Muth Mirror w/heating element
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRD Larry, Oct 29, 2008.
  1. Dec 3, 2008 at 7:22 PM
    moserjjx
    moserjjx Tacoma Newbie
    Eau Claire, WI
    08 DC TRD 4x4
    Weathertech liners, bed mat, rear spring TSB, extra 12V outlets in center console, seat belt chime off
    4 terminals? interesting - do you have a wiring diagram of how the fogs are wired? how is the stock switch with the kit wired - 1 ground and 2 12V (1 for the light)?
  2. Dec 3, 2008 at 7:25 PM
    TRD Larry
    TRD Larry [OP] trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    Don't have a wiring diagram. The fog light switch lights when the lights are on and dims with the rest of the lights, plus works the fog lights on/off. Without a diagram it work be hard to trace the wiring. Not sure it a Toyota dealer would be helpful.
  3. Dec 3, 2008 at 7:31 PM
    moserjjx
    Eau Claire, WI
    08 DC TRD 4x4
    i found a wiring diagram online and found the fog wiring but i'll have to study it more to determine exactly how it works. i'll also take a look at the fog light mod on here for insight
  4. Dec 3, 2008 at 7:42 PM
    moserjjx
    Eau Claire, WI
    08 DC TRD 4x4
    found this about 2/3 way down
    http://www.yotatech.com/f135/fog-light-switch-92093/
    it might shed some light on how to use that switch. i don't have the kit so i can't help any further but if you post or send the wiring instructions from the heated kit i can take a look
  5. Dec 4, 2008 at 4:06 PM
    TRD Larry
    Larry
    South Park, PA
    Thanks for the help. Checked out the link and it had the wiring instructions for the 4 prong switch. I need to look at the wiring diagram for the heating module and see if I can get it to work. My only concern is if I hook it up wrong I might blow out the heating relay.
  6. Dec 4, 2008 at 4:28 PM
    moserjjx
    Eau Claire, WI
    08 DC TRD 4x4
    I'd like to see that wiring diagram too so if you could email it to me that would be cool. if you're up for that, i'll PM you my email addy. thanks!
  7. Dec 4, 2008 at 4:51 PM
    craigFLA
    craigFLA Well-Known Member
    Ft. Lauderdale, Florida
    Tacoma TRD Sport Pkg.#1, XSP Package
    Leather, 20" rims, Borla cat-back exhaust, running boards, back up camera/3" screen in rear view mirror, carbon fiber interior trim. Tow Package. MODS: URD intake BHLM. Tinted tails & 3rd brake light Fog Light mod. 5pc Grill Craft (High Gloss Black powder-coat) T-Rex eye-lids AVS Wind Deflectors 3M Window Tint 15 front/30 rear OBX Sports Pedals Viper 5901 / remote start Pioneer AVIC F90BT-NAV Hybrid L8's in doors, L4's and Dynaudio MD102 tweets in custom kicks, morel rear-fill, JL TW5-13" sub, JBL MS-8, 2@Tru B475, Tru 4.65, PPI a600.2, PPI 456 X-over, Raamat BX2 and ensolite. relocated rear seats 3/4" Retrax cover electric dual "dead-bolt-lock" electric tailgate lock. electric Dynalock for Retrax Cover/custom fabricated case. kinetik second battery/power-gate isolation. Powerslot Cryogenic rotors, Hawks HPS Pads, SS lines,painted calipers&drums FULL trans flush mod OE Denso plugs
    Thanks for the link, I havent "read up" yet, but will consider this a valid option for some of my "in progress" mods.
  8. Dec 4, 2008 at 5:36 PM
    TRD Larry
    Larry
    South Park, PA
  9. Dec 4, 2008 at 5:38 PM
    moserjjx
    Eau Claire, WI
    08 DC TRD 4x4
    gosh darn it i fell silly now for not checking first. my bad. thanks though!
  10. Dec 7, 2008 at 11:50 AM
    TRD Larry
    Larry
    South Park, PA
    Want to finish this thread I started. I finallly completed the mirrors install. I had problems with the Tacoma Fog light switch when trying to wire it up for the heated mirrors. So I used the switch that came with the mirrors. I drilled out the center of the blanks and mounted the mirror in the blank. I included a picture of the switch.
  11. Dec 7, 2008 at 11:54 AM
    TRD Larry
    Larry
    South Park, PA
    I type as bad as I talk. What I mean to say is I mounted the switch in the blank, not the mirror.
  12. Dec 17, 2008 at 9:05 AM
    Teufel Hunden
    Teufel Hunden No Better Friend, No Worse Enemy
    Northern Virginia
    09 MGray DC SB TRD-OR 4x4 V6 Auto SR5
    Undercover tonneau, OEM tow package with hitch, OEM retractable roof rack, Front window tint (legal), WeatherTech FloorLiners, Door sill protectors, Tacoma bed mat, Rear leaf spring TSB, OEM DRL mod, Door edge guards, AFE Pro-Dry S Air Filter, Removed secondary air filter, Smoked LED 3rd brake light, Romik running boards, Go Rhino hitch step, Extra set of D-rings mod, Bed cargo net, TRD wheel locks, OBX sport pedal covers.
    I am installing my Muth mirrors with this toggle fog light switch that you were talking about. You mentioned that you got the old toggle switch to work before you decided to change to the push switch. Do you remember which wires go to which terminals on the toggle switch? Thanks in advance for any help you can give!
  13. Dec 17, 2008 at 8:05 PM
    TRD Larry
    Larry
    South Park, PA
    Was not able to get the stock tiggle switch to work correctly, that is why I switched to the swiitch that came with the mirrors. Not sure if the switch I had was bad, when i tested it i could not get the light to shine very bright anf tthe heating element would not function. I have not found anyone that used the stock switch to power the mirrors. I plan on getting another switch and try it again.
  14. Dec 18, 2008 at 1:15 PM
    Teufel Hunden
    Northern Virginia
    Thanks for the information. If you do get another switch, please let us know how it goes. I am still very interested in doing this if it's possible.
  15. Jun 27, 2009 at 6:49 AM
    #35
    avettese
    avettese Member
    I got myself the Muth mirrors, but would also like a better switch. I see that TRDlarry was looking for the same thing. Did anyone ever find one? I was wondering if a rear window defroster switch from maybe a camry would work. Also, I did find that these Muth mirrors do not use all the factory mounting/stabilization features of the stock mirrors and I find that there are some vibration issues at around 75-80MPH. I suspect that the 2 metal fingers that are on the stock mirrors, need to be somehow integrated inot the Muth mirrors. I may do this at some point, but I'd like to get the mirrors installed and working before I mess with them.
  16. Jun 27, 2009 at 9:34 AM
    #36
    TRD Larry
    Larry
    South Park, PA
    I have no vibration issues with my mirrors. I travel the interstate every day back and forth from work at 70 85 mph and have no issues with the mirrors.
  17. Jun 27, 2009 at 11:35 AM
    #37
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Aww damn, I completely forgot, I was going to build a system like this ages ago for mine!
