Multi function display question...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by staplegun, Dec 6, 2019.
  1. Dec 6, 2019 at 10:13 AM
    staplegun
    staplegun [OP] Well-Known Member
    Drove the 2016 today and while driving on the interstate, I noticed that the little speed limit sign that usually populates the bottom right corner under the compass was gone. Any ideas why this may have happened?
  2. Dec 6, 2019 at 10:25 AM
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    I'll take a look the next time I get in the truck. In general, I've noticed that it comes and goes based on the road and if the information is available for that particular stretch.
    Did you update your map data recently?
    GreyBaldTaco, Skydvrr and shakerhood like this.
  3. Dec 6, 2019 at 10:34 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I think that's it. Some roads don't have the mph. But I believe there's a setting for it as well.
    GreyBaldTaco likes this.
  4. Dec 6, 2019 at 10:40 AM
    staplegun
    The stretch of road I was on has showed the speed sign icon up until today. I retrieved an SD disk to get updates...
  5. Dec 6, 2019 at 10:41 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Search around in the settings. I think u can have it turned off
  6. Dec 6, 2019 at 10:53 AM
    staplegun
    Thanks for the replies guys - I'll check and see what settings exist, I'm baffled since I just made the same trip yesterday and the settings were not touched.
  7. Dec 6, 2019 at 11:27 AM
    DirtyGovnuh
    DirtyGovnuh Well-Known Member
    2021 TRD OR DCSB 4x4
    If you use the buttons on the steering wheel there is a speed limit options in the settings menu on the MFD.
  8. Dec 6, 2019 at 11:54 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Could it perhaps be linked to the navigation? I haven't ever payed it any attention, but now I am curious. I wonder if it only shows when nav screen is active.
  9. Dec 6, 2019 at 11:55 AM
    DirtyGovnuh
    It is. When I swapped my base entune for the entune premium the options were added to my MFD
    daddy_o[QUOTED] likes this.
  10. Dec 6, 2019 at 11:59 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    My radio screen is always off. My mph still shows.
    shakerhood and tonered like this.
  11. Dec 6, 2019 at 12:02 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Same here.
    I was guessing this is a function of Entune. Does anyone not using the app have the speed limit showing up?
    shakerhood likes this.
  12. Dec 6, 2019 at 12:03 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I also, don't use the app haha.
    tonered[QUOTED] likes this.
  13. Dec 6, 2019 at 12:05 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks! :cheers:
    That is interesting if it is on the map data card, esp how often speed limits are changed around here.
    Damn. Now. I have to put less trust in it.
    Skydvrr[QUOTED] likes this.
  14. Dec 6, 2019 at 12:08 PM
    piff
    piff Well-Known Member
    Minnesota
    2019 Quicksand Tacoma TRD OR DCLB AT
    Bone stock baby
    I thought I read somewhere that the windshield camera system thingy looks for speed limit signs. Maybe that supplements existing map data?
    Tullie D likes this.
  15. Dec 6, 2019 at 12:11 PM
    daddy_o
    Bossier City, La
    Just to be clear, not the MPH, but the max speed limit sign is the item in question
  16. Dec 6, 2019 at 12:15 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is a yes for me. I mainly use the headunit to make calls with the four main quick dial contacts. Otherwise it is off and the speed limit sign shows up on the compass screen any time that I have looked.
    shakerhood and Skydvrr like this.
  17. Dec 6, 2019 at 12:21 PM
    Camel89
    Camel89 Well-Known Member
    Houston, TX
    2016 TRD OR 4x4
    I think this has been brought up in another thread before. When you noticed it was missing, did you notice if your navigation system was displaying the speed limit?
    If the speed limit setting is turned on, and it is still not displaying, toggling between the Map and Home screen on the headunit will turn it back on. Sometimes on mine, when I first start driving, it does not display on the home screen (and the multi function display), but going to the Map screen, and then back to the Home screen turns it back on, on both the headunit and multi function display.
    15+1 likes this.
  18. Dec 6, 2019 at 12:40 PM
    staplegun
    I hardly use the navigation. And yes - as daddy_o stated -> "Just to be clear, not the MPH, but the max speed limit sign is the item in question"
  19. Dec 6, 2019 at 1:02 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Yep yep. Thanks for clarifying
  20. Dec 6, 2019 at 2:20 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I rarely use Nav and that little max speed sign appears for me too.
