My '01 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by WhyNotFab, Sep 3, 2010.
  1. Sep 3, 2010 at 6:41 PM
    WhyNotFab
    WhyNotFab [OP] Well-Known Member
    Ricky
    Florida
    '08 TRD Off Road
    Just got my first Tacoma Tuesday, it's a 2001 4x4 SR5..
    So far I've cleaned it up, painted some stuff, flushed the cooling system, changed oil, replaced blown bulbs.. minor things it needed. It has 198,000 miles but runs great, everything is in great condition just needs some TLC. I'm going to continue working on it tomorrow while I have a few days off.. change the differential oil, clean the K&N filter.. etc.
    I got the windows tinted (5% tint) and a Flowmaster muffler with turn downs yesterday.. and I ordered blacked out lights for the front/rear/3rd brake light, and also a billet grille. I had a soft tonnaeu cover on my S-10 that also fit, so I put it on, so far the truck already looks like a different truck. Can't wait for everything else to arrive! I have a ton of other plans for it also..
    Here are the pics so far,
  2. Sep 3, 2010 at 6:50 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    very nice, that tint is really dark!:eek:
    Is it a v6?
  3. Sep 3, 2010 at 7:05 PM
    WhyNotFab
    Ricky
    Florida
    '08 TRD Off Road
    Thanks! He only had to do the front sides/moonroof/windshield strip, the rear was already done (difference in color isn't too noticeable, especially from outside).. but I'm going to get a new windshield sometime and get it tinted with clear tint that blocks out almost the same amount of heat as the 5% that's on the rest. Keep the inside nice & cool!
    It's the V6, and so far seems to get pretty good gas mileage but I'll do whatever possible to increase it since every little bit helps lol.
    These forums are great, already browsing around and learning a lot.. writing things down I need to pick up tomorrow haha.
  4. Sep 3, 2010 at 7:07 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    nice. I have the same configuration and I used to get around 21 mpg before the new tires. Now its at around 19 mpg.
  5. Sep 3, 2010 at 7:18 PM
    WhyNotFab
    Ricky
    Florida
    '08 TRD Off Road
    I have 285/75/16, going to keep them and get new 16" wheels, but once these wear out I may go a little larger (if possible, the truck is lifted already but I'm unsure of the exact amount)..
    Just looked at your truck, looks great! Really like how you de-chromed everything!
  6. Sep 3, 2010 at 7:22 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Yeah, looks like around 3" of lift on yours. You can go a little larger but it requires some pretty serious trimming of the fenders to fit them. Your current tires are ~32.5" tall (33's) and the next common size up is 35's. Mine are 255/85/16 which are about 33.2" tall, but are really narrow.
  7. Sep 3, 2010 at 7:55 PM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    Very nice looking rig you have!
  8. Sep 3, 2010 at 8:36 PM
    mattleegee
    mattleegee Well-Known Member
    Tacoma, WA
    2018 WRX
    clean for 198k nice rig
  9. Sep 3, 2010 at 8:39 PM
    trd7
    trd7 4wd tacoma
    Tyler
    Columbia, SC
    95.5 Tacoma 4x4 4cyl auto
    AEM air intake
    good looking tacoma welcome to tw!
  10. Sep 3, 2010 at 8:40 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Morty
    Outer Space
    What are you going to do for suspension? I think it would bea good time to get some black wheel and mud tires!:D
  11. Sep 3, 2010 at 9:28 PM
    WhyNotFab
    Ricky
    Florida
    '08 TRD Off Road
    For now I'm going to leave it how it is, but once these tires wear out, if I decide to go larger then I'd like to lift it more. I'm considering these wheels though,
    What do you guys think?
  12. Sep 3, 2010 at 10:56 PM
    01tacoprerunner
    01tacoprerunner 16 TRD OR Inferno/01 4WD Prerunner
    Brian
    Raleigh, NC
    Do a headlight restore on it too. I used a method on mine that i found on youtube where you used a razor blade standing straight up, and scrape the yellow off of the head lights then you use a buffer and compound and it brings them right back to shiny.
  13. Sep 4, 2010 at 12:28 AM
    WhyNotFab
    Ricky
    Florida
    '08 TRD Off Road
    The new headlights are on their way, but I will probably restore the stock ones and keep them somewhere just in case, or maybe someone else needs them. I'll check YouTube, thanks!
  14. Sep 4, 2010 at 12:49 AM
    zero4
    zero4 Metal Cutter
    Will
    Northridge, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I used to spend the time sanding & polishing my headlights every so many months. I got tired of it. Aftermarket headlights are cheap & IMO well worth buying & saving the time to do the restore.
    If your headlights are just a little hazy than I would say do the restore. If they turned yellow already get new ones. I got mine for $60, I was worried about fitment & beam quality but they turned out to be pretty good. And they look way better than a restored headlight. When these turn yellow again, I won't even bother restoring & will buy another set.
    Hopefully they'll last a while. Everytime I wash the truck, I wax the headlights too.
  15. Sep 4, 2010 at 1:17 AM
    WhyNotFab
    Ricky
    Florida
    '08 TRD Off Road
    I posted a pic of the headlight/corner/bumper light kit i ordered,
    http://www.tacomaworld.com/forum/lighting/111736-bulbs-01-tacoma.html I had a couple questions about bulbs.. but then I realized the trim around the corners is black, so it won't match the grille shell :( I guess I'm picky haha.. but I'm not sure if it'll look right. I could always do a black grille shell, with the billet grille I have on the way.. but I kind of like the chrome.
    Anyone happen to have a pic of one with a black shell/billet grille?
  16. Sep 4, 2010 at 9:43 AM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    thats not a bad lookin rig ya got there,looks like its in good condition
  17. Sep 4, 2010 at 9:52 AM
    WhyNotFab
    Ricky
    Florida
    '08 TRD Off Road
    Thanks everyone!
    About to change the oil in the differentials, transfer case, & transmission.. trying to get as much done as possible since I'm off work till Tuesday then it'll be back to long days & no time to work on it as much haha.
  18. Sep 4, 2010 at 1:06 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Good looking truck bud!
  19. Sep 4, 2010 at 2:32 PM
    04prerunner
    04prerunner Well-Known Member
    kyle
    tampa, Fl
    2004 prerunner
    stock
    nice 4x4 man, keep the stock wheels though!
  20. Sep 4, 2010 at 3:19 PM
    WhyNotFab
    Ricky
    Florida
    '08 TRD Off Road
    Haha I want new ones!
