My 1999 Taco TuRD Build - I sold it
Discussion in '1st Gen. Builds (1995-2004)' started by xtremewlr, Nov 2, 2018.
  1. Aug 25, 2019 at 8:13 PM
    #301
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Wow! That’s great! We can help you move if you want. Jonny and I have been working on the F250 the last month and it’s almost all done. Just needs tires and alignment. Can move a bunch of stuff in one shot with that truck.
    xtremewlr[OP] likes this.
  2. Aug 25, 2019 at 8:23 PM
    #302
    xtremewlr
    xtremewlr [OP] Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Awesome! Whatever help you guys can give will be appreciated.
    Ace115[QUOTED] likes this.
  3. Aug 25, 2019 at 8:33 PM
    #303
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    We’d be happy to. Just let us know when you are ready.
    jubei and xtremewlr[OP] like this.
  4. Oct 26, 2019 at 9:53 PM
    #304
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Decided that it was time to redo the tire carrier. I wasn't happy with the Coastal designed one. It's not a bad design by any mean and I like the use of the large heim joints but I couldn't for the life of me get it to stop pulling away from the tail gate nor could I get the latch mechanism working well enough for me to trust it.
    You can see in this shot that I was using a piece of strap that I cut, to secure the latch closed. This was a pain since I had to untie and re-tie it every time I wanted to open the tail gate. But it worked and the carrier never swung open unexpectedly.
    This shot, from when I had just finished building the bumper and carrier, shows how the carrier would constantly lean away from the tailgate, especially when the tire was mounted on it. I could never adjust that lean out of it, regardless of what I tried.
    So I gathered the parts that I wanted to use to remake the tire carrier, hopefully making it more secure and resistant to leaning away from the tailgate so far.
    The first part was to get rid of the heim joint hinge. I opted to go with the 4xInnovations hinge assembly. It's still a double shear design but uses 2" roller bearings with seals and a 3/4" grade 8 bolt for the hinge pin.
    The latch assembly is also from 4xInnovations.
    I unbolted the old carrier and removed it and then cut off the hinge brackets. I'm re-using the uprights from the old carrier since there is nothing wrong with those.
    I'm switching the main support beam from a 2x4 tube to a 2x3 .120 wall tube. Should be more than strong enough. Tacked the hing body to the tube and setup the hinge mount on the bumper.
    After thinking about how to mount the latch, I decided to cut the pad off the bumper that supported the old carrier at the far end.
    I decided that the latch pin for the new latch would have to be mounted into the bumper since there is hardly any room between the tailgate and the bumper when the tailgate is down. So I cut a new hole and started welding shit together again.
    Once that was all welded up, I got the latch figured out but didn't take pics until I was done. Oops. It didn't really work out the way I wanted, the latch hangs pretty low. But it's solid and won't come undone by itself.
    I still might cut it all apart and start over again since I have another 5' of 2x3 tube to play with. But I'll leave it as is for now and get the uprights moved over tomorrow.
    Ngneer, jubei, Phessor and 1 other person like this.
  5. Oct 27, 2019 at 7:26 AM
    #305
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    What's preventing you from moving the whole thing closer to the tailgate?
  6. Oct 27, 2019 at 8:13 AM
    #306
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    The way the bumper corners are angled. I suppose I could by welding up an angled piece at the hinge end to sort of wrap around the corner. I thought of that but it would be a lot more fab work and extra weight to make sure it was strong enough. Sort of like this: ----------\__
    The only other way would be to chop the corner up and sort of french the hing into it. Again, a lot more work than I really want to do. The main support beam is as close as I can get it right now and actually allows me to put shit between the tail gate and the carrier.
    The problem with the old one with the heims is it was leaning away from the tailgate and not remaining vertical the way it was supposed to. This pic makes it a little more obvious maybe.
