Muffler/Tail Pipe rattling
Discussion in 'Technical Chat' started by SongDog, Oct 28, 2008.
  1. Oct 28, 2008 at 5:41 PM
    SongDog
    SongDog [OP] Active Member
    DFW, TX
    SR54x4 Sport
    Tint, Husky floor liners, UWS low profile toolbox, 2.5 lift, 265/70/17 BFG A/T, Moto Metal 951 17X9
    So I finally narrowed down the location of this periodic "clunk" when going over abrupt bumps on the passenger side. The design of the factory exhaust assembly allows it to travel up and down freely about an inch or so while supported with rubber bushings. The noise is coming from the fast down travel of the entire exhaust. It sounds like a blown shock. I can also hear a slight squeek fom the two springs and bolts that hold the two exhaust pieces together.
    Question...has anyone else noticed this sound? What could I do to get rid of it?
    It only happens during abrupt movement (bumpy roads)...not during normal driving.
  2. Sep 6, 2021 at 6:29 PM
    Ayoung208
    Ayoung208 Member
    Andrew
    2010 Tacoma TRD Sport DCLB
    I just bought a 2010 Tacoma Long Bed TRD sport and I noticed the exact same thing. After a bit of looking underneath, I determined quite conclusively the same issue. The exhaust pipe is welded to a steel bar which is attached to a rubber 'spring' type hanger that allows the tailpipe to travel up and down. My findings show that is the metal bar type bracket that makes contact with the leaf spring. Im not sure what can be done.
    The only thing I have thought of is taping a pad or something to the steel bar bracket to muffle the sound but it would have to handle the heat of the exhaust. Another thought is using a more ridged rubber hanger but Im not sure what could be found.
    Would love to hear more input on this issue. It is quite a clunk!
  3. Sep 9, 2021 at 7:43 PM
    cheezoto
    cheezoto Well-Known Member
    1KD Diesel ACLB, Supercharged DCSB
    I have had this issue before. You can buy stiffer rubber exhaust hangers, should fix your problem.
  4. Sep 9, 2021 at 7:44 PM
    cheezoto
  5. Sep 10, 2021 at 10:30 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I look at things figure out where the noise is coming from if it is the exhaust .
    Install a clamp and universal hanger preventing the exhaust from hitting anything.
    Then things like this really don`t bother me once I know the source not like the fuel tank is bouncing around having one fall off was enough of an embarrassment
