My 07 Taco just quit running??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by togah, Nov 1, 2014.
  1. Nov 1, 2014 at 9:12 PM
    togah
    togah [OP] Active Member
    garry
    corpus christi tx
    2007 tacoma prerunner
    Level ground, low speed(40mph), just stopped ..... Not struggling, no starting and stopping, no noises that I noted. Seemed like a fuse to something or relay just clicked out.
    I tried to restart...turns over but nothing....except the slightest try. That slight try is after the key was rotated on and off several times listening for the fuel pump. Lights all work I'm stumped your thoughts anyone have a similar break down.??? Pls help.....where to start eliminating things?
  2. Nov 1, 2014 at 9:15 PM
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    Check the mass air flow sensor. Google or search TW for instructions on how to clean it. If that doesn't work, replace it. I've had them fail on two different japanese cars, and the symptoms fit your description.
  3. Nov 2, 2014 at 7:54 AM
    togah
    garry
    corpus christi tx
    Ok...I've cleaned the Mass airflow sensor. Also pulled the housing and cleaned the throttle body. Still will not start??
    I did however spray some cleaner into the throttle body and she runs on the cleaner until it is burnt up.....I did not re assemble the air flow body before using the spray to start the engine. I can go buy a mass air sensor but the running on spray makes me think might be a fuel pump?? Any ideas ?? Really need to get her going....my only auto!!
    How would I check the fuel pump pressure?
    As info 175000 miles never changed anything but fluids regularly and plugs...never any issues
  4. Nov 2, 2014 at 8:28 AM
    gearcruncher
    Canadain bumper technician
  5. Nov 2, 2014 at 9:11 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  6. Nov 2, 2014 at 9:20 AM
    togah
    garry
    corpus christi tx
    I cannot feel any clicking while touching the fuel pump relay as the key is turned on and off?? Thinking about making a short jumper and connecting the two large lugs at the fuse panel...bypassing the relay ....? will this hurt anything...oem denso relay with 3 small lugs and 2 larger lugs.
  7. Nov 2, 2014 at 12:23 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Have someone in the truck to try and start it. Using a rubber mallet whack the bottom of the tank near the pump. If it starts there is your culprit. Time for a new fuel pump.
  8. Nov 2, 2014 at 12:43 PM
    togah
    garry
    corpus christi tx
    I beat the tank with a rubber mallet....as my wife cranked the motor....cranked but no start.
    The relay I cannot feel it click but can hear a click with a screwdriver to my ear....slight click and about half a second after the key is turned on....guess it ok?
    ANYONE KNOW IF THERE IS A VALVE TO CHECK THE FUEL PUMP PRESSURE. that is to be the next step Before I pull the tank down....just thought before I spend 500.00 !! :mad: On a fuel pump and drop the tank I want to be 100% sure
    How about a good after market fuel pump assembly cheaper than what I've found thus far or is the factory pump the way to go?
  9. Nov 2, 2014 at 12:51 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I don't know but maybe try another battery.
  10. Nov 2, 2014 at 12:58 PM
    Taco Salad Sport
    Taco Salad Sport Well-Known Member
    Castle Rock, CO
    2012 Sport DCSB 4x4
  11. Nov 2, 2014 at 2:19 PM
    togah
    garry
    corpus christi tx
    I see pump assembly at 5-600.00 and a denso pump that appears is the pump that would need to be installed at 190.00? Anyone have experience with the denso pump. I installed a pump in a chevy truck a few years back just had to change a couple hoses after taking the pump assembly/ sender unit apart. I really hate to spend 500 on a fuel pump. Any suggestions?
    I will check the battery voltage as well but with the starter spinning over good I don't know why that might be an issue.
  12. Nov 2, 2014 at 3:11 PM
    lionsm13
    lionsm13 Well-Known Member
    Black Hills SD
    07 Tacoma SR5
    Good info Scotty!! :)
    Plain and simple.
  13. Nov 2, 2014 at 5:56 PM
    Lester Lugnut
    He is the crown king of hill-billy diagnosis and I do not mean that in a disparaging way.
    I like Scotty.
  14. Nov 2, 2014 at 6:04 PM
    SuperJakeTheSnake
    SuperJakeTheSnake What is this place?
    Jacob
    Jacksonville NC
    02 Toyota Tacoma Prerunner
  15. Nov 2, 2014 at 6:22 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Rock auto shows a denso fuel pump and strainer for $102 plus shipping
  16. Nov 4, 2014 at 5:58 PM
    bobank
    bobank Well-Known Member
    Bob
    Nutting Lake MA
    06 SR5 DCSB Silverstreak Mica
    New Frame, Leer Cap, Vent Shades, Timbren's, Interior LED's, Fluid Film, Royal Purple.
    Any Luck togah? I'm curious to learn what broke.
  17. Nov 4, 2014 at 6:49 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Timing chain skipped a tooth/timing off??
  18. Nov 4, 2014 at 7:02 PM
    la0d0g
    running for the hills
    For crawling not hauling
    :popcorn: to hear the outcome
  19. Nov 4, 2014 at 7:03 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I've never heard of them skipping teeth, those chains are seriously beefy.
  20. Nov 4, 2014 at 7:16 PM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    If the car is running on carb cleaner then dies I'm thinking fuel related. Could be debris in the lines if it's not the pump. Are you sure the fuel gauge is working maybe it is out?
    Your truck isn't brand new so a pump or debris are possible causes
