Munkels Build
Discussion in '1st Gen. Builds (1995-2004)' started by munkel, Apr 11, 2014.
  1. Apr 11, 2014 at 12:17 AM
    munkel
    munkel [OP] fka unregistered lurker...
    PDX
    2004 Dbl Cab V6 4WD Tacoma
    Icon Suspension, 285/75/16 BFG MT's, Steeeckers, Custom Bed Mounted Tool Storage, Wilderness Trail rack, SoftTopper, K&N CAI, Hella Aux lights, PIAA Fogs, Warn M8000, Elite Front Bumper, BAMF sliders, All-Pro leafs and shackles
    Figured I may as well throw up a build thread now that I am making some progress on my rig. Bought my 2004 used in 2006 on New Years Eve, was hoping to squeak a few extra dollars out of the dealership before the end of year. Truck was stock except for a K&N CAI and a Vortex throttle body spacer. The bed must have been scratched up as they had just had it sprayed with Rhino liner or the equivalent.
    Engine/Drivetrain:
    3.4 V6
    Automatic
    K&N CAI (on when purchased)
    Vortex throttle body spacer (on when purchased)
    Stock gearing
    Suspension:
    Icon Coilovers Standard travel
    REMOVED - Icon External Reservoir rear shocks
    REMOVED - Icon AAL
    REMOVED - All-Pro 3" leaf pack
    OME Dakar Leaf pack
    OME D6XL AAL
    REMOVED - All-Pro 1.5" shackles
    Daystar 1.25 inch shackles
    BAMF BPV bracket
    Wheelers extended rear brake line
    Wheelers front brake lines
    Trail gear U-Bolt flip kit
    4 Crawler axle relocate
    Front diff drop
    OME sport rear shocks - relocated with new crossmember
    REMOVED - Timbrens rear bumps (too big IMO)
    Wheels/Tires:
    285/75/16 Duratracs
    Stock spare steelies painted black
    1.25" BORA/Motorsport Tech wheel adapters
    285/75/16 Duratrac spare
    Armor/Protection:
    Elite front winch bumper with local fabricator added hoops
    BAMF kick out sliders
    Crawl2Run Skids
    CBI rear swingout bumper with Scepter gas can, Hi-Lift, fold out table, shovel
    Interior Misc:
    RAM mount GPS windshield mount
    iPhone windshield mount
    two fire extinguishers mounted beside rear seats
    Wet Okole seat covers front/rear cordura seat cover
    Wheelskins perforated steering wheel cover
    seat belt cutter/glass breaker mounted on drivers door inside
    Maglite
    Paranoid Fabrication 6 switch under stereo mount for switches
    Exterior Misc:
    40mm? ammo can secured to bed and locked closed for recovery gear and flares
    REMOVED - Delta 32" truck box for tools, spare CV etc
    47" toolbox in rear or bed
    Small air compressor VIAIR 85P
    Softopper soft top canopy
    Wilderness trail roof rack
    4 TREDs mounted on roof rack (now in toolbox)
    Yakima roof rack bars
    Grillcraft grill
    Trail gear rear frame plates welded on
    Trail gear rear box kit plates welded on
    Lighting/Electrical:
    Rats nest of wiring under hood
    REMOVED - PIAA fogs in bumper
    AVEC Optiks series spot lights in front bumper
    REMOVED Hella 700FF lights on bumper with 130 watt bulbs
    AVEC 19" lightbar on front bumper
    Hella Module 70 back up lights in rear bumper
    REMOVED Hella Module 70's on roof rack pointed to rear/side
    AVEC 6 LED pods on roof rack pointed to rear/side
    In cab winch controls
    OTRATTW laser etched switches
    Pioneer HU with dual usb input, iPod and iPhone
    Uniden 520XL CB in ashtray location
    4' Firestik antenna
    dual power outlets in bed (now in toolbox)
    Inverter
    REMOVED - SlimCubby HID's
    REMOVED - AVEC LED headlights
    REMOVED - Sylvania SilverStar headlights
    Philips X-treme Ultinon LED Bulb headlights
    AVEC LED turnsignals, brake lights, 3rd brake lights, parking lights, reverse lights, dome lights, nav lights
    Recovery Gear:
    Tree strap
    Tow strap
    Snap recovery strap
    Warn M8000 winch
    Steel hawse fairlead
    Multiple sections of chain
    Snatch block
    shackles - 8-10 too many :D
    rear receiver shackle mount
    48" Hi Lift
    Shovel
    Axe
    Tire plug kit
    Future Plans:
    4 crawler 1" body lift, sitting in box in garage....
