mudflap line-yet again
Discussion in '2nd Gen. Tacomas (2005-2015)' started by longbow, Jul 26, 2008.
  1. Jul 26, 2008 at 8:14 AM
    longbow
    longbow [OP] I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    I know most of you won't give a rats butt about this, but some I guess will.
    This has bugged me since I lifted the truck, plus I also used it below the door seals for added protection.
    I wrote about this before and tried it out, if you are interested in any of this tape, (it is pin-strip tape) and your ride is silver and want to try it out give me a yell and I will send you enough to do front, back or both.
    I have enough to do around 25 trucks, plus I am going to keep some extra.
  2. Jul 26, 2008 at 8:15 AM
    longbow
    Bill
    Indiana
    before
  3. Jul 26, 2008 at 8:16 AM
    longbow
    Bill
    Indiana
    after
  4. Jul 26, 2008 at 8:18 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I give a rats ass, though I don't know where I can find one.
    What kind of tape is it? I like that idea.
  5. Jul 26, 2008 at 8:25 AM
    longbow
    Bill
    Indiana
    it is 3M tape, about and inch wide. After I did the door seal I used the back of the tape as a template, to trace for the flap area.
    Once installed I pulled the clear protective coating off the tape, I was surprised how it blended well. TRUE you can see it, but heck it does not look hit and miss with the ond line.
    Clean in my book.
  6. Jul 26, 2008 at 11:38 AM
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    Bro send some my way! Is this tape anything like the silver vinyl sticker I use on my headlights? If so, I've got some of that. But never thought of doing that. SWEET! I hate that wear spot. Something so simple and yet it hasn't been fixed since the truck came out in 2005. WTH?
  7. Jul 26, 2008 at 3:03 PM
    longbow
    Bill
    Indiana
    Have not seen the pic's of the headlights, (any pic's here?) but I don't believe so. I have had this tape for some time now, safety stored away.
    Send me an e-mail wmitchelljr@comcast.net with your address and I will get it out to you Monday.
    Do you need both front and back?
  8. Jul 26, 2008 at 9:42 PM
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    These vinyl stickers! You think they are similar? I've got a little of this left. Never did I think about cutting them into strips and using them for that purpose. I'll totally send you an email in a few. Thanks bro.
  9. Jul 26, 2008 at 10:45 PM
    ERdept
    ERdept Well-Known Member
    Longbow,
    I have posted a question about rubber mud flaps twice.
    It is an important topic to me since I'm changing to them.
    May I please have some tape?
    Here I am........
    Cliff C.
    PO Box 335
    Bellflower, CA 90707
    BTW, what does your line, "Sabot up" refer to.
    I'm thinking two things immediately, either a tank's sabot round, or a shotgun sabot round.
    I have a Benelli M4 which shoots the latter, I want to bust door hinges and locks down with. he he he.
    Do you think the black line could be eliminated by rubbing compound?
  10. Jul 27, 2008 at 11:40 AM
    longbow
    Bill
    Indiana
    maybe and maybe not, the tape I have like stated before is 1" wide. I do know that once you pull the backing off and place it, it has another protective film on the outer side you remove.
    After installation, I put a coat of wax over the area (plus a little more) and it seemed to fade away.
    Give what you have a shot, if it works SUPER if not I still have this here.
  11. Jul 27, 2008 at 11:45 AM
    longbow
    Bill
    Indiana
    As for the Sabot term it refers to a tank round. After the call for a certain round my loader would say "Sabot Up", and or "Heat Up".
    As for the tape, it is coming your way and I will mail it out tomorrow. Would you like enough for front, back or both?
  12. Jul 27, 2008 at 11:50 AM
    longbow
    Bill
    Indiana
    Forgot to add this, I tried to use rubbing compund and a number of other products. Problem was/is in areas where the clear coat was messed up, no issue worked most of it out.
    But the other areas, the flap went all the way thru to the actual flare material which is a blackish color.
  13. Aug 3, 2008 at 7:17 PM
    longbow
    Bill
    Indiana
    Got the package I sent you back, stating "undeliverable". My guess it is the mail carrier. I check the address and everything is correct.
    I will send it out again, but us the UPS shop here.
    If I get any tracking info I will send it PM.
