Muffler help please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco969, Jul 13, 2008.
  1. Jul 13, 2008 at 9:05 AM
    Taco969
    Taco969 [OP] Well-Known Member
    I am looking to buy a flowmaster 40 series and install it on my truck. I am wondering what size inlet and outlet and also which offset? Also what else do I need to buy to do the install with no leaks? Any help is greatly appriciated as I would love to order today! Thanks!:D
  2. Jul 13, 2008 at 9:37 AM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    You best bet is to go to an exhaust shop that way you know its done right and be able to get what you want.
  3. Jul 13, 2008 at 9:58 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    Stock exhaust piping is 2.5 " and the muffler is center inlet and center outlet.:thumbsup:
  4. Jul 13, 2008 at 10:39 AM
    Taco969
    Thanks you very much!
  5. Jul 13, 2008 at 11:17 AM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    The info; center in/center out w/2.5" does not necessarily mean you can go out and cut/splice and clamp the muffler in and the tailpipe will fit perfect, although a satisfactory fit might be achieved, or just use a turn down at rear of muffler.
    Edit: The factory muffler on my 07 is staggered; not side to side, but the inlet goes in on the top, and the outlet is at the bottom. So, if you want to leave the exhaust system stock with the exception of replacing the muffler yourself, a generic fit will need some pipe bending done if you want to use the tailpipe and all factory hangers in the stock locations.
  6. Jul 13, 2008 at 1:04 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    Muffler shop for sure. I went with a Dynomax instead but had a welded install with all hangers in stock locations in 30 minutes for $100 total out the door.
    I also saved the stock one but haven't been disappointed with the swap yet.
