Muti-terrain select. What mode do you use for snow?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jukeboxx13, Jan 1, 2017.
  1. Jan 1, 2017 at 3:32 PM
    Jukeboxx13
    Jukeboxx13 [OP] Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    I was using Mogul in my TRD OR 4x4 but dont know if that was correct so switched to mud and sand.
    What mode are you guys using or recommend?
  2. Jan 1, 2017 at 4:24 PM
    beyer075
    beyer075 Rock Licker
    Northern Nevada
    2016 White TRDOR
    I had settled on the mud/sand option since that seems to the lowest traction option. Though I only tested it in some deep snow/ice and had never needed it yet.
  3. Jan 1, 2017 at 5:02 PM
    Johnny919
    Johnny919 Well-Known Member
    Long Island, NY
    2006 Honda Pilot EXL 4WD
    The mud and sand mode would be the best option for the snow. The road conditions says "suitable for muddy roads, sandy roads, snow covered roads, dirt trails and other slippery or dirty conditions."
    Starting at page 255 of the owners manual will give you more information on the multi terrain select.
    TacoPandaTRD, SuperBad and Hobbs like this.
  4. Jan 1, 2017 at 5:06 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    mud and sand
    in the owners manual it actually mentions for snow
    SuperBad and PROseur like this.
  5. Jan 1, 2017 at 5:14 PM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    I wish multi terrain select worked in 4hi
    TacoPandaTRD, breader3 and Joe23 like this.
  6. Jan 1, 2017 at 5:16 PM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    I think you need to adjust it for whatever snow conditions you actually have. Right now I've got 2" of crust on 10" of sugar. Start off with Mud and Sand and adjust from there.
    From the manual:
    When it is difficult to generate traction“MUD & SAND” mode provides the largest amount of tire slippage, followed
    by “LOOSE ROCK”, “MOGUL”, “ROCK & DIRT” and “ROCK” mode.
    If the current tires slip is too large, driveability can be improved by selecting a mode with a smaller slip amount. Conversely, selecting a mode with a larger slip can improve driveability, if the current tire slip is too small.
  7. Jan 1, 2017 at 5:20 PM
    RIDERED67
    See i really don't understand how you guys would ever use 4lo for snow?
    musicisevil, Wdwrkr and ZachMX like this.
  8. Jan 1, 2017 at 5:22 PM
    Sagebrush
    Gens 1, 2, 3, and 4
    When it's too deep or steep for 4Hi. I was pushing snow and bouncing today.
    SB
    BC Hunter likes this.
  9. Jan 1, 2017 at 5:26 PM
    su.b.rat
    su.b.rat broken truck
    Auto lsd activates in 4lo and will likely help a lot getting started from a stop. the auto lsd actuates the spinning wheel's brake in the rear to get torque to the ground.
  10. Jan 1, 2017 at 5:30 PM
    Joe23
    Cottage country.
    Come through winter months my buddy's place cannot be reached without 4x4 and usually 4lo since it's deep heavy snow.
    Can maybe get in in hi but you're not getting out as it is up hill
    BC Hunter and JoeCOVA like this.
  11. Jan 1, 2017 at 8:22 PM
    Jukeboxx13
    California
    I had a feeling mud and sand mode would be best.
    I used 4lo cause it was my 1sttime weeling in snow ever and there were a lot of hills. Soon after though 4 hi worked just as good even with the stock Goodyear Wrangler Adventure tires. I want to say it was about a foot of snow as well.
    Thanks for replies
  12. Jan 1, 2017 at 8:46 PM
    browndirtcowboy
    browndirtcowboy Well-Known Member
    Manteca
    Really depends on what kinda snow. if you have about a foot or 2 of powder I wouldn't use 4lo to use any terrain select I'd use 4 hi. Need momentum.:mudding:
    musicisevil, Silentshredr and Joe23 like this.
  13. Jan 1, 2017 at 11:28 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    You guys actually need to use crawl control? Haa-ha, learn how to use 4WD. Crawl control is for those who don't know how to drive.
    specter208 and Aviator6 like this.
  14. Jan 1, 2017 at 11:56 PM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    I use 4H and the gas :p.
    I'm actually skeptical that Crawl Control would be useful in deep snow when you need momentum to keep you going.
    Aviator6 likes this.
  15. Jan 2, 2017 at 6:28 AM
    Camel89
    Camel89 Well-Known Member
    Houston, TX
    2016 TRD OR 4x4
    MTS is different from crawl control. With MTS you still need to control the gas and brake, it just limits wheel slippage.
    No need to be jealous because you don't have it :boink:
    I have it but I have no use for it under normal driving conditions, and sometimes I wish I did:annoyed:
  16. Jan 2, 2017 at 5:12 PM
    Stockotaco
    Stockotaco Well-Known Member
    Ben
    2016 Inferno TRD Off Road 4x4 w/man pedal
    All Stock
    So are auto trannies!:burnrubber:
    xman68 and PROseur like this.
  17. Jan 2, 2017 at 5:21 PM
    Jukeboxx13
    California
    1st 4x4 ever so yea I dont know how to drive, but I do drive a big rig on the weekdays, and back in to tiny lil warehouses all the time.
    kg206 and trabo like this.
  18. Jan 2, 2017 at 5:22 PM
    Jukeboxx13
    California
    It was my first time in snow, so its basically like mud then since you need the momentum. Hence why mud and sand mode works best in the snow.
    thanks
  19. Jan 2, 2017 at 7:50 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    To me crawl control and mts are neat toys. It far often than not a good driver can do just as well. IMO 4lo is only useful on icy situations or hard pack polished snow. At that point chains would be more effective than anything else.
    Deep snow requires more aggressive tires to dig and hard pack requires more siping. Brakes are your friend to control wheel spin and help to keep both tires on an axle moving equally where open diffs would allow one tire to spin uncontrollably.
    Now LSD, lockers, MTS and crawl control help the inexperienced to survive where their knowledge is lacking. I still feel learning solid off road techniques helps everyone and really helps understand what these new technologies are actually doing. You need to know what is going on in order to know what you need to do.
    Over a number of years going off road with an old clapped out Jeep YJ with the right setup I was going places that guys with $60k in upgrades were going. So learn to drive off road and stop wondering if that one button or one setting is the difference. Other than different tires or a front locker a stock Tacoma is pretty capable without getting lost in the gadget details. Drive. Drive some more. Keep driving and try to learn what your tires are telling you. Get a set of steel wheels and aggressive tires and try some more.
    over60, Camel89 and Aviator6 like this.
  20. Jan 2, 2017 at 8:04 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I can't remember his name but he posted some videos of crawl control in snow in Alaska. Worked perfect.
