Multipurpose 4x4 Long Travel kit?
Discussion in 'Long Travel Suspension' started by ks2socal, Aug 3, 2010.
  1. Aug 5, 2010 at 11:11 AM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    who needs long travel anyways. oakleytrd please, he gets the mad hook up at allpro. Any lt set up will be good in the rocks just watch the backend. I have done many trails with mine and not only desert. I am not 4x4 but have never needed it anyways, locker is all i need.
  2. Aug 5, 2010 at 11:14 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    steve do you use your stock e-locker or you have an aftermarket locker?
  3. Aug 5, 2010 at 11:25 AM
    bajamoon
    STEVE
    Whittier
    stock
  4. Aug 6, 2010 at 3:19 PM
    06HAOLE
    06HAOLE Well-Known Member
    Sherman Oaks, CA
    2014 Ford Raptor
    You have way more patience than I would have. The CV axles on a 4x4 compatible kit should have been figured out long before they released the kit. Thats part of the R&D process right?? If they want to be taken seriously alongside Total Chaos and Camburg they need to figure this out.
    I hope they take care of you and btw your truck looks great with those Walkers.
  5. Aug 6, 2010 at 3:22 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    Yea, but im technically a guinea pig so i got my kit pretty cheap, so it's a price I have to pay....im a really patient guy, plus Hassim is nice and is fun to wheel with, he takes care of his customers
  6. Aug 14, 2010 at 4:24 PM
    ks2socal
    ks2socal [OP] Member
    Crew cab or access cab, any severe limitations on the rear end with either?
    Im still not sure on the 2nd gen or 1st gen yet either.
    It seems that I should do a good amount of gusseting and reinforcing, maybe even make an engine cage. Is there anything else prone to breaking?
    Remember I dont really want to "Huck" the truck.
  7. Aug 14, 2010 at 7:25 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Chandler, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    If you get a second gen buy the Total Chaos Cam Tab things. My buddy flattened his crawling. I flattened mine in the desert but they don't make them for 1st gens so I have to make my own. Those are used to keep alignment and to get into alignment.
  8. Aug 14, 2010 at 7:40 PM
    SKINUM
    SKINUM Well-Known Member
    Garry
    Va/Tn/KY border
    07 FJC
    a lot!
    How are u all flattening those alignment tabs? I could see how it would happen I guess but doesn't seem like it would be easy to do.
  9. Aug 14, 2010 at 7:45 PM
    amaes
    Alex
    Chandler, AZ
    2011 FJ Built
    those things are only 1/8" bent steel so if you tire hits anything pretty good. I.E. Rocks, holes, bumps it will bend those. I guess a cheap solution would be to weld behind them. Basically made a little wall of steel behind them for strength.
  10. Aug 14, 2010 at 7:48 PM
    SKINUM
    Garry
    Va/Tn/KY border
    07 FJC
    a lot!
    Ohhhhhh, so it's not something physically hitting the tabs. It's the impact they take from the tires hitting something and being transferred through.
    I've been doing some slow wheeling for quite a while and have never bent one of the tabs. I guess if you have a little speed then that could certainly cause a problem.
  11. Aug 14, 2010 at 7:51 PM
    amaes
    Alex
    Chandler, AZ
    2011 FJ Built
    I'll take a picture of mine because I'm still cutting out my steel to make new ones. I'm not talking about the circle things but the tabs on the sides of them. Just making sure we are talking about the same things.
  12. Aug 14, 2010 at 7:55 PM
    SKINUM
    Garry
    Va/Tn/KY border
    07 FJC
    a lot!
    K........I was thinking about the circular tabs. Got ya now! :D
  13. Aug 14, 2010 at 7:59 PM
    amaes
    Alex
    Chandler, AZ
    2011 FJ Built
    Got it haha I figured you were so thats why I wanted to make sure we were talking about the same things.
  14. Aug 15, 2010 at 1:40 PM
    SiRMarlon
    SiRMarlon The Photo Ninja!
    Marlon
    Los Angeles
    Canon 5D MarkIII
    The All-Pro kit was designed with crawling in mind in my opinion...it's a well balanced kit perfect for crawling and does just fine in the high speed stuff...:D Just ask me and my brother! Or Tom (MonkeyProof)
    Crawling with SUA...
  15. Aug 15, 2010 at 1:56 PM
    #35
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    that double cab is crawling w/ spring under and bedcage, front and rear glass and a prerunner bumper... i like it.
    you dont see that very often
  16. Aug 15, 2010 at 2:08 PM
    #36
    SiRMarlon
    Marlon
    Los Angeles
    Canon 5D MarkIII
    Jon has probably Rock Crawled that truck more then he's done high speed stuff! :D
  17. Aug 15, 2010 at 4:47 PM
    #37
    ks2socal
    Thanks for the awesome pics! That SUA flex is pretty nice:D
    The all-pro kit seems to be the most verastile and also least likely to lead me down the never ending rabbit hole of beefing up every last part on the truck:p
  18. Aug 15, 2010 at 5:50 PM
    #38
    SKINUM
    Garry
    Va/Tn/KY border
    07 FJC
    a lot!
    Beefing up every last part is inevitable. :D
  19. Aug 15, 2010 at 6:19 PM
    #39
    TRDguyKC
    TRDguyKC Well-Known Member
    Kris
    Glendale, AZ
    subscribing. I hope to afford LT one of these days.
  20. Aug 15, 2010 at 7:04 PM
    #40
    mjp2
    mjp2 Living vicariously though myself Moderator
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Join the club! I have the LT and now get to work on that whole "affording" it thing. ;)
