My 03 has check eng light on, pulled 5 codes
Discussion in '1st Gen. Tacomas (1995-2004)' started by Debo Jones, Oct 7, 2010.
  1. Oct 7, 2010 at 7:09 PM
    Debo Jones
    Debo Jones [OP] Member
    I have a 2003 Tacoma V6
    PO113 Intake Air Temperature Circuit High Input
    What does this all mean? Can someone help me trouble shoot these problems, so I can get the truck to run right.
  2. Oct 7, 2010 at 7:12 PM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    v4 or v6?
    Anyways, check your airbox. (where the air filter is) Make sure the MAF sensor is still plugged in. you may have to replace the sensor (located on the tube)
  3. Oct 7, 2010 at 7:12 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Ok, do you use an oiled air filter or cold air intake or a K&N anything.
    Also a good bet would to be go to autozone and pick up some maf cleaner and clean your mass airflow sensor. It may cure all the problems
  4. Oct 7, 2010 at 7:40 PM
    Debo Jones
    My MAF was stolen along with airbox. I got a junk yard MAF, but no airbox. Was just running a metal screen over MAF tube.
    MAF cleaner sounds like a good idea
  5. Oct 7, 2010 at 7:50 PM
    clarkie152
    MA
    2016 4Runner Trail
    someone really needed a air box, huh?
    def MAF cleaner then, if that doesnt work, replace the MAF
  6. Oct 7, 2010 at 7:51 PM
    Debo Jones
    they took the battery and intake boot as well. lol
  7. Oct 7, 2010 at 7:58 PM
    ktmrider
    Junk
    wait, are you running your truck without an intake filter?
  8. Oct 7, 2010 at 8:28 PM
    Debo Jones
    Yeah, I was. I was not using the truck as a daily driver. only used it 3-5 times with out any filter.
  9. Oct 9, 2010 at 1:59 PM
    Debo Jones
    I was able to clean the MAF and Throttle Body.
    The only code its throwing now is
    Is the AIT another sensor?
  10. Oct 11, 2010 at 5:01 PM
    Debo Jones
    after a short test drive, its throwing the same 5 codes
  11. Oct 11, 2010 at 9:14 PM
    clarkie152
    MA
    2016 4Runner Trail
    then your MAF is toast. gotta replace that. might as well get an airbox to protect it
