Multiple dash lights popping
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Life3.0, Jun 1, 2024.
  1. Jun 1, 2024 at 6:23 PM
    Life3.0
    Life3.0 [OP] Member
    TacomaGrl
    2019 Tacoma SR5
    I juuuuust bought through Carvana for a 2019 Tacoma. Regretting this right now.
    I need some pro insight here…
    multiple dash lights popping on:
    check charging systems
    High A/T Temp
    Low oil pressure
    Gas gauge at a half tank
    No leaks obvious to the eye
    Sounds fine
    Went to auto zone - no codes triggered
    Battery and Alternator test fine
    I have never owned a vehicle and within a week various systems are lighting up on my dash.
    insight most welcome!
  2. Jun 1, 2024 at 6:25 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Are they only there while you’re sitting with the key on but engine not running?
    Road_Warrior, WA7 and t0p_d0g like this.
  3. Jun 1, 2024 at 6:25 PM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    I had all those indicators when I was offroading on a 30 deg angle pitch. I got the truck level and everything was fine after that. Hope others can chime in. Goodluck and welcome.
    Life3.0[OP] and Road_Warrior like this.
  4. Jun 1, 2024 at 6:27 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Same thing here. I rolled backwards about 15 feet on a grade while the truck was in drive, and all those same lights came on and the engine stalled.
    I turned the ignition off and then back on and all has been fine. That was about 30K miles/1 year ago.
    Not sure if that could be related, OP.
    Life3.0[OP] likes this.
  5. Jun 1, 2024 at 6:32 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Are these coming on while the vehicle is on/running or are you just turning the key without starting the vehicle?
  6. Jun 1, 2024 at 6:40 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Welcome to TW!
  7. Jun 1, 2024 at 6:53 PM
    Life3.0
    Life3.0 [OP] Member
    TacomaGrl
    2019 Tacoma SR5
    Bingo! Key is in but engine isn’t cranked. Thoughts on this?
    t0p_d0g likes this.
  8. Jun 1, 2024 at 6:54 PM
    Life3.0
    Life3.0 [OP] Member
    TacomaGrl
    2019 Tacoma SR5
    thank you! I’ve wanted a Tacoma for the longest time! Excited to learn more.
    t0p_d0g[QUOTED] likes this.
  9. Jun 1, 2024 at 6:58 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    That’s normal for Tacomas. Nothing to be concerned about.
  10. Jun 1, 2024 at 7:00 PM
    Life3.0
    Life3.0 [OP] Member
    TacomaGrl
    2019 Tacoma SR5
    …thank you! The left dash - all kick on then off but on my right side they linger and there a flag in the messages center. It’s the battery light and the engine light that lingers then kicks off after the engine cranks. Seems odd -:)
  11. Jun 1, 2024 at 7:14 PM
    530Taco
    530Taco Gone fishin'
    Adam
    Old Hangtown, CA
    '21 DCSB OR MT Cement
    Call it a test before you crank the truck over, you don't want to see those lights if the engine is actually running.
    Life3.0[QUOTED][OP] likes this.
  12. Jun 1, 2024 at 7:16 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    If you start it up, they all go away? If so..normal for some lights to be on with only the ignition on.
  13. Jun 1, 2024 at 7:17 PM
    Life3.0
    Life3.0 [OP] Member
    TacomaGrl
    2019 Tacoma SR5
    The whole panel lights up - seems normal then goes away. It’s the check engine light and the battery light that remains for a bit and then goes off. I have an appt on Monday at a Toyota dealership… it’s that battery light and engine that lingers but once the engine cranks it goes away. Seems so weird.
  14. Jun 1, 2024 at 7:18 PM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Here ya go..
    https://www.tacomaworld.com/threads/check-charging-system.557207/
  15. Jun 1, 2024 at 7:19 PM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    I would say you don’t need to take it to the dealership (but I’m not an expert). I’m honestly kind of surprised they didn’t just tell you that on the phone.
  16. Jun 1, 2024 at 7:20 PM
    530Taco
    Adam
    Old Hangtown, CA
    Don't waste your time or money, they're going to tell you it's totally normal.
    soundman98 likes this.
  17. Jun 1, 2024 at 7:20 PM
    TheWildMan
    TheWildMan Well-Known Member
    3rd Gen 23 Tacoma OR
    Scrubbed some tires, and knocked a dent out.
    Did your belt break?
  18. Jun 1, 2024 at 7:20 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    That is "ACC" mode and "RUN" mode in a car with keys. Before you crank the engine the entire system is checking itself and throwing warnings because some parts are still inactive.
  19. Jun 1, 2024 at 7:21 PM
    TheWildMan
    Just saw that you drove it. If it wasnt hard to turn, probably not your belt
  20. Jun 1, 2024 at 7:21 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    They want a chance to upsell a $100 air filter and fuel injector cleaning.
    Road_Warrior[QUOTED] likes this.
