Muffler bearing gone bad
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jandrews, Dec 5, 2012.
  1. Dec 5, 2012 at 12:23 PM
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    While you're under there checking on the injector pan rotary lockout nut, keep an eye out your Johnson Rod leaking from its tip. Sometimes you can give it a few strokes with your hand and it'll clear it all out, but every once in a while it gets stuck and needs the help of a professional (they aren't cheap, though).
  2. Dec 5, 2012 at 12:25 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    You gotta stay on top of these things. Parts wear out fast without proper maintenance!
  3. Dec 5, 2012 at 12:28 PM
    mjp2
    NJ
    While you're under there it's a great chance to turbo your rig!
  4. Dec 5, 2012 at 12:29 PM
    Razgriz
    Razgriz wtf am i reading
    San Jose, CA
    2013 White TRD 4x4
    I want turbo exhaust...
  5. Dec 5, 2012 at 12:29 PM
    Namyo
    Namyo -
    :eek:
    :eek::eek:
  6. Dec 5, 2012 at 12:35 PM
    Phil5393
    Phil5393 Well-Known Member
    Phil
    Long Island, New York
    TRD Sport
  7. Dec 5, 2012 at 12:53 PM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    i took my Muffler bearings outs years ago. im running a statick idle kit now, more flow better sound and way less worry about replacing expensive parts.
  8. Dec 5, 2012 at 12:55 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    you guys should see the muffler bearings guys run here
    sticks out so far under the truck, I've seen them rub speed bumps
  9. Dec 5, 2012 at 1:08 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    This is why I bought the extended warranty for my truck and only let the dealer service it. Silly people doing their own maintenance
  10. Dec 5, 2012 at 2:07 PM
    jandrews
    jandrews [OP] Hootin' and Hollerin'
    '09 FourDubDee TRD OR
    Think ill get two new ones so I have a trail spare.
  11. Dec 5, 2012 at 2:10 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You'll need 7 if you want a spare... A simple search would have shown you that there is one muffler bearing per cylinder. Some people just can't be helped... :facepalm:
  12. Dec 5, 2012 at 2:15 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Consider removing your muffler bearing completely and going with an o-pipe straight off the block. The torque gains are amazing.
  13. Dec 5, 2012 at 2:18 PM
    Junya808
    Junya808 Well-Known Member
    Maui, Hawaii
    2012 Tacoma OR 4X4
    Suspension Fronts: Icon Coil Overs Total Chaos UCA Rear: Icon shocks with resivior Icon aal. Interior: Wet okole seat covers Led map and dome lights Lighting: Slimcubby hid 6000k Slimcubby hid fogs 3000k Led parking lights Led license plate lights Led Switchbacks Misc. Mods Rear diff. Breather Mod
    I believe Nissan's muffler bearing might work too.
  14. Dec 5, 2012 at 2:18 PM
    rctoy
    konstantenos
    Pocatello Idaho
    my statick idle kit will work on a 6 or 8 cyl. I did forget to mention that it needs cleaned a lot so youll spend a decent amount of time on your back getting the job done.
  15. Dec 5, 2012 at 2:23 PM
    #35
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Better than on your knees.
  16. Dec 5, 2012 at 2:26 PM
    #36
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    this, but i'm lazy so it go's 50k miles between changes.
  17. Dec 5, 2012 at 3:26 PM
    #37
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    It looks like it would - the dimensions are the same - but the spline count is different.
  18. Dec 5, 2012 at 3:33 PM
    #38
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Lold
  19. Dec 5, 2012 at 3:52 PM
    #39
    rctoy
    konstantenos
    Pocatello Idaho
    so there it is big oll statick idle
  20. Dec 5, 2012 at 3:57 PM
    #40
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    I have always been a fan of the adjustable powerband over the Turbos. allows you to dial in the right amount of power for the situation and saves fuel.
