Muffler Recommedations
Discussion in 'Performance and Tuning' started by Koffnouski, Nov 19, 2017.
  1. Nov 19, 2017 at 8:32 AM
    Koffnouski
    Koffnouski [OP] Member
    Andy
    2007 Tacoma
    Bumper, Road Shower, Rack, Compressor, LEDs, Air shocks,
    Hi All,
    Looking for muffler "upgrade" recommendations. Something with a bit more "grrrrr baby" sound than the stock muffler.
    Thanks,
    Andy
  2. Nov 21, 2017 at 9:49 AM
    DanoDavis
    DanoDavis Alright meow
    Daniel
    Allen Tx
    09 Double Cab 4x4 6-Speed V6
    1 1/2" lift with 5100's, custom exhaust, LT Headers, URD CAI, URD MAF Calibrator, Electric fan, Camper shell, retrofit projectors, and other goodies..
    Dirtydeedsindustries.com
    Keith Carty is the owner, and a personal friend of mine.
    I’ll never run any other muffler again.
  3. Jan 6, 2018 at 3:36 PM
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    I did a muffler only system last month using a Black widow venom 250 muffler. http://www.blackwidowexhaust.com/mu...nter-SKU-BW001-C/p/35648298/category=15730041 They are worth looking into.
    I previously had a flowmaster series 50 muffler 1in/2out running split exhaust that came out of the back of the truck. I loved that system and the sound but it rusted and I needed to make another exhaust. I got my exhaust built earlier this month using a Black widow 2.5" Venom 250 muffler and i already have a aFe Stage-2 Si Pro 5R Cold Air Intake System Dry filter installed.
    I really like the sound of the Venom 250 on my truck. The initial firing up sound is aggressive and loud enough but doesn't scare small children. It was 11F this morning while starting the truck in the video. With that said, your neighbors will definitely know when you have started your truck because the exhaust note travels inside the house easily. Just under normal idle while sitting at a light or in a drive through you wont notice it to much, but once you get on the throttle you and everyone around you will hear it. Getting onto the highway or passing anyone puts a smile on my face each and every time.
    The biggest thing that I noticed with this muffler compared to the last system that was on my truck is how much "quieter" the Black widow muffler sounds inside the cab compared to outside the truck, It doesn't sound annoying or overly loud. It has some hum at 1500 rpm, so going 35 down the road you might have a little hum but not annoying drone. At 2k RPM while doing 70mph the exhaust is comfortably quiet and easy to drive, but once you bring the motor up to 3200 RPM she stops sounding like a Tacoma and makes me smile. The company Black widow is worth looking into to for sure.
    Koffnouski[OP] likes this.
  4. Jan 7, 2018 at 8:38 AM
    Koffnouski
    Andy
    2007 Tacoma
    Excellent!!! Thank you. This is the sound I'm looking for. Many thanks for posting the video.
    Was it difficult to install?
    Andy
  5. Jan 7, 2018 at 10:46 AM
    tattooedsnake
    Erick
    Connecticut
    '10 TRD sport 4x4
    Thanks I'm glad you like it. I can't say whether or not it was difficult or not since I had an exhaust shop do the job for me. I also had to get a lot more work done because my exhaust had rusted all the way to the factory mid pipe. The dumbass before me made the custom exhaust out of aluminized steel instead of stainless. So I had all new pipe bent and run with the muffler to make my own catback.
    The whole ideas of just cutting out the factory muffler and then welding a blackwidow in place isn't a hard job and any shop should be able to do it within an hour probably.
    Do me a favor and tell whatever exhaust shop you have do the build to check out blackwidow and help spread the word. I found out about them in a hot rod magazine and that is where Blackwidow mufflers are known more and less in the mid size truck world. They make an awesome muffler and are very easy to deal with when making an order. I ordered right from the website but they have custom shops around the country that sell their products.
    I accidentally ordered the wrong size muffler and messaged them on FB and within about 3 hrs the order was adjusted and shipping out.
    (Disclaimer I do not work for black widow. I just found a new product that I really like that is different than the normal stuff everyone buys.)
    Erick
  6. Jan 8, 2018 at 10:35 AM
    tattooedsnake
    Erick
    Connecticut
    '10 TRD sport 4x4
    With the old exhaust I noticed that after 3k rpm you would loose the sound of the muffler because the intake sound would take over. After having the new exhaust for about a month now the biggest thing that I noticed is a pretty consistant power band and also engine sound. There is no drop of one sound for another. As the RPMs get higher the whole engine system sounds strong and happy.
  7. Jan 23, 2018 at 10:33 PM
    runner05
    runner05 Well-Known Member
    Karl
    I like the sound of Borla mufflers. They produce a nice rumble.
  8. Feb 5, 2018 at 7:20 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  9. Feb 5, 2018 at 8:26 AM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    @dirty deeds
