multiple sets of fog lights
Discussion in 'Lighting' started by devilsalmostfree, Jun 19, 2010.
  1. Jun 19, 2010 at 11:55 AM
    devilsalmostfree
    devilsalmostfree [OP] Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    i did a search & found nothing on this! im wanting to put 4 sets of fogs on my truck. is it possible to just run all the wires from battery & ground to 1 of the switches, then jump from switch to switch & just run seperate accessory lines to each switch, that way i can turn either set of fogs on anytime, & not have to turn 1 on to get another to be on? im not the brightest when it comes to wiring. thanks for the help in advance!
  2. Jun 19, 2010 at 12:19 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    yep, i got 4 wired up like that
  3. Jun 19, 2010 at 12:32 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    With a bit stronger relay? Same wiring? Next bigger fuse? Higher amp switch?
  4. Jun 19, 2010 at 1:12 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    awesome, thanks guys!
  5. Jun 19, 2010 at 1:22 PM
    shanomac
    shanomac Senior Member
    Massachusetts
    '10 SR5 4x4
    You definitely want separate relays for each set of fogs. Be careful how much load you try to draw from the wires as they're of a pretty high gauge (thin). Better safe than sorry, IMHO. Each should have it's own wiring, relay and switch. Again, just my opinion. Good luck and post pics. I gotta see a Taco with 8 fog lights on it!!
  6. Jun 19, 2010 at 1:27 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I have 2 sets. 1 set is 35w HIDs. The other set is Hella 500s that are currently halogen but want 55w HIDs in them eventually. I have seperate oem switches and seperate wiring/fuses/relays.
  7. Jun 19, 2010 at 1:41 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    the lights will be going on my gmc, i only have 1 set on my tacoma. might add 2 more sets on it later on!
