Mudflap fasteners
Discussion in '2nd Gen. Tacomas (2005-2015)' started by leveltwo, Jan 5, 2012.
  1. Jan 5, 2012 at 9:09 AM
    leveltwo
    leveltwo [OP] Well-Known Member
    I know Ive seen this before but searching left me clueless. How do you remove the mudflap fasteners? i tried with 2 screw drivers on either side of the fastener and the top just broke off, leaving it still fastened in...:confused:
  2. Jan 5, 2012 at 9:12 AM
    johnanm
    johnanm Well-Known Member
    Up
    2011 Double Cab 2.7L Prerunner
    Bilstein 5100 @ 1.75" front shocks on stock springs, AFE ProDry drop-in, white DTRLs, Sylvania ZXE headlamps, DeeZee bed mat, Tailgate hose clamp mod, cheap snap craigslist tonneau, Weathertech vent visors, secondary air filter removed, Class III hitch
    There's a little slit on the edge of the top of the fastener to slip the screwdriver edge in and pop it up, you can stick the tip of the blade in about 2mm if I recall. If that isn't working for you I'd go with needlenose pliers and pull the middle straight out, esp if the top came off. GL
  3. Jan 5, 2012 at 9:25 AM
    leveltwo
    thats what i did, maybe since they are cold it snapped... ill try again.. thanks! rep!
  4. Jan 5, 2012 at 9:38 AM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    I had my best luck just pulling on the flap.
    Any pry/direct pull resulted in a broken push rivet top.
  5. Jan 5, 2012 at 9:41 AM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Mine had two different types on it, one was the type that requires the center to be pushed in first, the others just lift up like you were saying. Both are complete crap and will break easily, after they get road grime/dust/dirt in and on them, it doesn't let them slide. Seems those fasteners can be had for not much money.
  6. Jan 5, 2012 at 9:58 AM
    Large
    Large Red
    Kinda hard to splain but the dull end of a screw driver is too "fat" I guess u could say.. I used my pocket knife and it worked good.
  7. Jan 5, 2012 at 10:00 AM
    Sunner
    Sunner Well-Known Member
    I gave up after snapping two of them so I just kicked the flaps off after that. Ill just buy some if I ever want to put them back on.
  8. Jan 5, 2012 at 7:52 PM
    leveltwo
    those things are crap.. only broke one more though, and got the rest off..
