Multiple Front Wheel Bearing Failures
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ricerebel, Jan 18, 2010.
  1. Jan 18, 2010 at 7:56 PM
    ricerebel
    ricerebel [OP] New Member
    Harlan
    Northeast Arkansas
    05 v6 trd
    I just had my fifth (yes, five) front wheel bearing failure on my 05 4wd trd at 127,000 miles:mad:. I called Toy Cus Serv and they said they had no recorded issues with front wheel bearings (of course they would say that), but I see multiple failures in this forum. I drive 85% paved roads, 10% gravel roads, and 5% dirt on my farm. No water over the axles. I bought Toyota for its "go anywhere reputation" but I'm not sure I can afford to keep driving Toyotas. Any similar experiences or solutions?
  2. Jan 18, 2010 at 8:53 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    damn, what do you have for lift and wheels/tires? I had to replace one around 65k, seems to be holding up just fine. 5 is definitely a lot, and they're not exactly easy to change!
  3. Jan 18, 2010 at 9:13 PM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/75-16 KO2
    When did the first one fail?
  4. Jan 19, 2010 at 12:02 PM
    Mr_Torque
    Mr_Torque Buy the Ticket take the Ride.....
    Perkasie,PA
    '07 Tacoma SR5 4WD V-6 6 Spd
    MBRP Exhaust, 17" FJ Steelies w/Firestone AT's, Truxedo Lopro ,Timbren SES, Pioneer FH-X720BT HU & TS-C720PRS Component Speakers, TRD Quickshifter, Bilstein 6112/5160, Light Racing UCA, and Icon Progressive add a leaf.
    Who's replacing the bearings? Either they are getting damaged during the install or something else is out of spec.
  5. Jan 19, 2010 at 12:05 PM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2010 4Runner Trail Premium
    Dont get dishartened this is not normal ... You can still trust your Tacome for " go anywhere rep" Something is not right maybe its a cheap part, cheap installation, or something else ... unless you are buying the OEm parts from the dealer and those parts are going bad.
  6. Jan 19, 2010 at 12:19 PM
    Brunes
    Brunes abides.
    Rotorhead
    Yeah....Something ELSE is wrong with your rig- Instead of just blindly replacing wheel bearings- Have them look deeper to find the actual problem.
    The Tacoma isn't known for eating wheel bearings- so it's not a Toyota/Tacoma reputation thing- It's your truck.
    best of luck getting it solved.
  7. Jan 19, 2010 at 12:21 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    X3.
  8. Jan 19, 2010 at 12:40 PM
    Death_Stalker
    Talha
    Cypress, TX
    what is going on with your truck that you or your mechanic thinks its the bearings ?? Are you taking it to the same shop everytime something goes wrong? here is an example ... My truck had vibrations while accelerating. 2 mechanics told me it was the hub assembly, one told me it was the u joints. I thought majority rules so lets get the hub assemble replaced. Well guess what? it wasnt the hub assembly it was the u- joints. You may want to get more than 1 or 2 opinions on diagnostics...
  9. Jan 19, 2010 at 7:41 PM
    ricerebel
    Harlan
    Northeast Arkansas
    05 v6 trd
    Thanks for your replies. Let me answer. First, standard trd suspension / factory size tires, factory alloy wheels. First fail (left front) at 89k - dealership replaced and failed again at 120k - non-dealer reapir. Right front failed at 109k, non-dealer repair, failed again at 118k, non-dealer repair, and failed again at 127k which the dealer just repaired. All failures are REALLY wheel bearing failures - jack the wheel off the ground, grab the top and bottom and wiggle the wheel in and out 1/4 to 1/2 inch. Dealer repairs were OEM parts and I believe other repairs were aftermarket parts. Any more thoughts or suggestions?
  10. Jan 19, 2010 at 8:02 PM
    ksj
    Pacific NW
    265/75-16 KO2
    The first sounds about right (89k), though I'd expect >100K. Something is putting pressure on those bearings and causing them to fail. Has the truck ever been in a wreck? Are you getting alignments after you replace the bearings?
