My 12V MOD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aalders, Jun 19, 2009.
What do you think?
  1. Looks good would do it the same way.
    66 vote(s)
    83.5%
  2. Looks good but i would have done it different
    9 vote(s)
    11.4%
  3. Looks bad
    0 vote(s)
    0.0%
  4. I cant believe you cut a hole in your bed!!!
    4 vote(s)
    5.1%
  1. Jun 19, 2009 at 10:48 AM
    Aalders
    Aalders [OP] Well-Known Member
    Logan
    Dover, Delaware
    2009 Double Cab TRD off road
    Pop-n-Lock Tlailgate handle, TSB Rear Leafs, 12V bed outlet, Back up camera in mirror mod, Roof Rack, TRD Exhaust, Front Skid Plate, Running Boards, 4 100w KC SlimLites, Westin brush guard, Fog lights in the bed pockets, extra D rings in the bed, Fog light mod, seat belt chime mod, 75,000 candlepower StreamLight rechargeable flashlight
    I always thought it was weird that toyota put 110 in the bed but forgot to put 12v especially when it is so cheap to do. so i decided to fix that.
    I ordered this 12V Marine grade cigarette outlet from Amazon for $6
    The first thing i did when i got the outlet was to run over to our local Harbor Freight and pick up this step drill bit for $15. I used electrical tape to mark off where to stop. i drilled a 1-1/8in hole.
    I figured i should place to outlet as close to the tailgate as possible so that i could use it with my electric winch for my John boat. i figured it would look best right in the middle of the area where it slants inwards toward the tailgate.
    I had already placed a power block behind the left bed pocket from my previous bed light mod and used that for my + power feed. I ran 8ga wire i got at Lowes from the battery through the frame and up into the fender and then fused it with a 80amp fuse.
    I purchased a inline fuse holder and a 30amp fuse form Walmart for $2. I extended it with some 12g wire, put some ends on the end, and shrunk wrapped the connections.
    To put the outlet in i decided that i would use some little clips that came with a pair of Infinity speakers i purchased a few years ago so that i wouldn't run the risk of striping out the thin bed wall.
    in order to install the clips in the right position to line up with the holes on the outlet i knocked out the side of the hole with a square file i also got a Harbor Freight.
    Next thing was to wire it up! i put power to the power block and ran the ground to a bolt under the rear bumper sorry this is the only thing i forgot to take a picture of.... go figure. use your imagination.
    After i installed the hardware it was time to a test. the only thing i had at the time was this usb converter
    After that i cleaned everything up and was left with this.... the finished product.
    Total Cost around 8 dollars in parts and 15 dollars in tools!
    Toynado likes this.
  2. Jun 19, 2009 at 11:00 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    looks great, very professional install.
    Although, I haven't found a need for a 12v power source outside of the cab...
  3. Jun 19, 2009 at 11:14 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    You got skills! Nicely done!
  4. Jun 19, 2009 at 11:15 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    nice install
  5. Jun 19, 2009 at 11:22 AM
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
    You'r what makes this site great. Neet ideas and real answers.
    Yuma Taco,
  6. Jun 19, 2009 at 11:36 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    well Done!
  7. Jun 19, 2009 at 11:38 AM
    hillbillytaco
    hillbillytaco HOT!!
    Jeremy
    westbyGodvirginia
    06 impulse red trd off road dc v6 6spd
  8. Jun 19, 2009 at 11:40 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Great job!
  9. Jun 19, 2009 at 1:00 PM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    very clean install, looks like it came that way.
    Great job.........:thumbsup:
  10. Jun 19, 2009 at 1:18 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    looks good man. I put mine inside one of the cubbys with an on off switch but yours looks like it came like that.
  11. Jun 19, 2009 at 1:28 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Good job. I wouldn't really have a use for it personally, but a good idea nonetheless. Just make sure you throw some kind of water displacing grease on it to prevent corrosion. Marine grade or not, it will corrode after awhile. Rep added.
  12. Jun 19, 2009 at 2:28 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Beautiful work and I like the power block, you have the wiring half done for the next project, but I would like to know what do you use it for?
  13. Jun 19, 2009 at 2:37 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    great mod man. very well done.
  14. Jun 19, 2009 at 3:09 PM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    Well done! Great write up as well!
  15. Jun 19, 2009 at 4:23 PM
    Aalders
    Logan
    Dover, Delaware
    thanks guys for all your feedback. im going to replace the power block with a blue sea power Fuse block like this one soon just to make it neater and allow for easyer future mods
  16. Jun 19, 2009 at 5:57 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    where did you get your original 12V power from that goes into that powerblock?
  17. Jun 19, 2009 at 6:17 PM
    george3
    New Jersey
    I Googled "blue sea power Fuse block" and got a lot of choices. Which did you use and where was the best price if you checked that out. Thanks
  18. Jun 19, 2009 at 7:57 PM
    Aalders
    Logan
    Dover, Delaware
  19. Jun 20, 2009 at 3:48 AM
    george3
    New Jersey
  20. Jun 20, 2009 at 5:41 AM
    Aalders
    Logan
    Dover, Delaware
    i ran eight ga from the battery though the frame out into the fender