    Skygear Bussman relay/accessory fuse box, sitting in box in garage
    Paranoid Fabrication bussman mount plate for 1st gen, sitting in box in garage
    MilSpec battery terminals, sitting in box in garage
    Breaker for between battery and bussman box, sitting in box in garage
    5 gallon Scepter plastic jerry can for water for bed of truck with mount
    Most recent pics:
    The day I brought it home:
    Quickly making sure my measurements at the dealer were correct and that my bike would fit. :)
    Getting my dogs seal of approval!
    A set of Icons a few years later and a AAL kit for the stock leafs.
    A pic after the install...
    Little removable toolbox setup for the bed, turned out pretty well.
    A little taste of sand, had the bike for the day so it got the abuse not the Taco.
    Got a Grillcraft grill and blacked out the chrome grill surround.
    Picked up a used black canopy for the truck....
    So I had to transport the bike a different way...
    New All Pro 3 inch pack to replace the saggy rear end, even with the Icon AAL it was sitting too low, especially when the bike was on the back.
    Pretty soon the AP pack was sagging really bad and threw on a longer AP shackle set to try and make it last a bit longer.
    Traded in my Yakima rack for a Wilderness trail rack and flush mounted it on the roof. Added some Hella lights facing sideways and towards the rear.
    BAMP sliders primed up and ready to paint...
    Painted and installed... with a softopper replacing the fiberglass canopy.
    BAMF BPV bracket helped a lot.
    Elite front bumper, painted and set up with a new winch and PIAA fogs.
    Holee Shit that was one heavy sumbitch to mount up!
    Added a few Hella light to the top of the bumper and got my CB antenna mounted.
    Decided I needed a good switch setup so I ditched the factory stereo and got a nice Pioneer and then fabbed up a plastic switch plate for under the new stereo. Ordered some sweet switches from OTRATTW,com.
    Bought a used rear bumper and sanded, painted and drilled a few holes for some Hella backup lights.
    Bought a set of stock base model Tundra wheels off Craigslist for real cheap, same wheel as the stock spare.
    Sanded, painted, mounted up with my BFG MT's
    Wheelskins steering wheel cover, feels a lot better than the stock wheel.
    Kept rubbing the rear of the fenderwells when getting close to stuffing the rears, decided something needed to change.
    Rear was sagging badly with any weight in the back and especially with the bike on the hitch. Decided to order some new leafs.... Last pic before the new leafs.
    Dakar leafs and OME rear sport shocks with the AP shackles.
    A set of Timbrens off craigslist, probably to be replaced by something else later on that's smaller.
    New hoops for the Elite bumper from my local fab shop. (Saw Ponethousands and PCBuilders and had to copy them)
    While I was at the shop I had them reinforce the rear end in anticipation of my new bumper that should be here soon. Also had them weld in a tube and mounts top and bottom for the rear shocks. (mounting location stolen from BoxRocket)
    Random shot from this winter, was driving every day and the ice just kept building up and melting off.
  2. Apr 11, 2014 at 11:02 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Good looking rig!
  3. Apr 12, 2014 at 10:25 PM
    munkel
    PDX
    Thanks Lumpskie!
  4. Apr 13, 2014 at 6:06 PM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    Holy shit! I'm pretty sure that was you I saw today at Santiam Bicycle shop next to Washington Square mall..And I purposely drove by you to take a closer peek as I drove off. I knew that truck looked familiar. Hope that was you lol you were wearing an Icons shirt? I was wearing the cargo shorts with Air Jordan t shirt with my daughter, went back inside the shop because I forgot my sunglasses on the helmet box :wave:
  5. Apr 13, 2014 at 6:17 PM
    GATORTACO92
    GATORTACO92 Well-Known Member
    Alex
    Hoover, Al
    2004 F-350 6.0 King Ranch
    2004 F-350...uh lots of motor work to go fast...er. Way to much to list. 2001: 3" leveling kit, ARB bumper, lightforce 240 blitz, 35" KM2s. SOLD 2008: OME 886s 90000 with dakars, LR UCAs, 5% tint, Satashi. SOLD 2015: Flooded and Gone
    Very clean 1st Gen!
