Must fill gas tank very slowly or gas pump handle will kick off.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 02RedDoubleCab4x4, Oct 7, 2020.
  1. Oct 9, 2020 at 12:22 PM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    My lady’s Audi does that dumb crap
  2. Oct 9, 2020 at 12:23 PM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    I’ve found that only putting the gas handle to the first stop helps
  3. Oct 9, 2020 at 6:31 PM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    this was my issue when I had OP’s problem. Replaced with an OEM canister and it’s been issue free ever since.
    eon_blue[QUOTED] likes this.
  4. Oct 9, 2020 at 6:38 PM
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Sometimes vent hose at filler tube gets blocked up... cheapest bet Is to access it and blow air through it...
  5. Oct 10, 2020 at 10:06 PM
    locutus43
    locutus43 Active Member
    theres also a vent roll over valve if thats stuck then that would cause that too you need to lower the tank and install it its a pain to do had mine done when my smog stuff was done
  6. Oct 25, 2020 at 11:45 AM
    02RedDoubleCab4x4
    02RedDoubleCab4x4 [OP] Well-Known Member
    Sumter, SC
    02 Double Cab
    Rough Country 6", 2" blocks, 3 Inch Body, 15x8 with 35x12.50 General AT2
    Black DOG Lila thank you for the suggestion, Tacoma World members are helpful and share knowledge. I replaced the fuel check valve and can now fill the tank with the gas pump handle locked on the first notch.
    I have a 3 inch body lift so I did not have to drop the tank or lift the bed up.
    https://www.youtube.com/watch?v=D-HPp2-_PFM&app=desktop
  7. Oct 25, 2020 at 12:22 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Good to hear you got it fixed.
    Your video won't play due to owner's setting to not share over other sites.
  8. Dec 29, 2020 at 10:56 PM
    bluewave
    bluewave Well-Known Member
    Hawaii
    SR5 Tacoma
    I’m having this same issue after letting someone siphon gas from my 2017 Taco after someone who ran out of gas , is there a fix for this without replacing the gas filler neck, there is no warning codes..
  9. Dec 30, 2020 at 4:47 AM
    Black DOG Lila
    Virginia
    Replace the roll over valve at tank.
