My 1999 Taco TuRD Build - I sold it
Discussion in '1st Gen. Builds (1995-2004)' started by xtremewlr, Nov 2, 2018.
  1. Nov 23, 2019 at 5:39 PM
    #321
    xtremewlr
    xtremewlr [OP] Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Don't need either! I bolted them to the stock holes on my '99 and they are just as solid as the original small flares. Hopefully they stay like that, if not then I'll drill holes or do adhesive but I don't think it'll be needed.
  2. Nov 23, 2019 at 5:44 PM
    #322
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    when you say stock holes, do you mean the ones on the bottom side of the fender where the liner attaches?
    My truck came with missing flares so I have no reference to where they attach.
  3. Nov 23, 2019 at 5:46 PM
    #323
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Yup, those are what I mean. The flares are stiff enough that they bolt on and stay put just fine using those holes only.
  4. Nov 23, 2019 at 8:22 PM
    #324
    betterbuckleup
    Ian
    Concord, CA
    Gotcha. Thanks for explaining.
    Did you have to do any trimming on them/do you rub anywhere?
  5. Nov 23, 2019 at 8:23 PM
    #325
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Haven't had it offroad since installing them. I did have to trim the rear flares since my bed is cut for the bumper but that's it.
  6. Nov 24, 2019 at 6:09 PM
    #326
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    @xtremewlr , just reading through your build on the front and rear bumpers, They look good. But I have a question, why not use the front headlight loops. Wouldn't they provide some extra front end protection in case of a deer collision, or any other obstacle while trail riding. just curios.
  7. Nov 24, 2019 at 7:33 PM
    #327
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Sure, they probably would but I didn't like the look as much and they also make working on the engine that much harder, having to lean over them and all. I do have them and can weld them up if I decide to. Same with the side hoops on the rear bumper, although that's purely a looks thing.
    Ngneer likes this.
  8. Nov 24, 2019 at 7:42 PM
    #328
    Ace115
    Ace115 Well-Known Member
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    I prefer it without the headlight hoops but you heard my two cents already. Lol.
    hey when do you wanna start tinkering with the garage electrical?
    Ngneer likes this.
  9. Nov 24, 2019 at 7:59 PM
    #329
    Ngneer
    Ngneer Well-Known Member
  10. Nov 24, 2019 at 8:33 PM
    #330
    Ngneer
    Great write-up Sir, enjoyed the read with fantastic info for maintenance info, valve cover etc. which is my next thing to do, a lot of good info you gave on that. Thank You for sharing and one sic truck you have built.
    xtremewlr[OP] likes this.
  11. Nov 26, 2019 at 5:42 AM
    #331
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Anytime after Turkey day works for me. What's your schedule like? Maybe 12/7 or 8?
  12. Nov 26, 2019 at 8:55 AM
    #332
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    No plans that weekend. Let’s do it.
    xtremewlr[QUOTED][OP] likes this.
  13. Nov 26, 2019 at 8:56 AM
    #333
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Awesome. Either day works for me so whatever your schedule allows.
  14. Nov 26, 2019 at 8:58 AM
    #334
    Ace115
    Andrew
    Tucson AZ
    '03 DBL CAB 4X4
    Let’s start Saturday in case it takes a little longer than expected and we can wrap it up Sunday.
  15. Nov 26, 2019 at 9:18 AM
    #335
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Works for me!
  16. Nov 29, 2019 at 8:50 PM
    #336
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Spiker hood struts installed. Very straight forward to do, great fit and finish. Hood opens an additional 6" now, which is awesome. Only thing I had to do to make room was rotate my air compressor switch down. The strut was turning it on when I closed the hood otherwise.
  17. Dec 1, 2019 at 11:06 AM
    #337
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    I'm sure there are many of us, including myself, that have no welding skills at all. there are many mods, I'd like to do, but don't have the "Money", or the ability to weld and fab. If I could do work that looked like yours, I'd be one happy old man. Looking at your pics from the mountains, makes me wish I'd moved out to Arizona 30 years ago, when I was thinking about it.
  18. Dec 1, 2019 at 12:09 PM
    #338
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Thanks, I'm no professional welder, far from it! I appreciate the compliment tho! Really happy I made the choice to move out here!
  19. Dec 1, 2019 at 1:48 PM
    #339
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Finally swapped the clutch spring out for an Ace #70 spring. Good thing too, wasn't much life left on the clutch pedal center hook and the spring was almost worn half way thru. Might get an OEM brake pedal spring later.
  20. Dec 2, 2019 at 8:13 AM
    #340
    cynicalrider
    cynicalrider #NFG
    Jersey
    You tack that bracket in or was that there?
