My 06 tacoma is misfiring
Discussion in 'New Members' started by Fortlee20, Oct 12, 2020.
  1. Oct 12, 2020 at 6:30 AM
    Fortlee20
    Fortlee20 [OP] New Member
    09 Tocoma 4x4
    33s 18"rims rails
    I have a 06 Toyota Tacoma out of the blue about a month ago it started not taking gas and running horribly the more gas you give it, it will not take it just almost like it stalls it won't do anything until letting off the gas only being able to get it no more than a quarter of pedal. It's backfiring and only able to give it just a little bit of gas in what you call a sweet spot in order for it to run right or just run not right. I replace the spark plugs check the coil packs and also put a new mass air flow sensor and throttle positioning sensor. After doing this the trust is running better but it will all the sudden go back to doing what it was before and if I cut the ignition off and turn it back on it will start running pretty good once again. When I start the car up if it was up to 3000 RPM and fluctuates back and forth down to 500 RPMs all the way up to 3200. It's Butters app low speed but on the highway 50 to 80 miles an hour it runs great with no problem but as soon as I let off the gas it's like the engine stalls and didn't all the sudden jumps back up it's very weird any suggestions would be great
  2. Oct 12, 2020 at 6:43 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld Jason
    buckhuntin-tacoma likes this.
  3. Oct 12, 2020 at 6:47 AM
    Fortlee20
    09 Tocoma 4x4
    33s 18"rims rails
  4. Oct 12, 2020 at 9:25 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  5. Oct 14, 2020 at 12:13 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome!
