Must "to do's" on my new TRD Pro
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eleveneleven, Jan 18, 2017.
  1. Jan 18, 2017 at 11:16 PM
    eleveneleven
    eleveneleven [OP] Member
    SF Bay Area
    2017trdpro
    Hello TW,
    I just joined this forum and expecting delivery of my 2017 TRD Pro A/T in early Feb 2017. After reading some threads, I have a mental list of some things I need to do immediately and have some questions. Additionally, I wanted to know if I'm missing anything or if the issue no longer needs to be addressed (I noticed some of the threads started over a year ago and couldn't figure out if Toyota has fixed it). I understand I could probably get all my answers if I review all the related threads, so I'll apologize ahead of time if I'm not following proper forum etiquette.
    What I'm hoping for is a simple list of things I need to do, I figure it should be a short list considering it's a Tacoma, right?
    Oh, I should mention I'm "trying" to keep the vehicle more or less stock, so the below list is my simple understanding of things that should be done to ensure the vehicle performs as designed.
    Thanks in advance for any responses.
    1. Check the automatic transmission fluid - I plan on just doing this myself by getting the fluid to the correct temp, then filling it to the correct level. I remember reading deep in the main related thread regarding this issue, that this seemed to be the easiest way to deal with this issue, is that right?
    2. Purge and fill the Zerks at the u-joints.
    3. TSB-whatever to fix the automatic transmission "trying to search for gears" issue. I'm assuming TSB stands for Transmission Service Bulletin? Do I have to first see if my vehicle displays such behavior then take it back in to the dealership to get the ecu flashed? Or can I just request it get flashed before I pick it up? Or, are newer vehicles no longer experiencing this problem? Additionally, I've read somewhere that the vehicle learns how you drive for the first number of X miles, if this is the case, do I need to wait until this is over before seeing if my vehicle has this problem? How does driving it with the ETC mode "on" effect all of the above. Lastly, assuming I do need the TSB, what number is it? If you know it off the top of your head, please share. I'm that lazy ...
    Thanks again
  2. Jan 18, 2017 at 11:19 PM
    Razgriz1
    Razgriz1 Well-Known Member
    Southern California
    2017 Toyota Tacoma TRD Pro Cement 6MT
    Welcome to TW!
    First thing to do is lube dat butthole up, cause people here REALLY don't like Pros.
    A Salt Weapon likes this.
  3. Jan 18, 2017 at 11:20 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    No, just 3rd gens in general.
    Welcome to the show OP.
  4. Jan 18, 2017 at 11:24 PM
    eleveneleven
    SF Bay Area
    2017trdpro
    butthole lubed, got it. Will apply when doing the zerks.
    Thanks
  5. Jan 18, 2017 at 11:27 PM
    kuuk
    kuuk Active Member
    SF Bay Area
    2017 trd off road 4x4
    4. get a pro grill, ah nevermind it already has it
  6. Jan 18, 2017 at 11:27 PM
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    1. I had the dealer do this and provide a written report before I accepted my new truck. It's part of the pre-delivery service so they should be doing it anyway. Feel free to check yourself, but it's really their job.
    2. As above, I asked them to do this and provide a report.
    3. It's Technical Service Bulletin (TSB). They're released when a problem is identified across a product line but a recall isn't warranted. I simply asked them to flash the ECU to the latest version and provide a written report, which stated that my 2017 already had all updates installed.
    ETC mode won't hurt anything. It's only there to provide better MPG numbers on the EPA test.
    Apd and eleveneleven[OP] like this.
  7. Jan 18, 2017 at 11:32 PM
    Apd
    Apd Well-Known Member
    707
    Check all the fluids and grease points. A lot of complaints about that lately.
    eleveneleven[OP] likes this.
  8. Jan 18, 2017 at 11:40 PM
    A Salt Weapon
    A Salt Weapon Well-Known Member
    T
    Southeast Alaska
    2017 Blue DCSB TRD OR
    This step would become get rid of the pro grill then right?
  9. Jan 19, 2017 at 4:42 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    justinalldredge19 likes this.
