Multiple misfire codes help!
Discussion in 'Technical Chat' started by SargeSlapnuts, Nov 29, 2012.
  1. Nov 29, 2012 at 11:29 AM
    SargeSlapnuts
    SargeSlapnuts [OP] SargeSlapnuts
    Nick
    Pooler, Ga
    2003 taco TRD off road 4x4 dbl cab.
    255/85-16 BF goodrich km3's, modified trail gear Bumpers front and rear, 10k winch, ranch rear lift shackles, Rancho coilovers in the front, grey wire mod, aftermarket stereo, camper top on the back.
    i have the following codes
    p0300 mutiple misfire
    p0301-p0304 misfire on denoted cylinder.
    my truck started running terribly one day and now it will not even run at all. about to change fuel filter. already changed MAF sensor. not sure where else to look. help would be much apreciated. also plugs are in decent shap and are firing as i checked all of them.
    my truck has the 2.7l and is an '04
  2. Dec 1, 2012 at 9:52 AM
    budget76
    budget76 Active Member
    New Jersey
    98 xt-cab 4x4 4cl/2.7 stock man
    soon want dual lockers Picture was my 85 dual arb great
    sorry to hear.
    I propose you clean all grounds, and open each electric contact easy to reach,
    clean with dremel round wire brush, add dielectric grease and put back together. I usually do
    this when all is good, but today you are screwed.
    need now age of plug wires. I am changing mine soon just to have new
    wires and avoid issues like this. i do 600 miles a week in my 98 and change parts before
    they die.
    mikes 2 cents.
  3. Dec 2, 2012 at 9:01 AM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    http://www.obd-codes.com/p0300
    go through this step-step. this is a serious problem.
    don't drive your truck, you can do serious damage to the engine, and destroy your cat. very fast.
    and use OEM parts....
  4. Dec 3, 2012 at 9:17 AM
    SargeSlapnuts
    Nick
    Pooler, Ga
    Well I did also check both the cam and crank sensors and they have both check out. Was looking through various pids on my code reader and found that my second o2 sensor is getting zero volts and randomly peaking about a volt. Ill investigate further and let you guys know. I have also been following the step by step procedures via all data.
  5. Dec 3, 2012 at 9:20 AM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
    most of the time when ive seen the "p0300 random cyl misfire" code its been either a maf or coil, id check the coil since you said you already changed your maf
  6. Dec 15, 2012 at 12:28 PM
    SargeSlapnuts
    Nick
    Pooler, Ga
    I have finally found the problem and its a bit angerinng but good to have my truck running again!
    My front catalytic converter blew all to peice and got stuck in the second cat. hence my exhaust was plugged up. so now i have my truck running and also have to buy 2 new cats. thanks for all the help to contributors and suggestions!
