My 07 Taco just quit running??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by togah, Nov 1, 2014.
  1. Nov 4, 2014 at 7:32 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Just putting out my guess and help out.
    I know that GM, on some vehicles, had the timing gear teeth over molded with a nylon skin to keep the timing gear noise down. As the nylon aged and cracked it came off the gear teeth and caused severe looseness in the chain and the chain could jump. It happed to an old car I had .... replaced them with solid steel gears.
  2. Nov 4, 2014 at 7:39 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I remember those days! I was working as a mechanics apprentice at the time. We were getting new GM cars in the shop just out of warranty that had jumped time.
    It usually happens when the engine is turned off, then doesn't crank back up.
  3. Nov 4, 2014 at 8:49 PM
    Canufixit
    New England
    My 74 Monte Carlo did it just like the OP. Driving along, no hurry - then nothing. Had Spark and Gas, Turned over and over and over ...
    Since the OP seemed to fail in a similar fashion I thought I'd mention the issue since many
    other things seemed to have been checked.
    Good Luck to the OP and let us inquiring minds know the outcome ...
  4. Nov 5, 2014 at 6:11 AM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    Highly likely a fuel pump or relay.
  5. Nov 5, 2014 at 6:28 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Jumping time can be EASILY checked with a timing light or a leakdown tester. Doesn't the OBD have a low fuel pressure error code? Is there a test/bleeder port on the fuel injection for a secondary fuel pressure gage?
  6. Nov 5, 2014 at 9:16 AM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    Sounds like a fuel issue, start with the fuel pump like someone else stated.
