Mxpatriot's Locked and Long Travel 4x4 Tacoma / Alaska Offroad Thread
Discussion in '2nd Gen. Builds (2005-2015)' started by Mxpatriot, Dec 26, 2009.
  1. Sep 4, 2017 at 11:31 AM
    #481
    Mxpatriot
    Mxpatriot [OP] Well-Known Member
    '06 4x4 AP LT and Locked
    And one from the Dalton Highway
    ARCHIVE, Dalandser and stairgod like this.
  2. Oct 10, 2017 at 9:44 PM
    #482
    Mxpatriot
    Updated specs on first post to be more accurate. Stuff has changed over the last year a bit.
    MrZoggs likes this.
  3. Oct 11, 2017 at 7:03 AM
    #483
    GetzPayd
    GetzPayd Well-Known Member
    Kennewick WA
    2014 DCSB Sport
    Total Chaos & Kings
  4. Oct 18, 2017 at 12:10 AM
    #484
    Mxpatriot
    Carnage pic:
    MrZoggs and GetzPayd like this.
  5. Oct 18, 2017 at 12:10 AM
    #485
    Mxpatriot
    Two new things in this photo... snow and @ARCHIVE garage's fabricated shackle hangers. Very impressed with the build quality on these things and the mounting positions possible that make SOA and SUA applications possible. Great option for the other guys building multi-use / expo trucks on SOA or SUA leaf packs.
    For years I have been unhappy with the lower ride height that I got with the defined SUA kit on stock shackle hangers, especially when I put my RTT on. Was considering a drastic measure (switching to air shocks instead of my bypasses) to get the rear end up 1-2" but ended up breaking my stock shackle (completely snapped in half). I called archive garage to see if they made anything and I got lucky with my timing. These let me run the front end up where it should be, both for clearance, being centered in the travel of the suspension, and for proper alignment being possible without having the front end in bro lean mode.
    These will be available for sale very soon and some more detailed photos will be out as well.
  6. Oct 18, 2017 at 3:04 AM
    #486
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Do you have any more pic of the shackle hanger? I can't really see it too well in the pic above.
  7. Oct 18, 2017 at 6:00 AM
    #487
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Details of hangers with pictures will be released in a couple weeks. The production kits are receiving minor tweaks.
  8. Feb 9, 2018 at 5:17 PM
    #488
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Love the rear mount winch... Been thinking of doing the same one day.
  9. Jun 14, 2018 at 10:53 AM
    #489
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    nvm i got the shock out and verified. you could use a regular 8 inch coilover but it would limit droop.
    i have the same kit. do your spring cups not hit the axle or tie rod? whats your alignment specs?
  10. Jun 14, 2018 at 7:54 PM
    #490
    Mxpatriot
    I bought my shocks used and someone had already machine a groove in the spring cup to clear the axle. The tolerance is close but they don't appear to ever touch.
    I end up getting around 2.5 degrees caster each side with camber within spec, off the top of my head.
  11. Jun 15, 2018 at 5:44 AM
    #491
    Sacrifice
    KS
    DCSB OR 4X4 LT
    do you have a picture of that? mine seemed to hit the axle or tie rod depending on which way i turn the wheel :notsure:
  12. Nov 11, 2018 at 6:18 PM
    #492
    patricox59
    patricox59 Well-Known Member
    Denver, CO
    2005 Tacoma TRD Sport 4x4
    Can you share a couple more up close pics of your front bumper? I’ve been trying to find people who have a tube bumper design with a winch and this is the first well done one I’ve seen. Want to make my own and see how you mounted winch to the bumper
  13. Nov 11, 2018 at 6:19 PM
    #493
    patricox59
    Denver, CO
    I’ve got a thick one now that I’d just like to get rid of to take some weight off the front end
  14. Nov 13, 2018 at 8:51 PM
    #494
    Mxpatriot
    Here's what I had in my imgur account that kind of shows the front bumper well. There are a few more of the truck on my IG, @chaseoutdoors.
    The design has shifted, it originally was a tube bumper with a hidden 2" receiver behind the license plate. After I destroyed that, I plated, gusseted, and reinforced the crap out of it and built what I have today, most of which is hidden from view by the plates that are welded up front. There are smarter way to go about it if you are starting from scratch, I just ended up continually adapting it until I found what I liked.
  15. Dec 9, 2018 at 12:34 AM
    #495
    patricox59
    Denver, CO
    Ok great, appreciate it. Those are helpful to look at
  16. Dec 28, 2018 at 11:25 PM
    #496
    Mxpatriot
  17. Jan 6, 2019 at 5:32 PM
    #497
    Mxpatriot
    New year, new look. Vinyl wrapped the truck in Avery SW900 Satin Khaki. Local shops were quoting several thousand bucks. Bought $600 worth of vinyl and did it myself with decent results and a lot of left extra vinyl. New wheels and tires as well.
  18. Jan 6, 2019 at 6:26 PM
    #498
    Sacrifice
    KS
    DCSB OR 4X4 LT
    i tried vinyl once and i sucked at it. looks good
  19. Jan 6, 2019 at 7:06 PM
    #499
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Looks like a brand new truck
  20. Jan 11, 2020 at 9:35 PM
    #500
    Kowalski
    Kowalski Well-Known Member
    2016 Tacoma TRD Off Road
    Still have it?
