Muffler bearing gone bad
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jandrews, Dec 5, 2012.
  1. Dec 6, 2012 at 2:54 PM
    #101
    acdronin
    acdronin Well-Known Member
    You guys are all lucky, I have the Cali edition with smog stuff on it, all trucks in cali are now required to have the Trippy-Dippy-Hippy Emissions system, basically there are sensors all over your truck so if you try to replace the muffler bearing yourself without express written permission from the govenor you truck will either do one of two things: A: it grows dreads and decides to 'Occupy" wherever the fuck it's at, meaning it simply won't move unless you pepper spray the headlights. or B: It starts throwing CEL codes and turns into a California Politician, meaning it becomes unreasonable and totally obstinate, raises your taxes and saddle your offspring with ridiculous debt.
  2. Dec 6, 2012 at 3:25 PM
    #102
    Tacoma Mike
    Southern Maine
    Just back flush it from the pipe with Mothers Salve. Use a 4 inch reduction warbler and 2000 psi. Once inserted and pressurized, wait until the overhead temp display reads ( ) ( ). Remove hose while standing off to one side. After tar is ripped up dispose of properly. Within 2 min of aftershock fart, cycle key 64 1/2 times. Insert new ball bearings in the us made kit into the snap on tool # ou812. Inject directly into flap valve upstream from bearing housing. Start engine and warm up to 450 degrees for 30 min. That's it. New bearings installed the right way. So simple a caveman can do it.....
    :thumbsup::burnrubber:
  3. Dec 6, 2012 at 3:34 PM
    #103
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    I can't find my bearing? Where is it at? Where the plate to take of to grease it at least?
    I would take it to a professional for service. to many times I have heard horror stories about DIY's getting in over their heads. Big problems, a real can of worms.:(
  4. Dec 6, 2012 at 3:48 PM
    #104
    Rsoxfan1
    Rsoxfan1 Well-Known Member
    Mass
    2012 DCSB TRD Sport 4x4
    I once had a bad muffler bearing on my 83 vette...
  5. Dec 6, 2012 at 4:16 PM
    #105
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    I just cut my muffler off and I still can't find the bearing??? I know it's bad it rattles like crazy!
  6. Dec 6, 2012 at 4:20 PM
    #106
    Leggo
    Newton,Ma.
    you got it bro. Classic tell tale symptom.
  7. Dec 6, 2012 at 4:29 PM
    #107
    Millertime187
    David
    Clay City, KY
    1995 Taco
    Well I can't seem to find it so I'm going to put this thing back on. I have two choices ethier use a coat hanger and torch to weld it or I also bought some heat tape. Prob do both to be safe I guess.
  8. Dec 6, 2012 at 4:50 PM
    #108
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Bubble gum would be my choice in that situation.
  9. Dec 6, 2012 at 4:52 PM
    #109
    Millertime187
    David
    Clay City, KY
    1995 Taco
    I don't think that would work silly!
  10. Dec 6, 2012 at 4:53 PM
    #110
    Leggo
    Newton,Ma.
    can't use the sugar free shit either.
  11. Dec 6, 2012 at 5:14 PM
    #111
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Has to be the original double bubble pink shit.
  12. Dec 6, 2012 at 6:33 PM
    #112
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    East Coast Exhaust Supply sells a sleeve bushing kit to replace the troublesome bearing. For Taco owners with 8.4" or larger johnson rods only.
  13. Dec 6, 2012 at 6:36 PM
    #113
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    My johnson rod is only 3". :eek:
  14. Dec 6, 2012 at 8:03 PM
    #114
    KenLyns
    Belly of the Beast
    Real muffler bearing with greaseable zerk fitting:
  15. Dec 6, 2012 at 8:13 PM
    #115
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    All these muffler bearing threads is making me nervous. I should check mine.
    Do I need a metric or SAE crescent wrench?
  16. Dec 6, 2012 at 8:16 PM
    #116
    bullaculla
    Da big big island!
    Shit, I just loaned that one to a friend :mad:
  17. Dec 6, 2012 at 8:17 PM
    #117
    acdronin
    Is that by Canadian standards or Euro standards?
  18. Dec 6, 2012 at 9:00 PM
    #118
    olouieo
    olouieo U-member
    Louis
    So.Cal
    2013 TRD Sport, MGM DCSB 4x4,
    2013 TRD Sport, MGM DCSB 4x4, Icon Stage 4, 17" KMC Addict wheels, Nitto Terra Grappler Tires 285/70-17
    has anyone plasti-dip their Muffler Bearings?
  19. Dec 6, 2012 at 9:03 PM
    #119
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    i've thought about it, isn't it supposed to help it last longer?
  20. Dec 6, 2012 at 11:00 PM
    #120
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I warm my muffler bearings on the satoshi grill prior to installing, they drop right on without pressing. I buy only ceramic coated Titanium Sulfate Bearings for longer life, and keeping RPMs above 4800 means the muffler bearings never slow down long enough to seize, even when overdue for replacement. I like the bilstein bearings with adjustable preload, they perform better, as the correct amount of preload is crutial for good bearing life. I also recommend regular muffler flushes to remove contaminants and wear particles, as it greatly improves muffler bearing life when compared to a muffler drain and refill, but that is better than nothing.
