Muffler, Weld or Clamps?????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Przemekmsu, Jun 27, 2010.
Muffler Weld or Clamp????
Poll closed Jul 27, 2010.
  1. Weld
    44 vote(s)
    89.8%
  2. Clamp
    5 vote(s)
    10.2%
  1. Jun 27, 2010 at 9:14 PM
    Przemekmsu
    Przemekmsu [OP] Well-Known Member
    Przemek
    South Jersey
    2006 Toyota Tacoma, SR5 V6, 4x4 TRD Off Road
    K&N Air Filter, WickedFlow Exhaust muffler
    So my new WickedFlow muffler should be coming in any day, I have been going back and forth if I should have it welded it or just clamped it????? What is your opinion about it. What is better?????
  2. Jun 27, 2010 at 9:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If done right, The clamps can be leak free. If done poorly, the welds can leak. Personally, I prefer welding.
  3. Jun 27, 2010 at 9:18 PM
    Przemekmsu
    Przemek
    South Jersey
    I guess weld it it looks cleaner as well.
  4. Jun 27, 2010 at 9:27 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I would use the clamps until I got it to the exhaust shop where they can weld it. That's about as far as I'd go with clamps.
  5. Jun 27, 2010 at 9:27 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
  6. Jun 27, 2010 at 10:06 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    Why clamp when welding is an option?
  7. Jun 28, 2010 at 5:13 AM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    The only reason I could see that you would want to clamp it is that you are not sure whether or not you'll like it...
  8. Jun 28, 2010 at 6:04 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Both.....
    Are you installing a muffler only?
    If yes....I would only use the clamps until you are ateast happy with the quality, sound, performance of the muffler. At that time - if you are happy with it - you can decide if you want it welded (and can leave the clamps on).
  9. Jun 28, 2010 at 10:16 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    My muffler setup is clamped but of course welding would be the better option. One of these days I will go through and tac weld it wherever necessary.:rolleyes:
  10. Jun 28, 2010 at 11:09 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    welds not only look cleaner but also less chance of having exhaust leaks...:D
  11. Jun 28, 2010 at 2:16 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Same here....had planed on getting it welded sooner but just haven't gotten around to it yet...
  12. Jun 28, 2010 at 4:04 PM
    Janster
    Jandy
    Lancaster, PA
    Something to think about......
    The only real chance of having it welded and avoiding leaks - would be to have it welded while the exhaust is 'off' the truck.
    Trying to have someone weld it while the exhaust is still mounted on the truck, is very difficult to weld the top parts of the tubing, depending on clearance.
  13. Jun 28, 2010 at 4:07 PM
    T0LLPHR33
    BSP TRD Off-Road
    most times when exhaust/muffler shops are going to weld any part of the exhaust setup they remove the exhaust to do a better job at welding...
    only lazy people would try to weld while the exhaust is still on the vehicle...:rolleyes:
  14. Jun 28, 2010 at 7:40 PM
    Janster
    Jandy
    Lancaster, PA
    Then I'm lazy then...THanks. :p My husband and I put a Flowmaster dual exhaust kit on the truck ourselves. If you know anything about these kits, the hardest part is lining everything up, getting the tubes twisted for exact placement at the exits, making sure there's clearance everywhere,etc.
    Clamp it all together and I'm sure as hell not removing it again after all that work. I had it welded...stitch welded to be exact. But that's certainly not gonna control leakage. It was to help prevent it from moving.
    So - depends on what your sole purpose is for getting it welded. For leakage prevention or holding it together.
  15. Jun 28, 2010 at 7:43 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    Weld you would spend the thirty bucks in clamps anyways
  16. Jun 28, 2010 at 8:31 PM
    revhappyleon
    revhappyleon Well-Known Member
    Manny
    Tampa near macdill
    07 Prerunner V6 6-speed(custom dual exhaust)
    dual exhaust, foglight anytime, satoshi, chlm, aux backup lights and electric fan conversion
    what kinda muffler is it? if it's a straight through design like a glasspack or magnaflow you don't have much to worry about in the way of leaks if it's a welded style muffler(like flowmaster) you might wanna weld it. (i start a thred about turboing my truck nobody replies you include a poll and suddenly everyone comes clicking:( fml )
  17. Jun 28, 2010 at 9:35 PM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    Link me there. I used to have a turbo taco, I love talking boost!
  18. Jun 28, 2010 at 10:00 PM
    revhappyleon
    Manny
    Tampa near macdill
  19. Jun 28, 2010 at 10:19 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Morty
    Outer Space
    Weld it boy! Why would you clamp a exhaust or muffler?!?!
  20. Jun 28, 2010 at 11:19 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    did deleting the rear cats change the sound?:confused:
