Muffler?
Discussion in '1st Gen. Tacomas (1995-2004)' started by VintageFast, Aug 28, 2015.
  1. Aug 28, 2015 at 8:27 AM
    VintageFast
    VintageFast [OP] Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Alright, after 395,000 miles it's time to but a muffler. I'm not looking for anything loud. What do ya'll think I should go with?
  2. Aug 28, 2015 at 8:36 AM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    Another stock muffler? Also the TRD one isn't too loud if you decide to go that route. Most magnaflow and flowmaster are relatively loud. Borla makes a good one too but might be louder than you are looking for. You might just look up a bunch of sound clips, there are also reviews on some exhaust systems posted around TW
  3. Aug 28, 2015 at 9:21 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I run the Walker one .47743 This is the one with the tail pipe as well
    Not loud I can see no loss of performance
  4. Aug 28, 2015 at 12:42 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    If you don't want extra noise a simple turbo muffler will do
  5. Aug 29, 2015 at 2:40 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I find when anything goes may as well replace from the cat back because it won`t be long till the rest fails.
    Myself I would rather do it all and be done for a few years
  6. Aug 29, 2015 at 4:28 PM
    EricU
    EricU Well-Known Member
    Englewood, CO
    i have a knock off magnaflow on mine, about 18-24" long
    nice and quite and much smaller than stock
  7. Aug 29, 2015 at 4:34 PM
    BCollett
    BCollett Well-Known Member
    Brandon
    Hesperia Ca
    01 Limited Dbl Cab 4x4
    Pro Comp Lift.
    I'm in the same boat and I have heard people like their Aero chamber mufflers from hooker. They aren't raspy like the flow master. at idle its more noticeable than stock but cruising down the road its basically as quiet as stock im told. i found some videos on youtube..... hard to really tell how it will sound but it wasn't bad.
  8. Aug 29, 2015 at 6:19 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Borla pro xs with an ultra quiet resonator!!:D
  9. Aug 29, 2015 at 9:03 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    x2
    I have the aero 2525xl
    xl means it has the resonator so its a bit quieter. Sounds good to me.
  10. Aug 29, 2015 at 9:09 PM
    At The Helm
    At The Helm ATH Fab Vendor
    Morgan
    Gardnerville, NV
    2015 AC 4x4 TRD OR & 2019 T4R
    Kings, TC UCAS, SCS SR8's, ATH bumpers
    Dynomax super turbo is pretty quiet... Like just barely noticeably louder than stock.
  11. Aug 31, 2015 at 12:15 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    This
  12. Aug 31, 2015 at 12:38 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Flowmaster 50
