Mudweiser's ACLB Pyrite Mica Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Mudweiser, Aug 15, 2015.
  1. Aug 15, 2015 at 6:43 PM
    Mudweiser
    Mudweiser [OP] Member
    Ft. Custer, MI
    2011 TRD Sport Access Cab in pyrite mica.
    Current mods:
    -Projector headlights
    -GT Radial Aventuro tires
    -MB TKO wheels
    -Westin winch grille guard
    -Billet grille
    -Warn VR10000 winch
    -Hella 500 Black Magic lights
    -Smoke fog lights
    -Arrow antenna (broke off after a month on tiny branches)
    -Optima yellow top
    -Blue Sea fuse box
    -Taillight guards
    -Power Acoustic head unit (wish I could return)
    -LED bed lights
    -Tonneau cover
    -Stebel Nautilus horn (removed and returned)
    Pics coming:
    -LED light bar
    -Neoprene seat covers
    -LED Reverse light
    Future mods:
    -CAI
    -Bushwacker pocket fender flares
    -Black diamond plate rocker panels
    -Spray on bed liner for the underbody
    -Remote start (if I can EVER get Geek Squad to schedule an install appt)
    -Plastidipped emblems
    -Auto up/down window module
    -Maybe more USB ports. I bought one before I got the head unit with one installed.
    This is the most stock photo I have, but I had already added new wheels/tires and projector headlights.
    -The projector headlights were from eBay and I did have to seal the seams on one to prevent fogging (you can see it in some of the photos before I caulked), but overall I'm happy with them. I had smoke headlight covers on my 4runner and those are pain taking off to drive at night.
    -Tires: 265/75r16 GT Radial Adventuro MT
    -Wheels: MB Wheels TKO
    -Westin Sportsman winch grille guard. The part that holds the winch has two frame mounting points on each side and thick frame reinforcement brackets. Also a spot to set a beer when working on the truck.
    -Billet grille set from eBay. Many billet grilles on eBay say they are only for 2005-2010. The grille on the 2011 is slightly different (it has a solid center piece whereas the earlier models have a split center piece), but if you're cutting it all out anyway it doesn't matter.
    -Hella 500 Black Magic lights that I had on my previous Toyota.
    -Smoke fog lights. The one on the right is stock to show the difference.
    -Low profile bug shield in the second pic. If it ever breaks I will be going back to the standard height bug shield. This one keeps bugs off the hood, but not the windshield, and that's half the point.
    -Arrow antenna. For a little while I had a shorty bullet antenna, but that was crap. I could only pick up 3-4 stations and I live city where several dozen stations are available.
    -Stick on window vent visors.
    -Optima Yellow Top
    -Blue Sea 5028 aux fuse block w/ 80a breaker.
    -Power Acoustik PD-342B double din head unit. Really disappointed.
    -Pilot aircraft switch panel mounted on the overhead console. This will run my front off road lights and I replaced one regular switch with a 3-way switch for my future reverse lights.
    -LED bed lights. The switch is inside the little tool compartment. I only installed one side to see how bright it would be and if I even needed them on the other side. I don't think I do.
    -Warn VR10000.
    -American Tonneau's tonneau cover. I really wanted the BAK tonneau for the extra bed space and one hand opening for the rear, but I just could justify the $800 price tag. This $250 cover comes off in a few minutes in the rare event I need the entire bed.
    -New drop hitch. The Tacoma sits a little higher than my '01 4runner and the angle was so high, my little trailer wouldn't fit on the ball with my previous hitch.
    -Stainless steel taillight guards.
  2. Aug 15, 2015 at 6:44 PM
    Mudweiser
    Ft. Custer, MI
  3. Aug 20, 2015 at 5:43 PM
    Mudweiser
    Ft. Custer, MI
    If anyone is thinking about a Stebel Nautilus horn, I tried it and wasn't about to waste $40 on a horn that sounds no louder than stock and is just higher pitched (whether that's better or worse, I don't know). Here's the video of the stock horn vs. Stebel's.
    Maybe on a motorcycle it sounds loud and that's why it has such good reviews. Still searching for that super loud horn that doesn't sound like a train and doesn't require an air compressor.
  4. Feb 10, 2016 at 7:14 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    Nice looking truck :thumbsup: how do you like your smoke fogs? I have one broke, and have to get a new set, smoke vs. yellow? smoke looks good :cheers:
  5. Feb 10, 2016 at 7:52 AM
    Mudweiser
    Ft. Custer, MI
    Thanks! I like the smoke fog lights. It's only a slight tint, so they're still plenty bright. I got them on eBay for around $40. They came with new bulbs and a wiring harness, which I didn't need since I had factory fogs.
    JimboAnz likes this.