  7. Oct 27, 2019 at 8:19 AM
    #307
    StaticOnTheRadio
    StaticOnTheRadio Well-Known Member
    TEXAS
    Sweet rig
  8. Oct 27, 2019 at 10:10 AM
    #308
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    I have the same hinge and it has worked great for the last two years.
  9. Oct 27, 2019 at 11:27 AM
    #309
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    I love the hinge and the latch. I'm just not overly pleased where the latch ended up in my case. I'll leave it for a while and see if it grows on me.
    Phessor[QUOTED] likes this.
  10. Oct 27, 2019 at 1:00 PM
    #310
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Finished up the new carrier this morning. It's much stronger and more stable than the previous version. This one will not lean away from the tailgate. Just needs painting now.
    This is why I couldn't mount the latch any higher than I have it. The tailgate open just about rests on the bumper. My license plate frame actually does.
    Rock solid with the tire on there now.
    And the tire is angled towards the bed like originally designed.
    Overall, I happy with it. I might change it again later but I'm in no rush. I'll see how it fares over this next wheeling season before making any further changes.
  11. Oct 27, 2019 at 5:03 PM
    #311
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Painted and re-mounted. Won't be coming off again for a while. I hope.
    Arctic Taco, slander, Phessor and 3 others like this.
  12. Oct 28, 2019 at 8:04 AM
    #312
    cynicalrider
    cynicalrider #NFG
    Jersey
    Swing out came out great dude! Solid work.
  13. Oct 28, 2019 at 9:08 AM
    #313
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Thanks! I'm still not super happy with the latch hanging down like that but taking a flap wheel to it helped some. Managed to reduce the profile a little bit.
  14. Oct 29, 2019 at 1:38 PM
    #314
    cynicalrider
    cynicalrider #NFG
    Jersey
    You ever install your coil bucket gussets?
  15. Oct 29, 2019 at 3:20 PM
    #315
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    No, not yet. I got tired of the truck having so much downtime and then I moved. Still have all the parts sitting to rebuild the front suspension. SPC UCAs, Whiteline LCA bushings, LBJs, so on and so forth...
  16. Oct 30, 2019 at 8:06 AM
    #316
    cynicalrider
    cynicalrider #NFG
    Jersey
    So sounds like you might be right behind me on this project. I am hoping my LCA bushings are still good though. They look like they are so as long as the cams aren't seized I will just be taking them off for some gussets and thats it.
    xtremewlr[QUOTED][OP] likes this.
  17. Oct 30, 2019 at 9:19 AM
    #317
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Yeah, I'm not in a rush to start the work, especially with prime wheeling season starting.
  18. Nov 22, 2019 at 7:09 PM
    #318
    Ngneer
    Ngneer Well-Known Member
    Man, stop beatin yourself, you do damn nice work, we all screw up with jumping the gun, it’s part of life’s lessons. I think you have done a jam up job brother keep it up, you inspire all of us, I’ve read nothing else up to this point. I’m an ol fart at 60, u have inspired me, nice job man!
  19. Nov 23, 2019 at 10:53 AM
    #319
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Thanks for the feedback guys! Glad y'all like it!
    Haven't been up to much with the truck lately. Busy with work, funds are tight and life and all. I have installed new headlights and corner markers to fix the original, faded ones as well as installed 01-04 fender flares which give much better coverage over the tires. Should help reduce the amount of mud fling nicely.
    Old headlights and side markers. The passenger side marker would occasionally fall out since the tab on the headlight was broken.
    The side markers were really faded in the orange part.
    New headlights and markers.
    Much better. Headlights are a little brighter now too. Still getting the aim dialed in but I got them pretty close.
    New (old) fender flares installed.
    MR E30, slander, jubei and 1 other person like this.
  20. Nov 23, 2019 at 5:31 PM
    #320
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    How did you mount the 01-04 flares? I've been keeping my eyes out for a set to get better coverage of my wheels as well. They look great and seem to fit well!
    I was thinking of using some kind of adhesive rather than drill holes in my fenders for the OEM mounts.
