Muffler bearing gone bad
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jandrews, Dec 5, 2012.
  1. Dec 5, 2012 at 9:07 PM
    #81
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^You came to the right place. 4MufflerParts would've ripped you off.
  2. Dec 5, 2012 at 9:09 PM
    #82
    paid4c4
    paid4c4 Well-Known Member
    Northern KY
    2015 4X4 TDR Sport, Auto Extended Cab
    I have found that if you change your exhaust system to a dual exhaust you'll get much better life expectancy from you muffler bearings. The exhaust system runs much cooler with the exhaust split between two pipes and bearings.
  3. Dec 5, 2012 at 9:14 PM
    #83
    olouieo
    olouieo U-member
    Louis
    So.Cal
    2013 TRD Sport, MGM DCSB 4x4,
    2013 TRD Sport, MGM DCSB 4x4, Icon Stage 4, 17" KMC Addict wheels, Nitto Terra Grappler Tires 285/70-17
    Thanks for all the help guys I figured out that I wasn't my MBs that was bad it was just the Loose Nut Behind The Wheel.
  4. Dec 5, 2012 at 9:18 PM
    #84
    KenLyns
    Belly of the Beast
    :eek: Hope the johnson rod wasn't impinging as a result!
  5. Dec 5, 2012 at 9:19 PM
    #85
    joes06tacoma
    Joe
    Central Coast, CA
    I noticed that Autozone is now selling water cooled mufflers.
    If you think about it, it makes total sense. All that intense heat makes the muffler bearing grease break down within a short period of time, and the bearings will cook themselves, and as we all know that increases exhaust backpressure and decreases high end horsepower.
    I'm hoping to have a little extra cash after I do my Christmas shopping. Planning to swap in one of these, run the Toyota long life coolant in it, and get away from having to repack my muffler bearing grease so damn often. Looking forward to less maintenance and a better running truck from here on out.
    Autozone, who would have thought?
  6. Dec 5, 2012 at 10:46 PM
    #86
    dantastic
    dantastic Well-Known Member
    818<->626
    2012 DCLB 4x4 BLK
    tl; dr. Is there going to be a TSB for the muffler bearings or what? Seems like everyone is having issues with them.
  7. Dec 5, 2012 at 11:09 PM
    #87
    anotherreject
    anotherreject Well-Known Member
    i got my johnson rod stuck in my muffler bearing while trying to pack new grease into the muffler bearing...any tips?
    also planning on adjusting the loose nut behind the steering wheel when i get a round tuit.
  8. Dec 6, 2012 at 1:45 AM
    #88
    Cadha13
    Cadha13 初音ミク #1 Fan, and Bacon Wrapped Hot Dog Cook
    David
    Albuquerque
    2022 TRD OR DCSB 6MT
    OEM Bed Lights
    I think you might be losing power from the loss of heat in the muffler. I suggest routing the exhaust into the radiator to prevent loss. Also for good measure, add a radiator blanket to keep warm in the winter.
  9. Dec 6, 2012 at 3:14 AM
    #89
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    Dafuq? Man i wish you guys would have posted earlyier. Mine went out atva 100000 miles and i wasnt under warrenty. Dealershit cost me 2k in parts in labor
  10. Dec 6, 2012 at 3:36 AM
    #90
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
  11. Dec 6, 2012 at 8:06 AM
    #91
    olouieo
    olouieo U-member
    Louis
    So.Cal
    Before you try the Muffler Bearing Mod I was told by my ASE Super smart mechanic who went to school to learn mechanics and stuff to use this first
  12. Dec 6, 2012 at 9:09 AM
    #92
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    ^Rip off... Pumice in the fuel will do the same.
  13. Dec 6, 2012 at 9:43 AM
    #93
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    I don't always off road but when i do i make sure i have a sham-fucking-wow
  14. Dec 6, 2012 at 10:40 AM
    #94
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    I just browsed through this thread and did any one bring up the fact that everytimeyou replace the muffler bearing a new muffler drive belt is recommended. Old bells tend to stretch and slip resulting in the pulley attached to the bearing getting hot and the heat is transferred to the inner race then to the balls before it gets to the muffler itself. Another contributing factor is unburnt hydrocarboners caused by low compression level. These unburnt hydrocarboners tend to break down the lubricant. Adding a 12 hounce can of compression at the same time the muffler belt and bearing are changed is highly recommended. Check on the can so that you get the proper PSI for your application.
    Often the unindoctrinated will replace the muffler belt tensioner, but as it is only an idoler it doesn't effect the heat of the driving muffler belt pulley or the driven pulley on the recirculating ball pump and since the ball pump is hanging out in the air it usually doesn't experience over heating and may actually benefit from extra shielding during the colder times of the year.
    And shame on you for probing a tail pipe with the Johnson rod. Using the proper tool for the job is always the best policy. Even if the johnson rod does not get stuck, repeating probing can lead to a prolapsed tail pipe extension sphincter band. Proper procedure is to procure the smoke shifter that corresponds to your particular tail pipe orientation. Left handed smoke shifter for left orientation, right handed smoke shifter for that orientation. Those with both right and left orientations will of course need to get one of each.
    I hope this sheds some light on a sometimes dark and misunderstood area of mantenance.
    Jim
  15. Dec 6, 2012 at 11:25 AM
    #95
    ssmith29440
    ssmith29440 Well-Known Member
    2012 Tacoma TxPro Trd
    A friend of mine had his muffler bearings shoot through his tail pipe and struck a little ole lady crossing the street. All the bearings hit her below the knees. Now she's wheel chair bound fot the rest of her life.
  16. Dec 6, 2012 at 11:33 AM
    #96
    silver taco
    silver taco Well-Known Member
    Los Angeles
    07 4X access cab
    Icon 2.5 ext travel, Camburg 1.25" uca's, All-pro leafs, Icon 2.5" rear shocks, LR jounce front and back, breather mod, KR Fab rear bumper, Kenwood 2m radio, All-Pro sliders, Front bumper by Surfinferno (Dylan), Glassworks fenders, 4:56 gears, gusseted spindles and coil buckets
    Dammit! Why does toyota keep adding things to compromise the reliability? The first gens dont have this problem.
  17. Dec 6, 2012 at 11:44 AM
    #97
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    first gens are worse. they use a two piece MF made in India. Those that were assembled in the USA are a little better, but still use a two piece MF.
  18. Dec 6, 2012 at 12:53 PM
    #98
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    I can't find my bearing? Where is it at? Where the plate to take of to grease it at least?
  19. Dec 6, 2012 at 1:07 PM
    #99
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    Right behind the jack shaft. Give it a few good tugs and yer good to go
  20. Dec 6, 2012 at 1:25 PM
    #100
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Find the tip of your johnson rod and it's to the left.
