MWM BAJA 12 BUILD
Discussion in '2nd Gen. Builds (2005-2015)' started by MWM BAJA 12, Feb 4, 2014.
  1. Feb 4, 2014 at 2:05 AM
    MWM BAJA 12
    MWM BAJA 12 [OP] Well-Known Member
    Micah
    Dallas
    2012 "Baja" Edition BLACK
    see my build page
    egy2uqu8_4a5f07731d6b66d42675e0f5237fdb111d57ddbd.jpgru8aqu4u_4f3114ebd2b0367fd3e81df9f4a2013c5da4ea9d.jpg
    tacofinal1.jpgtacofianl2.jpgtacofinal3.jpg002.jpg tacomaworld1.jpg tacomaworld2.jpg 005.jpg tacomaworld3.jpg 004.jpgw8.jpg[ light switch (3).jpg light switch (2).jpg light switch (1).jpg 001.jpg 003.jpg light kit3.jpg light kit2.jpg tacolight3.jpglight kit.jpgw1.jpgw2.jpgw3.jpgw4.jpgw5.jpg[w6.jpgseatcover.jpgheaterswitch.jpg
    Interior:
    - 2014 Navigation Unit
    - Wet Okole seat covers front & rear
    - Seat Heaters (EBay)
    - Custom Overhead Switch Console by KNine00
    - Midland 75-822 40 Channel CB Radio
    - Scangauge II
    - Valentine-1 radar detector with hidden mount behind rearview mirror and hard wired
    - Weathertech Extreme-duty Floor Liners (Black)
    - Custom CarGrills Perf SS Black "Satoshi" Grill Mod
    Suspension:
    - KING 700# Extended Travel Front Coil-over Shocks w/ Adjustable Remote Reservoir
    - Total Chaos Upper Control Arms
    - Dakar Leaf Springs (CS047R x 2)
    - KING Extended Travel Rear Shocks w/ Remote Reservoir
    Armor:
    - Pelfreybilt front plate bumper w/ full hoops
    - Pelfreybilt IFS skid
    - Pelfreybilt Mid skid
    - Pelfreybilt Transfer Case skid
    - Pelfreybilt Gas Tank skid
    - Pelfreybilt welded sliders with kickout
    - Pelfreybilt High-Lift rear bumper with swing gate tire with high lift/rotopax mount and fold down table
    - Pelfreybilt Custom Bed Rack w/ rotopax and ax/shovel mounts
    - B.A.M.F. LCA skids
    Lighting:
    FRONT
    - Rigid Industries SR-20" Combo w/ amber covers
    - Rigid Industries Dually white LED fog lights w/ amber covers
    - Rigid Industries D2 Hyperspot Ditch Lights
    - Plashlight 40" Combo
    REAR
    - Rigid Industries SR-Q Flush Mount Backup Light Kit
    INTERIOR
    - Csjumpers LED lights EVERYWHERE
    EXTERIOR
    -Vision X Rock Lights
    Under The Hood:
    - BeeRadd Under Hood Light Kit
    - RedLine Hood Quick Lift Elite
    - CustomCar Grillls with TOYOTA Raptor Letters
    - Blue Sea Systems 5026 Blade Fuse Box
    - Blue Sea 7187 100 AMP Circuit Breaker Surface Mount
    - ARB CKMA12 Air Compressor
    Performance:
    - TRD Exhaust (cut after the rear axel and tip re-welded at the bend)
    - Airflow Snorkel
    - AFE Drop in filter
    Wheels & Tires:
    - 285/75 16 BFG Mud Terrain tires on 16-inch gunmetal gray beadlock-style wheels
    - SPARE on Swing Gate 285/75 16 Nitto Trail Grappler
    Exterior:
    - Weather Tech window visors
    - Weather Tech stone & bug deflector
    - Debadged
    - TRD 3rd Light cover by Yota88
    - Firestik Black 3' 650W tunable tip CB antenna
    - 1 Rotopax 3 Gallon Gas Pack
    - 1 Rotopax Storage Pack Single
    - 2 Rotopax 4 Gallon Gas Packs
    - 1 Rotopax 2 Gallon Oil/Gas Pack
    Recovery:
    - Warn M8000-S Winch
    - Warn hawse fairlead
    - Factor 55 ProLink (Black)
    - Smittybilt Snatch Block
    - Smittybilt 3"x30' Recovery strap 30,000LBS
    - 5x Smittybilt 3/4" Black D-Rings w/ Daystar D-Ring isolator and Daystar shackle washers
    - 48" High-Lift Jack and handle keeper
    - High-Lift Jack Off Road Base
    - ARB Pump Kit and ARB Blue inflator with gauge and braided hose
  2. Feb 4, 2014 at 2:48 PM
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    Sweet truck! Lookin' good :D Black trucks clean up so nicely!
