My '02 Tacoma makes this weird noise.
Discussion in '1st Gen. Tacomas (1995-2004)' started by MrMandraik, Oct 23, 2016.
  1. Oct 23, 2016 at 11:16 AM
    MrMandraik
    MrMandraik [OP] Member
    2002 Red Tacoma SRS
    Front end was smashed, replaced radiator, condenser, receiver/dryer, a few A/C lines. Still needs some separating but it needed to be able to drive with A/C so my uncle and myself made it work.
    When I turn the key in my ignition, and subsequently turn the engine over, there comes from the passenger side of the car a noise like a droning buzz. Brother in law says it might be the blower motor, but I have it in hand and there appears to be no correlation between it and the droning buzzing noise.
  2. Oct 23, 2016 at 11:18 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Only when starting? Might be a poor connection to the starter or a weak battery.
  3. Oct 23, 2016 at 11:19 AM
    MrMandraik
    2002 Red Tacoma SRS
    No, it persists when driving.
  4. Oct 23, 2016 at 11:22 AM
    MrMandraik
    2002 Red Tacoma SRS
    In this area; the video I took of the noise itself will not load.
  5. Oct 23, 2016 at 2:49 PM
    Roadeater
    Roadeater Well-Known Member
    Kennesaw, Ga
    2004 Black Tacoma Prerunner TRD V6
    Take a video, upload on YouTube and post the link so we can hear the noise and the Masters mech of this wonderful site can help you:)
  6. Oct 23, 2016 at 3:24 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Does your truck have ABS ? They are known to make a buzzing noise when mal-functioning.
  7. Oct 24, 2016 at 11:22 AM
    MrMandraik
    2002 Red Tacoma SRS
  8. Oct 24, 2016 at 11:28 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Christ, that is quite the noise you have there, can you hear it from under the hood?
  9. Oct 24, 2016 at 11:49 AM
    MrMandraik
    2002 Red Tacoma SRS
    Right? Not so much, it definitely sounds like it emanates from inside the cab as opposed to coming from under the hood.
  10. Oct 24, 2016 at 12:16 PM
    MrMandraik
    2002 Red Tacoma SRS
    That is merely a Bluetooth auxiliary hook up, and has no apparent bearing on the noise, plugged in or unplugged.
  11. Oct 24, 2016 at 1:43 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Don't know, my whole dash is apart cause I'm working on my truck and I only see the fan but that's not the problem, but then again I don't have abs
  12. Oct 24, 2016 at 2:00 PM
    RedManRocket
    Red
    2002 Double Cab LT
    It almost sounds like your air mixer, but your ac isn't on, don't know if still functions if the air is off, you would be able to see the little white peice spinning if that was the issue
  13. Oct 24, 2016 at 5:16 PM
    tan4x4
    Rick
    Folsom, CA
    Whatever is making that loud noise, must be vibrating as well.
    Can you feel around under there, touching everything and see if you can 'feel' the noise-maker?
  14. Oct 24, 2016 at 6:03 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Damn thats alot louder than i was expecting.
    Honestly cant even think of anything in that area that would be making that noise(since the blower motor was ruled out). The ecu itself???
  15. Oct 27, 2016 at 2:01 PM
    MrMandraik
    2002 Red Tacoma SRS
    What would the ECU be?
  16. Oct 27, 2016 at 7:15 PM
    wamego
    wamego Well-Known Member
    2002 Tacoma 2x4 TRD SR5
    I would just start reaching in with your finger and start feeling everything. I don't think the blower motor would sound like that. Maybe some kind of relay. Start turning things on and off, "I mean everything" one at a time and see if the sounds changes. Make sure that what you turn on or off is actually doing what its post to do. Where is the reset button for the emergency fuel shut off located at?
  17. Oct 27, 2016 at 7:32 PM
    MrMandraik
    2002 Red Tacoma SRS
    I'll have to do that; and I did notice that the droning modulates whenever I have the indicator lights on, when changing lanes or with the emergency lights on.
  18. Oct 27, 2016 at 7:52 PM
    wamego
    Pop the fuses out that runs the lights one by one. That will narrow it down in a flash:)
  19. Oct 27, 2016 at 8:03 PM
    MrMandraik
    2002 Red Tacoma SRS
    Is there a diagram I can reference to determine which fuse controls the lights? Either in the Haynes manual or the fuse box cover itself?
  20. Oct 27, 2016 at 8:12 PM
    ecotecin
    ecotecin Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    Most fuse box covers have it labeled on there, so check there, if not im sure you could just google a pic of it, ot the haynes manual would have it.
    MrMandraik[OP] likes this.
