MXT500 MIDLAND RADIO
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sabrina0987, Apr 28, 2022.
  1. Aug 9, 2022 at 6:57 AM
    AgingDisgracefully
    AgingDisgracefully Well-Known Member
    Peter
    2016 Tacoma SR5 V6 4X4
    I guess I could cut the wire somewhere between the fuse and the jack that plugs into the radio, feed it through the firewall and reattach, right?
  2. Aug 9, 2022 at 6:59 AM
    2lazy2
    2lazy2 Well-Known Member
    17 TRD OR 4X4 DCSB
    I have had to cut and re-splice wires to get through the firewall. I don't especially like the extra joints, but it seems to work fine. I solder, use waterproof shrink tube, tape, and corrugated wire loom. I don't want to worry about connections coming apart or corroding so I kind of over do it, but beats looking for short circuits later. I want my lights and radios to work when I need them!
  3. Aug 9, 2022 at 7:00 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    I was able to push the wire harness through the main harness firewall grommet without too much trouble. It required untaping the end of the grommet hole around the harness but that's just electrical tape if you want to replace it after wiring. You can push the power leads through that grommet from either direction so pushing the fuse blocks through that hole isn't necessary.
  4. Aug 9, 2022 at 8:10 AM
    DaBigDogg
    DaBigDogg "Say when..."
    Jay
    Mid-Suffolk, LINY
    2024 Celestial Silver DCSB TRD OR Hybrid
    Also, since nobody mentioned it, standard practice is having the fuse closer to the battery than the item you're powering...just an FYI.
  5. Aug 9, 2022 at 8:18 AM
    AgingDisgracefully
    Peter
  6. Aug 9, 2022 at 8:43 AM
    DaBigDogg
    Jay
    Mid-Suffolk, LINY
    You could do that but I'd change one major thing; rather just wrap it in electrical tape; I'd use weatherproof heat shrink to cover the connection.
    Something like this:
    https://www.amazon.com/dp/B084GDLSCK
    Personally? I'd use these with a good ratcheting crimping tool and a heat gun:
    https://www.amazon.com/dp/B09B9NP9F4
    Now take all of this with a grain of salt...I'm not a 12V installer by any stretch of the imagination but I've used these methods before and none of the vehicle's I've worked on have burnt to the ground lol. YMMV. If you really don't feel comfortable, enlist the help of some local HAM's or (if you don't mind paying) reach out to a local emergency vehicle upfitter. But if you do it right and not cut corners (like running power cables through door jambs lol), I don't think you should run into any trouble.
  7. Aug 9, 2022 at 9:53 AM
    AtomAnt
    AtomAnt Well-Known Member
    Adam
    South Cackalacky
    2019 TRD Sport
    I’m wiring mine the same as you’re planning to. You can cut those fuses off since you’re wiring to an aftermarket fuse block. Just wire directly from the radio to the fuse block and use a 15amp fuse in the fuse block. You can keep the fuse holder on the negative wire if you want but it’s not necessary unless you are connecting the negative wire directly to the batteries negative post, which isn’t recommended anyways. You’ll want to run the ground wire to a bussbar if you have one on your PowerTray or to the inside of the fender, where the battery’s ground cable is attached.
  8. Aug 9, 2022 at 10:52 AM
    AgingDisgracefully
    Peter
    I assume the a5A fuses are standardized? Like could I use these?:
    https://www.amazon.com/Bussmann-BP-...t=&hvlocphy=1021085&hvtargid=pla-568657539528
    Edit: Maybe I should get these since they are from Blue Sea Systems (the maker of my fuse block)?:
    https://www.bluesea.com/products/5242/ATO___ATC_Fuse_-_15_Amp
  9. Aug 9, 2022 at 11:00 AM
    AgingDisgracefully
    Peter
    One other question: it looks like the smaller fuses just plug in to the fuse block? I assume the fuse should go into the slot on the fuse box where I intend to put my radio positive wire ahead of my putting in that wire?
