Muffler Bearing Question
Discussion in 'Technical Chat' started by 09DBLCAB09, Mar 11, 2013.
  1. Mar 11, 2013 at 11:44 PM
    09DBLCAB09
    09DBLCAB09 [OP] Well-Known Member
    Well I got about 49,000 miles on my truck and I finally had to replace my muffler bearings. Some old man walked by as I was doing it and he told me that I should replace my clutch belt at the same time because they usually go out around the same time
    Question is... Put in a stock clutch belt or should I put in a hi tension clutch belt since I'm running bigger tires and a lift?
  2. Mar 11, 2013 at 11:47 PM
    09DBLCAB09
    I check my headlight fluid about once a month. My truck doesn't really use that much surprisingly... Especially considering I have HIDs
  3. Mar 11, 2013 at 11:47 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Damn , rusty muffler
  4. Mar 11, 2013 at 11:48 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    hi tension all the way.
    don't forget to check the blinker fluid to
  5. Mar 11, 2013 at 11:49 PM
    09DBLCAB09
    That's what made me check the bearings. Good thing I checked cuz my muffler bearings were shit
  6. Mar 11, 2013 at 11:49 PM
    09DBLCAB09
    I've noticed my blinkers are starting to blink a little faster. I may be low on blinker fluid
  7. Mar 11, 2013 at 11:51 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
  8. Mar 11, 2013 at 11:53 PM
    09DBLCAB09
    I'll have to check that tomorrow
  9. Mar 11, 2013 at 11:53 PM
    95 taco
    95 taco Battle Born
    :gossip: don't you know, the v6's have 2?
  10. Mar 11, 2013 at 11:54 PM
    09DBLCAB09
    Where's the second one? I've only ready about 1 in the 2nd gens
  11. Mar 11, 2013 at 11:58 PM
    09DBLCAB09
    I did notice a weird ping after I put the new bearings in. I think it's just coincidence that my piston return springs may be going out
  12. Mar 11, 2013 at 11:59 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    You can totally get another 5,000 gallons out of that muffler bearing! I just recently rehoused my alternator filter
  13. Mar 12, 2013 at 12:00 AM
    OZ-T
    Peter North
    British Columbia
    I know what I'm doing tomorrow
  14. Mar 12, 2013 at 12:01 AM
    95 taco
    95 taco Battle Born
    not sure, i've only read about it.
    yep, gotta be super careful and make sure you lube up the bolts real good, unicorn piss is recommended, synthetic, 60%corn, 35%grass,5% oats.
    it has to eat that specific stuff to make the right weight lube.
  15. Mar 12, 2013 at 12:05 AM
    09DBLCAB09
    HAHAHAHHAHAHAHAHA
  16. Mar 14, 2013 at 6:25 AM
    BamaToy1997
    Bill
    Navarre, FL
    While you are replacing that muffler bearing, make sure that your kanuter valve is not binding. A sticky kanuter valve can cause premature muffler bearing failure. You don't want to have to go back in and replace that muffler bearing again if you don't have to. You didn't mention if your Tacoma was a V6 or a 4 cylinder., but remember that the V6 has TWO muffler bearings in it, not just one. I am Sure that someone here will provide the parts diagram to show this. And PLEASE don't use those cheap aftermarket bearings. You are just asking for trouble. By the way, anyone out there have a first gen? I have been searching all over and cant find the blinker fluid reservoir! I am thinking the prior owner may have removed it.
  17. Mar 14, 2013 at 6:27 AM
    Large
    Large Red
    So much trolling, guess I'll contribute.
    Use a skyhook to lift the motor, and make sure to grab a bucket of steam before you use the battery stretcher.
  18. Mar 14, 2013 at 6:31 AM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
  19. Mar 16, 2013 at 9:34 AM
    BamaToy1997
    Bill
    Navarre, FL
    My wiring harness smoke reservoir is still full. Haven't seen any leak out yet. Do you have any spare exhaust smoke? I see too much coming out of the tailpipe, so I think I may have a leak somewhere.
  20. Mar 16, 2013 at 9:39 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Straight up
    I had a dream last night where my truck got muddy on the inside. I was pissed.
