Multiple cylinder misfire
Discussion in '1st Gen. Tacomas (1995-2004)' started by Brokenneck, Mar 24, 2024.
  1. Mar 24, 2024 at 5:29 PM
    Brokenneck
    Brokenneck [OP] Member
    Mark
    2001 tacoma 2.4L rear wheel drive xcab
    None
    So I just replaced the spark plugs and coil packs and multiple sensors plus engine coolant sensor. Still misfiring I am not sure what to do next. I need my truck for work. Someone please help me figure this out.
  2. Mar 24, 2024 at 5:30 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Which codes is it throwing?
  3. Mar 24, 2024 at 5:42 PM
    Brokenneck
    Mark
    None
    1. Not it says mass air flow A circuit
    2. Intake Air Temperature sensor 1 circuit
  4. Mar 24, 2024 at 5:43 PM
    Brokenneck
    Mark
    None
    Mass or volume air Flow A circuit.
  5. Mar 24, 2024 at 6:49 PM
    HazMatKat413
    HazMatKat413 Active Member
    2011 Tacoma Crew Cab, 2003 Crew Cab
    Husky X-Act Floor Mats F&R Bakflip MX4 hard tonneau Undercover swing away tool box
    Confirm that your air cleaner housing and boot are all seated and sealing properly.
    If you have a scan tool, check the temperature, can't recall what its listed as, but I noticed my temperature reading was way out of whack after driving home, was either map or maf sensor, don't remember which but it was 2 torx head screws
  6. Mar 24, 2024 at 7:01 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Being the parts cannon that I am, maybe clean or replace the egr valve.
    ControlCar and HazMatKat413 like this.
  7. Mar 24, 2024 at 8:06 PM
    Brokenneck
    Mark
    None
    Thanks for the input guys I'll check it out and see what I can come up with.
    Steves104x4 likes this.
  8. Mar 25, 2024 at 1:12 PM
    Glamisman
    Glamisman Well-Known Member
    While running disconnect either the electrical connector to the individual ignition coils or fuel injectors. If there is no change, reconnect and go to the next. If there ia a big change you have isolated the offending cylinder.
  9. Mar 25, 2024 at 2:00 PM
    HazMatKat413
    Think you just swapped those...
    My understanding is if you unplug a properly FUNCTIONING coil or wire, you'll see a significant change.
    Whereas if you unplug a DEAD one, you'll see no significance change.