  6. Apr 13, 2014 at 6:22 PM
    munkel
    PDX
    Yeah, that was me, I saw your truck driving by as you were leaving, told my wife you were on TW. She had seen you in the store. Buying my 2 year old a balance bike.
  7. Apr 13, 2014 at 6:23 PM
    munkel
    PDX
    thanks!
  8. Apr 14, 2014 at 7:32 AM
    JoeTacoma02
    Right on man. Don't know why I didn't put 2 and 2 together, I just knew I've seen your truck somewhere before. I had to upgrade my daughter's helmet since she outgrew her old one and target has funky designed ones so we stopped by there. You go to that shop often? The guy who helped me seemed so excited to help us choose our helmets :rolleyes:
    Anyway, nice truck man! Looks 10x better person.
  9. Apr 14, 2014 at 9:43 PM
    munkel
    PDX
    I had never been there before, never knew it existed. Wife found it online and we rolled in. Saw you and your daughter come in and leave really quick and thought it was odd. Didn't see you grab the glasses though. Didn't notice your truck until it was driving away, just got a look at the rear end.
  10. Apr 26, 2014 at 9:20 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    nice truck!! did you go w/ the high clearance CBI? you no has skids?
  11. Apr 26, 2014 at 9:34 AM
    Hockeyman90
    Hockeyman90 Well-Known Member
    Kaleb
    Craig, Co
    2001 Gold SR5
    Custom front bumper, bed liner, 33" wrangler duratracs on 16" ATX series Mojave rims, OME 3" suspension, 882 coils, custom rear bumper
    Very nice double cab.
  12. Apr 27, 2014 at 9:55 PM
    munkel
    PDX
    Thanks guys, no skids yet, after electrical cleanup then skids. I got the regular outback with swingout, table, cutouts for backup lights and single can carrier. Hi lift mounted to it as well. All painted and bolted up and made its maiden trip this weekend. Just need to download pics.
  13. Apr 30, 2014 at 10:14 PM
    munkel
    PDX
    Few pics from last weekend, little camping trips with bikes.
  14. May 15, 2014 at 5:49 PM
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    Subbed, really like it man.
  15. May 15, 2014 at 9:29 PM
    munkel
    PDX
    Thanks John!
  16. May 16, 2014 at 9:48 PM
    munkel
    PDX
    Pulled the rack and soft topper off to wash it up for summer, hadn't washed it in a very long time, took a few pics along the way.
  17. May 18, 2014 at 8:43 PM
    TacomaYeti
    TacomaYeti WEST KY YOTA'S
    Reed
    Kentucky
    03 Double Cab TRD v6
    hey bud, I just got the exact same truck and i want to lift it..i have never lifted a truck or tacoma..could you give me a list of what all i need to get a 3 inch lift or what you have?
    thanks, reed
  18. May 18, 2014 at 9:16 PM
    munkel
    PDX
    that is a tough question as there is 100+ different ways to lift a yota. There is a ton of lift threads on here, check there for some different options.
    What I have is the following for my lift:
    Icon Coilovers for the front
    Old Man Emu sport shocks for the rear
    OME Dakar rear leafs with add a leaf/overload
    1.5 inch all pro shackles
    longer rear u-bolts
    I have also done other modifications to get that combo to work for me like weld in a crossmember and relocate the rear shocks.
    Keep in mind anything you do will be affected by adding armor or other weight, so if you get front shocks/coilovers etc and you plan on getting a bumper/winch then get stiffer springs, same for the rear. If you didn't get a rear bumper then you might not need the AP shackles or overload leaf.
    If it were me and I were just getting my truck and I know what I know now I would get a package deal on an old man emu/dakar package from Kurts cruiser outfitters or wheelers in grants pass. Call up either of those places and tell them what you intend on doing, hauling, modding and they can give you a few different options. Something like Icon being the most expensive and OME being more reasonable but still more then a crappy spacer lift, don't do that.....
  19. May 19, 2014 at 7:02 AM
    TacomaYeti
    Reed
    Kentucky
    thanks man that helped tons
  20. May 19, 2014 at 7:06 AM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Sweet looking truck!