  10. Aug 9, 2022 at 11:08 AM
    GrundleJuice
    Michigan
    2016 TRD Bro
    Blade fuses are standardized but there are multiple standards so just be sure to get the physical size that fits the fuse block you will be using. Each size standard is available in a range of amp ratings.
    The first link you posted looks like a "mini" which is designated by ATM in the fuse part number. The second link is a "regular" size, aka "ATC" or "ATO". There is also a larger size, but those are not common in the fuse ratings that would be found on most vehicles.
  11. Aug 9, 2022 at 11:12 AM
    GrundleJuice
    Michigan
    2016 TRD Bro
    correct. The bottom of the fuse block that you will use should have a common wire or buss bar that connects all (or sometimes half) of the fuse outlets on one side and your wire powering whatever circuit/device you want to install will connect to the other side of the fuse slot that you want to put the fuse in, often via a small threaded post with a nut or a socket with a setscrew to clamp onto the wire. There are probably other designs, but they should all work the same way electrically.
  12. Aug 9, 2022 at 11:13 AM
    AgingDisgracefully
    Peter
  13. Aug 9, 2022 at 11:15 AM
    AgingDisgracefully
    Peter
    Do you have a sense of what size terminal eyelet would be appropriate for that fuse block? Thanks
  14. Aug 9, 2022 at 11:23 AM
    GrundleJuice
    Michigan
    2016 TRD Bro
    The specs tab on the link your sent says the buss stud size is #10-32 and the terminal screws are #8-32.
    A #10 screw uses a 3/16“ nominal hole diameter so I would get terminals with that size hole if possible.
    A #8 screw uses a 5/32" nominal hole diameter, but that's so close to 3/16“ that I wouldn't worry about trying to find a smaller terminal eyelet to fit those, if they even exist.
    You could probably go as large as ¼" on the eyelets if you had to without any issues
  15. Aug 9, 2022 at 11:26 AM
    #35
    GrundleJuice
    Michigan
    2016 TRD Bro
    Do you have wire strippers and good ratcheting crimpers to attach the terminals to the wire? Insulated terminals can not be crimped securely with pliers or the wrong crimper die, the nylon jacket prevents the metal conductor from closing securely with the wrong crimping tools.
    AgingDisgracefully likes this.
  16. Aug 9, 2022 at 11:29 AM
    #36
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    You don't need to keep them if you are going into your aux fuse block then to the battery. Those fuses are if you are going directly to your battery. There really isn't a need for you to have pos + and neg - from the radio to your aux fuse block... then to have that line fused between the battery and the aux fuse block. You only need one fuse between your equipment and the source.
    Remember, the blue sea can handle UP TO 30 Amps. Your radio is rated for much less than 30 AMPs -- 30 amps would fry the circuits so just be sure to look at the instructions for how many amps it is rated for then fuse appropriately (probably 5A or 7A).
  17. Aug 9, 2022 at 12:02 PM
    #37
    AtomAnt
    Adam
    South Cackalacky
    2019 TRD Sport
    The MXT575 factory harness uses a 15amp fuse, so that’s what I’ll be using in my fuse block. Per Midland, the max power it will pull is 10amps, so a 15amp fuse sounds right.
  18. Aug 9, 2022 at 12:08 PM
    #38
    AgingDisgracefully
    Peter
    I got these for stripping and crimping:
    https://www.amazon.com/dp/B001HQMWNY/?coliid=I200KTL0Q53NVD&colid=6QWZTAZD5F4P
    https://www.amazon.com/dp/B07Q32PYP3/?coliid=I1K00DYNQ3E8LI&colid=6QWZTAZD5F4P
  19. Aug 9, 2022 at 12:10 PM
    #39
    GrundleJuice
    Michigan
    2016 TRD Bro
  20. Aug 9, 2022 at 12:12 PM
    #40
    AgingDisgracefully
    Peter
    Thank you!
    GrundleJuice[QUOTED] likes this.
