Multiple Switches to Same Add a Fuse?
Discussion in 'Lighting' started by BrotherBudro, Jan 6, 2018.
  1. Jan 6, 2018 at 7:00 AM
    BrotherBudro
    BrotherBudro [OP] Well-Known Member
    David
    Nashville
    2017 SR5 Access Cab, V6 4X4
    Leer 100XR, Dual Battery, Dog Platform, Sleeping Platform, Ham, CB, Light Bar, Rear Lights,
    Hey guys,
    I had a professional install my LED light bar, and rear facing lights. The switches are from On Board Air and are wired to illuminate when the dash lights are on. I am in the process of planning out how I'm going to install ditch lights myself.
    My question is: Can I run all 3 switches from the same add-a-fuse (AAF) that allows them to illuminate with the dash lights are on? If so, how? I am assuming the installer ran the current 2 switches off the same AAF and I can follow his lead there, but I want to have a plan BEFORE I take apart the dash.
    If I can't run them all off the same AAF, do I just need to buy one for each switch I add (I don't see myself adding any more after this, but if I hang around here too long, who knows)
    pauldncali likes this.
  2. Jan 12, 2018 at 1:42 PM
    BrotherBudro
    David
    Nashville
    I ordered a pack of 5 add-a-fuses. The way they are designed, I think it will work. Unless there is something going on behind the scenes that I'm not aware of. I think I'll only need to do 2 AAFs total (one off the other). My backup plan is just find another fuse that is powered when I turn on the headlights :fingerscrossed:
    I should know in about a week.
  3. Jan 12, 2018 at 2:57 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    yes as long as they are only triggering a relay
    Plain Jane Taco likes this.
  4. Jan 12, 2018 at 3:13 PM
    paranoid56
    San Diego
    14 double cab taco
    thats what i do, as the power to illuminate the little LED in teh switch and the amount of power to trigger a relay is so low. I think last time i checked, doing 3 switches and relay trigger was less then a half amp. (would nee to double check that)
    its a dfx file, let me know what file you can read and i can send that :D
  5. Jan 12, 2018 at 4:56 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Pdf? Or anything else im not a snazzy enough engineer to know how to read dxf haha
  6. Jan 13, 2018 at 5:17 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    For the mic tuning oem style switches, i tap into the illumination wires off the stock foglight switch. They light up when the lights are on just like oem. No need for an add a fuse.
  7. Jan 13, 2018 at 5:20 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    This.
    If not....no way
  8. Jan 14, 2018 at 8:47 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Agreed
