Muffler bolt in replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gavonder, Nov 1, 2018.
  1. Dec 20, 2018 at 10:57 AM
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    Years ago when I sold parts, none of walkers "stock" replacements were stainless. Now that might have changed, but I doubt it.
  2. Dec 20, 2018 at 11:04 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    OEM Toyota are the best longest lasting stock cat backs, if you want to spend the money$
  3. Dec 20, 2018 at 11:07 AM
    nivek5sfe
    nivek5sfe Well-Known Member
    Marietta, GA
    05 DCLB 4x4
    Not sure if the pipe is, on their site it just says 100% stainless muffler. Actually it says all of their replacement mufflers are. kinda has me leaning towards theirs now and getting the intermediate pipe too and just putting one of those thick joint clamps where it comes together, cant remember what theyre called, Ive used them to put a cat on a car in the past.
  4. Dec 20, 2018 at 11:20 AM
    BillsSR5
    bill
    2014 SR5
    you can get this setup for $147 on Amazon https://www.amazon.com/Walker-56204...mm=2008:toyota:tacoma&keywords=muffler+system
    DaveInDenver[QUOTED] likes this.
  5. Dec 20, 2018 at 11:28 AM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    The mufflers look like they are stainless:
    56204
    • Automotive Item Grade OEM Standard Part
      Muffler Body Height 5 1/2"
      Muffler Body Length 23"
      Muffler Body Width 11"
      Muffler Shape Oval
      Fitment Direct OE Replacement
      Muffler Type Combination
      Muffler Body Material Stainless Steel
      Muffler Inlet Configuration Offset
      Muffler Inlet Count 1
      Muffler Inlet Diameter 1 2 1/4"
      Muffler Inlet Diameter Designation Inside Diameter
      Muffler Inlet Connection Type Pipe Connection
      Muffler Outlet Configuration Offset
      Muffler Outlet Count 1
      Muffler Outlet Diameter 2 1/2"
      Muffler Outlet Diameter Designation Outside Diameter
      Muffler Outlet Connection Type Pipe Connection
      Muffler Overall Length 61 3/8"
      Muffler Reversible No
    And the int pipe is aluminized:
    54694
    • Class W
      Finish Aluminized
      Material Type Steel
      Inlet Count 1
      Inlet Connection Type 2 Bolt Welded Flange
      Outlet Count 1
      Outlet Diameter 2.250"
      Overall Length 40.500"
    BillsSR5 likes this.
  6. Dec 21, 2018 at 1:24 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    One of the reviews stated that the muffler rusted out in less than 3 years, so much for stainless.
    I've had alot of problems with walker products cracking on my civic and my wife's accord. I just keep taking the parts back to advance until they tell me no more. I think it's a one time replacement.
  7. Jan 30, 2019 at 12:03 PM
    nivek5sfe
    Marietta, GA
    05 DCLB 4x4
    Just an update, I bought the walker muffler for $109 shipped off ebay and put it on this past weekend. Used a sawzall to cut off the old one and the walker fit right up where the old one was. I used one of those band clamps to join it to the existing intermediate pipe, Ive used them in the past on project cars so I guess Ill see how it holds up on my DD.
  8. Jan 30, 2019 at 12:47 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    My stock exhaust lasted 12 years before a hole developed on top of the muffler.
    I bought oem to replace it.
    I have never had an aftermarket exhaust last as long as this. And it was under $500. with gasket and hardware.
    Took about an hour to swap out.
