My 1999 Taco TuRD Build - I sold it
Discussion in '1st Gen. Builds (1995-2004)' started by xtremewlr, Nov 2, 2018.
  1. Jul 14, 2019 at 11:17 AM
    #281
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I'll be curious to see how much of a difference you notice after the injector cleaning.
    Some day i'll get around to doing that for my truck.
  2. Jul 14, 2019 at 11:23 AM
    #282
    xtremewlr
    xtremewlr [OP] Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Me too. The truck has been running great and I was seeing decent mileage before hand at around 16/17 mpg cruising on the freeway at 75 or so. I'm not expecting much tho, maybe a little pick up in the power and a slight improvement on mileage. Either way, I'll have the piece of mind knowing the injectors are fresh.
  3. Jul 14, 2019 at 2:13 PM
    #283
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    From this...
    To this... (yes, I scrubbed the shit outta them using Purple Power stuff)
    To this...
    And finally this...
    jubei and loyaltothetaco like this.
  4. Jul 20, 2019 at 11:38 AM
    #284
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Cleaning things up and getting ready to reinstall one of the valve covers. I broke the lip off one of the small half moons and am waiting for the replacement to arrive on Monday. Also waiting for the injectors to come back which could be a couple weeks still.
    Re-wrapped the wiring loom for the injectors in Tesa tape.
    Installed the new spark plug seals in the valve cover and put the new gasket in place.
    loyaltothetaco likes this.
  5. Jul 20, 2019 at 11:39 AM
    #285
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Driver side cover in place.
    jubei likes this.
  6. Jul 20, 2019 at 3:30 PM
    #286
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Parts I was waiting for arrived early (not the injectors tho) so I was able to get the passenger valve cover installed. Also got the first piece of the oil filter relocation puzzle. I also realized that I think I installed the driver side spark plug gaskets the wrong way, aka backwards. Since it's already installed, I'm not messing with it. I think it will still seal fine tho.
    I also replaced the oil filler cap rubber gasket and the idle air control valve gasket on the TB.
    jubei, loyaltothetaco and Phessor like this.
  7. Jul 20, 2019 at 4:21 PM
    #287
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Started installing what I could until I get the injectors back. Coils are back in place and a couple other pieces but nothing major.
  8. Aug 4, 2019 at 10:08 AM
    #288
    Phessor
    Phessor Well-Known Member
    What were your ADS shock measurements?
  9. Aug 4, 2019 at 10:53 AM
    #289
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    turbodb likes this.
  10. Aug 4, 2019 at 4:07 PM
    #290
    Phessor
    xtremewlr[QUOTED][OP] likes this.
  11. Aug 22, 2019 at 4:58 PM
    #291
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Received my long awaited injectors. They were surprisingly pretty clean when comparing before and after.
    Before, right after removing from the motor and just a wipe down.
    After they were rebuilt. Haven't even taken them out of the bags yet.
    And finally the spec sheet showing before in GRAY and after clean/rebuild in WHITE. I'm impressed since they have 324k miles on them.
    Probably won't see any difference on the truck but it's good to know they are fresh again. Might start putting them back in tonight. Truck will be running again this weekend for sure.
  12. Aug 22, 2019 at 6:59 PM
    #292
    betterbuckleup
    Ian
    Concord, CA
    Dang. Those are pretty good results considering how many miles they have on them.
    Ngneer and xtremewlr[OP] like this.
  13. Aug 22, 2019 at 7:11 PM
    #293
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    I'm more impressed with how good they were before the cleaning honestly.
  14. Aug 23, 2019 at 8:11 AM
    #294
    betterbuckleup
    Ian
    Concord, CA
    That's what I actually meant lol.
    I would be more surprised if they were returned to you with results less than that.
  15. Aug 23, 2019 at 8:10 PM
    #295
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Took a couple hours tonight and got most of the intake put back together. I'll finish up in the morning.
    loyaltothetaco, jubei and Phessor like this.
  16. Aug 24, 2019 at 10:03 AM
    #296
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    So I got everything back together and the truck fired up. Runs super smooth now too. Don't know if that's because of the injectors or that I also cleaned the throttle body while I was waiting. Unfortunately, while I was checking everything out for leaks and such, I noticed that there was fuel draining out of the air box. Shut the truck down and discovered that the fuel pressure regulator must have a hole in the diaphragm and it was allowing fuel to leak. When this happens, it drains into the air intake tube so that fuel isn't dripping out onto a hot engine. So, back OFF with the intake so that I could access the FPR and replace it.
    And the fuel that leaked into the air box caused the rubber gasket that seals the air filter to swell and come unglued. So unless someone has a good idea to replace just the gasket, I have to get a new air box now too. :annoyed:
    Ran out to the parts store this morning and got the new FPR, a new air filter since the old one was soaked in gas, some 1/4" FI fuel hose to replace the old return lines coming off the FPR and ordered a new air box assembly that will fortunately get here this afternoon. IO lucked out and had the receipt from O'rielly's for the old air cleaner assembly when the PO had replaced it. I was able to use that and get a new one under warranty. I finished putting the new FPR in and getting the intake all back together again when I got home.
    Old and new Fuel pressure regulators. Old OEM one is Denso but I wasn't going to pay $180 for another OEM. Instead, I paid $145 for a no name replacement with a lifetime warranty.
    New FPR installed. I also replaced the rubber FI return hoses coming off it to the hard line on the fender. The FPR isn't a Denso like OEM but it's what I have for now and it has a lifetime warranty. Fortunately, they aren't that hard to get to now that I have remove the intake a couple times.
    Lower manifold back on. I reused the gaskets since they were new when I installed everything last night.
    And this is where it sits until the replacement air box comes in this afternoon.
    Ace115 likes this.
  17. Aug 24, 2019 at 4:36 PM
    #297
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    It's whole again. Runs great but seems a little hard to start sometimes. Maybe just the ECU needing to learn the newly rebuilt injectors. Drove it over to the DIY car wash and gave it a quick bath then came home and put the tent back on the rack as I'm heading out the California for Labor Day weekend.
    loyaltothetaco, Ace115 and Phessor like this.
  18. Aug 25, 2019 at 12:31 PM
    #298
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Wow man! I’m impressed with the attention to detail. You’ve got that truck better than brand new.
  19. Aug 25, 2019 at 6:56 PM
    #299
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Thanks man! Still have more to do, like finishing the front suspension but that will have to wait until I'm in the new house. I'll be moving next month, closing on a house off Twin Peaks in 2 weeks.
    Ace115[QUOTED] likes this.
  20. Aug 25, 2019 at 7:32 PM
    #300
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Took the truck out for a shake down drive. Went up Mt Lemmon here in Tucson and walked around at the top. Nice and cool up there compared to down in the city area, about 30 degrees difference. Truck ran great, maybe a little smoother than before but not a huge difference. Still have the occasional hard start issue when it's hot but it seems to be getting better. No visible leaks around the valve covers which is also a good thing.
    Took the roads less traveled going back down the back side of Lemmon, all graded, non-maintained roads. Good to be back in the dirt again. Found a few spots that look like good camping spots for future trips.
    Incredible views from the top of Mt Lemmon, too bad there was so much cloud cover at the time.
    My trusty co-pilot not impressed with the scenery.
    Neat little observatory at the top as well. Locked gates kept people from doing further exploring.
    No cloud cover on the backside of the mountain, giving spectacular views looking east.
    And the obligatory poser shots.
    slander, Ace115, jubei and 1 other person like this.