    I really want to get an under hood set up like that sometime.
  3. Feb 4, 2014 at 10:08 PM
    MWM BAJA 12
    Micah
    Dallas
    see my build page
    Thanks! I've had it for 10 months and it's been a work in progress. I finally got around to putting together a build page to keep track of everything
  4. Mar 2, 2014 at 8:50 AM
    jibbajabba
    jibbajabba Member
    Winnipeg - Canada
    12 Tacoma TRD Sport
    Nice build!
    I noticed you got the 2014 entune installed on your 2012. Which is sweet.
    I want to get the exact same thing done on my 2012. Planning on ordering the unit from FLTruck, but I have no clue where to get the pin adapter and antenna. How did you get yours installed and working?
  5. Mar 2, 2014 at 8:57 AM
    Large
    Large Red
    Why spend the coin for the baja just to swap the suspension? Just curious.
  6. Mar 2, 2014 at 10:48 PM
    MWM BAJA 12
    Micah
    Dallas
    see my build page
    I got a gr8 deal on the Baja used. Owner of the stealership drove it around and I acquired it with only 8,700 miles. Plus it had all the bells and whistles I was looking for. I didn't join Tacomaworld till after I got my Taco.....and then my wallet pulled a Keyser Soze on me
  7. Mar 3, 2014 at 2:23 AM
    MWM BAJA 12
    Micah
    Dallas
    see my build page
    you can get the antenna adapter from Crutchfield and the pin adapter from ebay. If you go to the page FLTruck is selling the radios on you will be able to get a better idea of install. I got my radio from FLTruck. Good deal! You will need an adapter from ebay and an A to A male usb cable to get the usb plug to work. you will also need a VIN# off a 2014 truck with Entune to get the Entune to work. I just looked up new Tacomas online and plugged in VIN#s till one worked :D
    If you have any more ?s just PM me and ill do me best to help
  8. Mar 26, 2014 at 8:49 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Hey Micah do you still have factory Battery terminals?
  9. Mar 26, 2014 at 11:02 AM
    MWM BAJA 12
    Micah
    Dallas
    see my build page
    Yep they are still stock for the time being. I'm swapping out the battery for a marine grade one @ the end of the year. I have a Pelfreybilt battery holder for it but can't justify spending $200+ on a new battery quite yet
  10. Mar 26, 2014 at 5:38 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Ya I remember you telling me that earlier, I just ordered my winch and got my blue sea fuse block and was unsure about the terminals.
  11. Apr 2, 2014 at 5:34 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
  12. Apr 2, 2014 at 5:37 PM
    MWM BAJA 12
    Micah
    Dallas
    see my build page
    Thanks!
  13. Apr 24, 2014 at 1:27 AM
    MWM BAJA 12
    Micah
    Dallas
    see my build page
    Just finished my Grillcraft grill and TOYOTA letters up front. Used heavy duty 3M tape to put the letters on. Thought I might have to use epoxy but that 20#sq/in 3M tape it legit
  14. Apr 25, 2014 at 10:11 AM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    I might need that tape for my Rock lights
  15. Apr 25, 2014 at 11:15 AM
    MWM BAJA 12
    Micah
    Dallas
    see my build page
    What kind of rock lights did u get? I got some Vision X rock lights
  16. Apr 25, 2014 at 11:54 AM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
  17. Apr 25, 2014 at 1:14 PM
    MWM BAJA 12
    Micah
    Dallas
    see my build page
    I saw the brackets but $50 just for brackets when the whole kit costs $120. Can't justify spending that when tape/magnets/ or epoxy will do the same. I'll still prob get em if I can't fab something up myself but damn $50 for brackets :/ WTF am I talking about.....I just payed $125 for a 50" light bar bracket. $50 is like half priced. Haha
    I'm getting a snorkel n a few weeks. Gonna need your help/tools for install
  18. Apr 25, 2014 at 6:57 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    No problem let me know when your ready
  19. Apr 25, 2014 at 11:57 PM
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    Nice Build
  20. Apr 26, 2014 at 12:16 AM
    MWM BAJA 12
    Micah
    Dallas
    see my build page
    Thanks! I'm not happy with my suspension set up but it was much better than it was. Baby steps $$$$$. I have a case of the shimmies when I go over small bumps :/
    Nothing 5-10gs worth of suspension work won't fix :'(
