Mudflaps Rubbing!
Discussion in 'Wheels & Tires' started by HBOMB, Oct 31, 2018.
  1. Oct 31, 2018 at 6:21 AM
    HBOMB
    HBOMB [OP] Well-Known Member
    Massachusetts
    2011 Tacoma TRD Sport, 4WD, DCLB, Super White
    Just mounted a new set of TRD rims with Nitto Ridge Grappler 265/70/R17 tires. Looks so sweet but when I turn, the tires rub on the front mud flaps, ughhh! I don't want to take the mudflaps off as I would like to maintain the paint job. Should I cut the area it rubs on out with a Dremel (essentially a couple of small squares) or use a heat gun to soften up those areas and flatted out with a hammer? I know many of us have this issue running these size tires so any suggestions would be helpful. Pics help too.
    BassAckwards likes this.
  2. Oct 31, 2018 at 6:22 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Use a heat gun and push the portion back that is rubbing. I took a Dremel and cut squares out of my factory mud flaps to clear my 295/70/17s. Anything is possible!
    You can also take a file and knock some of the material off where the contact is. I've done this as well
