly, the original post makes much more sense now.
    First of all, let me say good for you for taking matters into your own hands and overcoming your physical obstacles. I may have both of my legs, but I do understand that sometimes you have to adjust the world because it won't adjust for you.
    Having said that, when I first read the post I had little sympathy -- as someone who has always owned manual transmissions by choice, it seemed strange to hear an automatic transmission owner complain of "small brake pedal". I may prefer the manual trans, but driving in winter boots can be a challenge sometimes with the 3 smaller pedals so close together.
    Also, you should post some picks of your mod; I think some folks may find it useful!
  17. Sep 7, 2012 at 4:38 AM
    wolftree
    Rick
    Ohio
    This is the first truck I have had to do this on. I think the angle/location of the vertical arm on the brake pedal was a large part of my need to do something just a little different. But, I felt a need to address it and change it. The oversize pedal lets my foot strike to the left of the vertical bar now.
    I will have to work on getting a digital camera, then take some photos of both the accelerator and brake pedals.
  18. Sep 7, 2012 at 6:34 PM
    Squisha
    Westminster, CO
    99 Taco Reg Cab 4x4
    Just catching up on the thread, Wolftree.
    So you had what I would call significant mods to your controls to begin with. Interesting!
  19. Sep 7, 2012 at 11:20 PM
    wolftree
    Rick
    Ohio
    Squisha, Yes and no. The left foot pedal is a simple crank that uses two bolts to mount it to the floor.
    There is an example in my "Gallery" just under the number of posts.
