Mudflap compatibility with aftermarket fender flares
Discussion in '4th Gen. Tacomas (2024+)' started by Phantom100, Jan 6, 2025.
  1. Jan 6, 2025 at 1:32 AM
    Phantom100
    Phantom100 [OP] Active Member
    New York
    2024 TRD OR black
    Are aftermarket fender flares such as rough country or NYTOP or Seibon compatible with mudflaps?
    rough country ones dont seem compatible. not sure about NYTOP . Any verifications are appreciated.
    4th gen TRD OR crew cab non-hybrid
  2. Jan 6, 2025 at 4:35 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    don't think its an issue....
    The simple flaps like Rokblokz or Ark dont have contoured outside raised molded edges that contours the fender flare, so theres options...
    pretty sure the mf mounts to the actually fender pinch / inner fender well area & not the actual flare...
    so I cant see a reason why a mf won't work, if you pick the right mf...
  3. Jan 6, 2025 at 10:07 AM
    Phantom100
    New York
    2024 TRD OR black
    NYTOP said it wont be affected. Thanks
