Muffler bearing gone bad
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jandrews, Dec 5, 2012.
  1. Dec 5, 2012 at 3:59 PM
    #41
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    Is that the new closed loop system I heard about?
  2. Dec 5, 2012 at 4:00 PM
    #42
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    That's true for 1st gen Tacos. 2nd gens with the V6 have only two muffler bearings - one per cylinder bank. See parts diagram:
  3. Dec 5, 2012 at 4:00 PM
    #43
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Yep. 100% back pressure so no torque is being wasted in the low end.
  4. Dec 5, 2012 at 4:11 PM
    #44
    olouieo
    olouieo U-member
    Louis
    So.Cal
    2013 TRD Sport, MGM DCSB 4x4,
    2013 TRD Sport, MGM DCSB 4x4, Icon Stage 4, 17" KMC Addict wheels, Nitto Terra Grappler Tires 285/70-17
    It was almost impossible to remove mine I had to use a left handed srewdriver.
  5. Dec 5, 2012 at 4:32 PM
    #45
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    Yeah, 2013's have seen some changes, haven't they?
    The 2005-2011 models use a pilot wrench to get to it. Quite a bit easier, but pulling the hypoid cramdshaft out to get to it makes it an extra step over yours.
  6. Dec 5, 2012 at 4:34 PM
    #46
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Metric of course.
  7. Dec 5, 2012 at 4:37 PM
    #47
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    I saw they added a bigger johnson rod on the 2013 so the left handed screwdriver is needed. But it's only on the black trucks.
  8. Dec 5, 2012 at 4:43 PM
    #48
    KiltedRonin
    KiltedRonin Poor Impulse Control
    Ronin
    Silver Spring, MD.
    2011 access cab, MGM, leer 180.
    Muffler bearing part# B-A-1100-N is the correct one right?
  9. Dec 5, 2012 at 4:46 PM
    #49
    KenLyns
    Belly of the Beast
    Make sure you get the TSB bearing, P/N B-A-1100-N3. Mention HARSH SOUND at the service desk. Be polite.
  10. Dec 5, 2012 at 4:52 PM
    #50
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Ah, of course!
  11. Dec 5, 2012 at 4:55 PM
    #51
    Mach375
    This NEEDS to be added to the TSB thread!!
  12. Dec 5, 2012 at 5:21 PM
    #52
    jandrews
    jandrews [OP] Hootin' and Hollerin'
    '09 FourDubDee TRD OR
    I think Marlin Crawler makes an adapter plate, but I'd have to look up the part # for it.
    Re: 1 per cylinder bank: Unlikely to blow out more than one muffler bearing at any given time, even with hard wheeling.
    Good to know. Thanks.
  13. Dec 5, 2012 at 5:43 PM
    #53
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You have a few options for replacement. if your not getting rid of your truck anytime soon, you could go with an OEM MB, but keep in mind, its a good thing to also consider getting a Muffler Bearing Master Rebuild kit. This includes things that dont come with the part itself, like muffler bearing anti lube grease, and a muffler bearing calibration tool. If you are hard on your MB's, which given your pics, you are, then I would consider a ceramic MB replacement. Most are a perfect drop in replacement for OEM MB's, after they are machined to specs. MAKE SURE that you dont install the rear most MB into the front of the exhast. tHIS CAN CAUSE SERIOZ issues with the kanuter valve assembly. The front bearing has a "DE" on it, while the rear has "RP" printed.
  14. Dec 5, 2012 at 5:56 PM
    #54
    Leggo
    Newton,Ma.
    nobody even mentioned the "normal" break in period, or the "extended" break in period and the possible hazards with that whole ordeal. Is it just me?
  15. Dec 5, 2012 at 5:57 PM
    #55
    KenLyns
    Belly of the Beast
    I accidentally drained my muffler's anti lube grease trying to flush the blinker fluid system. Halp!
  16. Dec 5, 2012 at 6:05 PM
    #56
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    You didn't get you blinker fluid mix with the headlight fluid.
  17. Dec 5, 2012 at 6:06 PM
    #57
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not to worry!! Drain the remaining fluids into the tranny.
  18. Dec 5, 2012 at 6:06 PM
    #58
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats a good point. Jandrews should be informed of the hazards of an impropper break in.
  19. Dec 5, 2012 at 6:07 PM
    #59
    LDurchy
    LDurchy Well-Known Member
    Cedar Falls, Iowa
    I have had good luck with Acme brand rotate-a-lator juice. The 2000 and later vehicles require the metric blend. A mole in the labs has informed me about a new synthetic urethane plastic bearing called Healathon. It actually will heal to new build specs. It is renewed by playing bagpipes for 45 minutes within 5 meters of the parts. It is good for 10 'renews'.
  20. Dec 5, 2012 at 6:11 PM
    #60
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    You might need to send in an exhaust sample to a emission lab. Your muffler bearing is hot at 30k miles? Sounds like something else is bad.
    I had to install a turbo encabulator on my subaru. It helps my muffler bearing last longer with all that boost.
